Teensy 4.1 trouble getting started
Turns out I cant even get the simplest LED program to run. A career in embedded systems and software development didnt help me. :)
Left the pin at 13 for the teensy 4.1. Here is the versions and sample code.
Arduino 1.8.13
Teensyduino 1.53
Windows 10 platform
I bought a USB cable with the teensy so that I would have all the right pins. I am using a motherboard USB port and not a powered USB hub, not sure if that matters.
When I first hooked up the teensy 4.1, the LED was blinking. Then I tried to download and run the LED program. No blinking...
I have read thru the troubleshooting pages and didn't find any solutions.
Steve
LED Code:
Blink
Turns on an LED on for one second, then off for one second, repeatedly.
// Pin 13 has an LED connected on most Arduino boards.
// Pin 11 has the LED on Teensy 2.0
// Pin 6 has the LED on Teensy++ 2.0
// Pin 13 has the LED on Teensy 3.0
// give it a name:
int led = 13;
// the setup routine runs once when you press reset:
// initialize the digital pin as an output.
pinMode(led, OUTPUT);
// the loop routine runs over and over again forever:
digitalWrite(led, HIGH); // turn the LED on (HIGH is the voltage level)
delay(1000); // wait for a second
digitalWrite(led, LOW); // turn the LED off by making the voltage LOW
Here is the verbose output.
11:38:52.672 (ports 5): Begin, version=1.53, high-res time
11:38:52.672 (ports 5): LoadLibrary cfgmgr32 ok
11:38:52.672 (ports 5): LoadLibrary ntdll ok
11:38:52.676 (ports 5): callback 0024
11:38:52.676 (ports 5): callback 0081
11:38:52.677 (ports 5): callback 0083
11:38:52.677 (ports 5): hWnd = 525898
11:38:52.681 (ports 5): nothing new, skipping HID & Ports enum
11:44:24.581 (post_compile 1): Begin, version=1.53, high-res time
11:44:26.806 (loader): Teensy Loader 1.53, begin program
11:44:26.868 (loader): Listening for remote control on port 3149
11:44:26.869 (loader): initialized, showing main window
11:44:26.943 (loader): remote connection 1380 opened
11:44:26.944 (loader): remote cmd from 1380: "comment: Teensyduino 1.53 - WINDOWS (teensy_post_compile)"
11:44:26.944 (loader): remote cmd from 1380: "status"
11:44:26.944 (post_compile 1): Sending command: comment: Teensyduino 1.53 - WINDOWS (teensy_post_compile)
11:44:26.947 (loader): HID/win32: vid:045E pid:00DB ver:0173
11:44:26.948 (post_compile 1): Status: 0, 0, 0, 0, 0, 0, C:\Users\Steve\AppData\Local\Temp\arduino_build_77 4481\, Blink.ino.hex
11:44:26.948 (post_compile 1): Sending command: dir:C:\Users\Steve\AppData\Local\Temp\arduino_buil d_251115\
11:44:26.948 (loader): remote cmd from 1380: "dir:C:\Users\Steve\AppData\Local\Temp\arduino_bui ld_251115\"
11:44:26.948 (loader): remote cmd from 1380: "file:Blink.ino.hex"
11:44:26.948 (post_compile 1): Sending command: file:Blink.ino.hex
11:44:26.957 (loader): File "Blink.ino.hex". 13380 bytes, 0% used
11:44:26.962 (loader): remote cmd from 1380: "status"
11:44:26.964 (post_compile 1): Status: 1, 0, 0, 0, 0, 0, C:\Users\Steve\AppData\Local\Temp\arduino_build_25 1115\, Blink.ino.hex
11:44:26.964 (post_compile 1): Sending command: auto:on
11:44:26.964 (loader): remote cmd from 1380: "auto:on"
11:44:26.965 (post_compile 1): Disconnect
11:44:26.988 (loader): remote connection 1380 closed
