Teensy 4 + 2.8" TFT using ILI9341_t3 issues.
KG5NII
SETUP:
Teensy 4 + 2.8 inch ILI9341 TFT display using ILI9341_T3
Teensyduno-1.47-beta7
Arduino 1.8.8 on Linux 4.19.27 (Funtoo Linux)
I've a prototype Teensy TFT display shield PCB I originally designed to be used with Teensy 3.2
The TFT display pinouts on that PCB are different than the pinouts Teensy 4 needs. Therefore I cut
the traces between the Teensy and TFT on the PCB and rewired as per the code below with kynar wire.
ISSUES:
I'm having issues with display corruption at random times.
I've tried multiple displays with the same result.
In the example code below (which originally comes from the library example code)
it seems to work, BUT, not for long. Usually end up at some point early on with a
white display, or sometimes just a mass of graphics corruption that ends up as a white screen.
Displaying text seems to be stable, but in general nothing seems to be rock solid at all.
Questions:
  • What is the status of ILI9341_T3 on Teensy 4?
  • Could someone verify proper and stable operation on their setup?
  • 2 days of testing and trying different code has left me stumped. If others are experiencing the same issue then frankly I would be happy, It's not the TFT display. Tried 3 of them with same results. At this point I'm almost frustrated and am definitely sleep depraved. Suggestions anyone?
  • A completely different question: AGND (Teensy 3.x) is now GND on Teensy 4 or is that a misprint on the info card?
In the following code, my TFT is setup with TFT reset pin to teensy pin 8. If your TFT reset pin is connected to the Teensy 3.3v pin then set TFT_RST to 255.
#include <ILI9341_t3.h>
#define BACKLITE   1                       // 1 = enable if using backlight control,
                                                    // 0 = disable. Display brightness is set via external resistor
#define SECONDS 2000                    // Delay in ms
const uint8_t TFT_BACKLITE    =    6;  // Backlight brightness control.
                                                    // LED pin of TFT connected to this pin via 100 Ohm resistor.
const uint8_t TFT_RST         =    8;    // TFT's RESET pin connects here. A nice way to hw reset the TFT
                                                    // This appears to only occur during a tft.begin() call.
                                                    // Otherwise connect TFT's RESET pin to Teensy 3.3v pin and set value to 255
// Normal SPI Connections
const uint8_t TFT_DC          =    9;
const uint8_t TFT_CS          =   10;
const uint8_t TFT_MOSI        =   11;
const uint8_t TFT_MISO        =   12;
const uint8_t TFT_SCLK        =   13;
const char msg[17] = "testTriangles():";
uint16_t counter = 1;
ILI9341_t3 tft = ILI9341_t3(TFT_CS, TFT_DC, TFT_RST, TFT_MOSI, TFT_SCLK, TFT_MISO);
 #if BACKLITE
    const uint8_t brightness = 7;                               // brightness level 0 - 10
    analogWrite(TFT_BACKLITE, 5 + 25*brightness);     // resulting values of 5 - 255
  tft.begin();
  tft.setRotation(1);
  tft.setTextColor(ILI9341_CYAN);
  tft.setTextSize(1);
void loop(void) {
   testTriangles();
   counter++;
   delay(SECONDS);
void testTriangles(void) {
  int16_t       n,  i,  cx = tft.width()  / 2 - 1,
                        cy = tft.height() / 2 - 1;
  tft.setCursor(0,0);
     tft.printf("%s %d",  msg, counter);
  Serial.printf("%s %d\n",msg, counter);
  n     = min(cx, cy);
  for(i=0; i<n; i+=5) {
    tft.drawTriangle(
                      cx    , cy - i,            // peak
                      cx - i, cy + i,           // bottom left
                      cx + i, cy + i,          // bottom right
                      tft.color565(0, 0, i)
Thanks in advance,
Ron KG5NII
  • GraphicsTest.ino
Code commentary in the file attachment referring TFT_RST is wrong. Instead of the TFT's LED pin it should be the TFT's RESET pin.
Mistakes are my thing. I'm good at them. Unbelievable the mistakes I can spot once going public with the code.
It's a big deal cuz someone new reading this could get all confused. I sure did. My apologies for this. I will endeavor
to be more accurate in the future.
Ron KG5NII
Not sure if what you have is working now or not?
I did the conversion to get it to run on the T4, which has worked for me. Will try yours later. You might change the ili9341_t3 library and lower the MAX SPI speed and see if that helps.
Kurt,
Thank you for your reply. Don't bother. Its now working. Turns out that pin 13 (SCLK) had a tad too much flux on it which was causing a high resistance connection. Not your typical brown goo flux. Wasn't that easy to see. Deal is my 12 yo daughter is the one who found the issue less than 60 sec after she started looking. Then I was lectured about keeping my header pins clean. Good grief. Double face palm. I'm going to go get a beer now.
Cheers,
Ron, KG5NII
