I am not sure but there may be a bug in the compiler for Teensy 3.2
I've been working on a project and I need high and low voltages with 1 sec in between. I know LED is connected to pin 13 in Teensy 3.2 and I use that pin
in the code to apply HIGH and LOW using Arduino IDE's APIs. It works perfectly fine for the first I try that. Then I set pin 11 to be low and high and that's my problem begins.
Pin continues blink even though pin is set to be 11. When I change pin to be 13 again LED stops blinking. After this point it is always pin 11 in the code that makes the LED connected to pin 13 blink.
I think there is something wrong with compiler. It acts as if it is Teensy 2.x even though everything is set for Teensy 3.x
Any thoughts?
Any thoughts?