11:44:27.077 (post_compile 2): Begin, version=1.53, high-res time
11:44:27.078 (loader): remote connection 1432 opened
11:44:27.078 (loader): remote cmd from 1432: "comment: Teensyduino 1.53 - WINDOWS (teensy_post_compile)"
11:44:27.078 (loader): remote cmd from 1432: "status"
11:44:27.078 (post_compile 2): Sending command: comment: Teensyduino 1.53 - WINDOWS (teensy_post_compile)
11:44:27.079 (loader): remote cmd from 1432: "dir:C:\Users\Steve\AppData\Local\Temp\arduino_bui ld_251115\"
11:44:27.079 (loader): remote cmd from 1432: "file:Blink.ino.hex"
11:44:27.079 (post_compile 2): Status: 1, 1, 0, 0, 0, 0, C:\Users\Steve\AppData\Local\Temp\arduino_build_25 1115\, Blink.ino.hex
11:44:27.079 (post_compile 2): Sending command: dir:C:\Users\Steve\AppData\Local\Temp\arduino_buil d_251115\
11:44:27.079 (post_compile 2): Sending command: file:Blink.ino.hex
11:44:27.088 (loader): File "Blink.ino.hex". 13380 bytes, 0% used
11:44:27.093 (loader): remote cmd from 1432: "status"
11:44:27.094 (post_compile 2): Status: 1, 1, 0, 0, 0, 0, C:\Users\Steve\AppData\Local\Temp\arduino_build_25 1115\, Blink.ino.hex
11:44:27.094 (post_compile 2): Disconnect
11:44:27.114 (loader): remote connection 1432 closed
11:44:27.115 (post_compile 3): Running teensy_reboot: "C:\Program Files (x86)\Arduino\hardware\teensy\..\tools\teensy_rebo ot.exe" teensy_reboot.exe "-board=TEENSY41" "-port=COM1" "-portlabel=COM1" "-portprotocol=serial"
11:44:27.115 (loader): remote connection 1432 opened
11:44:27.180 (reboot 4): Begin, version=1.53, high-res time
11:44:27.180 (reboot 4): location = COM1
11:44:27.180 (reboot 4): portlabel = COM1
11:44:27.180 (reboot 4): portprotocol = serial
11:44:27.180 (reboot 4): Serial device COM1 will be tried first
11:44:27.180 (reboot 4): LoadLibrary cfgmgr32 ok
11:44:27.180 (reboot 4): LoadLibrary ntdll ok
11:44:27.182 (reboot 4): nothing new, skipping HID & Ports enum
11:44:27.183 (loader): remote connection 1456 opened
11:44:27.184 (reboot 4): Disconnect
11:44:27.207 (loader): remote connection 1456 closed
11:44:27.208 (loader): remote connection 1432 closed
11:44:50.744 (loader): Verbose Info event
11:49:15.963 (ports 5): WM_DEVICECHANGE DBT_DEVICEARRIVAL
11:49:15.966 (loader): remote connection 1712 opened
11:49:15.979 (ports 5): found_usb_device, id=\\?\usb#vid_16c0&pid_0478#000c28d8#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
11:49:15.979 (ports 5): found_usb_device, loc=usb:0/1D0000/0/1/5 Port_#0005.Hub_#0010
11:49:15.979 (ports 5): found_usb_device, hwid=USB\VID_16C0&PID_0478&REV_0105
11:49:15.979 (ports 5): found_usb_device, devinst=00000005
11:49:15.979 (ports 5): add: loc=usb:0/1D0000/0/1/5, class=HID, vid=16C0, pid=0478, ver=0105, serial=000c28d8, dev=\\?\usb#vid_16c0&pid_0478#000c28d8#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
11:49:15.979 (ports 5): hiddev_from_devinst_list: iface=0
11:49:15.980 (ports 5): found_usb_device complete
11:49:15.980 (ports 5): hid, found devinst=0000000A
11:49:15.980 (ports 5): hid, path=\\?\hid#vid_16c0&pid_0478#8&1f7c6fd9&0&0000#{ 4d1e55b2-f16f-11cf-88cb-001111000030}
11:49:15.980 (ports 5): hid, opened handle
11:49:15.980 (ports 5): devinst=0000000A, location=usb:0/1D0000/0/1/5
11:49:15.980 (ports 5): vid=16C0, pid=0478, ver=0105, usepage=FF9C, use=0025
