MCP1825 3.3V Regulator and Teensy++2.0 and 5volts
So I've got a Teensy++2.0 that I have been using with the MCP1825 3.3V regulator with power coming from USB. All is working well. But I have a need to run this particular teensy at 5Volts for a quick test on another project.
Can I just jump the 5volt pad to the center pad? This will short the input and output pins of the regulator together. ANy ideas if this will cause a problem with the regulator?
Thanks,
Rich
