After I close the Arduino IDE and unplug the teensy board, the teensy.exe process remains active and continuously attempts to create a file, always getting a "Path not found" result.
In this particular instance teensy.exe is attempting to create the hex file corresponding to the last sketch I was working on before shutting down the IDE:
C:\Users\cff\AppData\Local\Temp\build1a815bdf9c5bfde50d8033dce09cdb00.tmp\WhisperSom_01g.ino.hex
Is this behavior by design?
I've attached a ProcMon screen shot.
Thanks!!
-- CraigF
Thanks!!
-- CraigF