11:49:15.980 (ports 5): devpath=\\?\hid#vid_16c0&pid_0478#8&1f7c6fd9&0&000 0#{4d1e55b2-f16f-11cf-88cb-001111000030}
11:49:15.980 (ports 5): usb_add: usb:0/1D0000/0/1/5 hid#vid_16c0&pid_0478 (Teensy 4.1) Bootloader
11:49:16.098 (loader): Device came online, code_size = 8126464
11:49:16.105 (loader): Board is: Teensy 4.1 (IMXRT1062), version 1.05
11:49:16.120 (loader): File "Blink.ino.hex". 13380 bytes, 0% used
11:49:16.125 (loader): set background IMG_ONLINE
11:49:16.141 (loader): File "Blink.ino.hex". 13380 bytes, 0% used
11:49:16.146 (loader): elf appears to be for Teensy 4.1 (IMXRT1062) (8126464 bytes)
11:49:16.151 (loader): elf binary data matches hex file
11:49:16.156 (loader): elf file is for Teensy 4.1 (IMXRT1062)
11:49:16.162 (loader): begin operation
11:49:16.178 (ports 5): WM_DEVICECHANGE DBT_DEVNODES_CHANGED
11:49:16.178 (ports 5): nothing new, skipping HID & Ports enum
11:49:16.208 (loader): flash, block=0, bs=1024, auto=1
11:49:16.213 (loader): gauge old value = 0
11:49:16.218 (loader): flash, block=1, bs=1024, auto=1
11:49:16.403 (loader): gauge old value = 1
11:49:16.408 (loader): flash, block=2, bs=1024, auto=1
11:49:16.413 (loader): gauge old value = 2
11:49:16.419 (loader): flash, block=3, bs=1024, auto=1
11:49:16.426 (loader): gauge old value = 3
11:49:16.432 (loader): flash, block=4, bs=1024, auto=1
11:49:16.438 (loader): gauge old value = 4
11:49:16.447 (loader): flash, block=5, bs=1024, auto=1
11:49:16.452 (loader): gauge old value = 5
11:49:16.459 (loader): flash, block=6, bs=1024, auto=1
11:49:16.459 (ports 5): WM_DEVICECHANGE DBT_DEVNODES_CHANGED
11:49:16.459 (ports 5): nothing new, skipping HID & Ports enum
11:49:16.464 (loader): gauge old value = 6
11:49:16.484 (loader): flash, block=7, bs=1024, auto=1
11:49:16.495 (loader): gauge old value = 7
11:49:16.500 (loader): flash, block=8, bs=1024, auto=1
11:49:16.507 (loader): gauge old value = 8
11:49:16.513 (loader): flash, block=9, bs=1024, auto=1
11:49:16.517 (loader): gauge old value = 9
11:49:16.523 (loader): flash, block=10, bs=1024, auto=1
11:49:16.528 (loader): gauge old value = 10
11:49:16.533 (loader): flash, block=11, bs=1024, auto=1
11:49:16.537 (loader): gauge old value = 11
11:49:16.544 (loader): flash, block=12, bs=1024, auto=1
11:49:16.549 (loader): gauge old value = 12
11:49:16.558 (loader): flash, block=13, bs=1024, auto=1
11:49:16.562 (loader): gauge old value = 13
11:49:16.574 (loader): sending reboot
11:49:16.579 (loader): begin wait_until_offline
11:49:16.618 (ports 5): WM_DEVICECHANGE DBT_DEVICEREMOVECOMPLETE
11:49:16.619 (ports 5): remove: loc=usb:0/1D0000/0/1/5
11:49:16.619 (ports 5): usb_remove: usb:0/1D0000/0/1/5
11:49:16.619 (ports 5): nothing new, skipping HID & Ports enum
11:49:16.636 (loader): offline, waited 1
11:49:16.656 (loader): end operation, total time = 0.488 seconds
11:49:16.671 (loader): set background IMG_REBOOT_OK
11:49:16.693 (loader): redraw timer set, image 14 to show for 1200 ms
11:49:16.734 (ports 5): WM_DEVICECHANGE DBT_DEVNODES_CHANGED
11:49:16.735 (ports 5): nothing new, skipping HID & Ports enum
11:49:16.796 (loader): HID/win32: vid:045E pid:00DB ver:0173
11:49:17.893 (loader): redraw, image 9
11:49:18.269 (ports 5): purge, name=hid#vid_16c0&pid_0478 (Teensy 4.1) Bootloader, loc=usb:0/1D0000/0/1/5, age=1.650 sec
