Having trouble with SPI connections to my Teensy 4.1. Specifically an IMU breakout from Adafruit, the ISM330DHCX. I did look at the other thread on an Adafruit IMU in SPI mode but I could not find a solution to my problem. My code is below, simply the provided Adafruit testing example.
I have a barometer from Adafruit running in SPI mode with no issues, and I've run the ISM330DHCX in SPI mode off of my Arduino MEGA 2560 without issue. What's strange is ism330dhcx.begin_SPI(LSM_CS) returns true, however the accelerometer options can't be changed and the output is a set of values that do not update as the ISM330DHCX is moved, and they do work in I2C mode or in SPI mode running from the MEGA. I think the wiring is correct, the Barometer runs fine off of the same SPI pins, just with CS set to 9.
The outputs look like:
Adafruit ISM330DHCX test!
ISM330DHCX Found!
Accelerometer range set to: +-2G
Gyro range set to: Accelerometer data rate set to: 1.66 KHz
Gyro data rate set to: 1.66 KHz
Temperature 25.50 deg C
Accel X: 0.00 Y: 0.00 Z: -9.79 m/s^2
Gyro X: 0.00 Y: 0.00 Z: 0.00 radians/s
I'm probably overlooking something, hopefully someone is able to offer some guidance. Thank you!
#include <Arduino.h>
#include <Adafruit_ISM330DHCX.h>
#include <Adafruit_Sensor.h>
// For SPI mode, we need a CS pin
#define LSM_CS 10
// For software-SPI mode we need SCK/MOSI/MISO pins
#define LSM_SCK 13
#define LSM_MISO 12
#define LSM_MOSI 11
Adafruit_ISM330DHCX ism330dhcx;
void setup(void) {
pinMode(10,OUTPUT); // set default spi CS to high
while (!Serial)
delay(10); // will pause Zero, Leonardo, etc until serial console opens
Serial.println("Adafruit ISM330DHCX test!");
// if (!ism330dhcx.begin_I2C()) {
if (!ism330dhcx.begin_SPI(LSM_CS)) {
// if (!ism330dhcx.begin_SPI(LSM_CS, LSM_SCK, LSM_MISO, LSM_MOSI)) {
Serial.println("Failed to find ISM330DHCX chip");
while (1) {
delay(10);
Serial.println("ISM330DHCX Found!");
//ism330dhcx.setAccelRange(LSM6DS_ACCEL_RANGE_4_G);
Serial.print("Accelerometer range set to: ");
switch (ism330dhcx.getAccelRange()) {
case LSM6DS_ACCEL_RANGE_2_G:
Serial.println("+-2G");
case LSM6DS_ACCEL_RANGE_4_G:
Serial.println("+-4G");
case LSM6DS_ACCEL_RANGE_8_G:
Serial.println("+-8G");
case LSM6DS_ACCEL_RANGE_16_G:
Serial.println("+-16G");
ism330dhcx.setGyroRange(LSM6DS_GYRO_RANGE_250_DPS);
Serial.print("Gyro range set to: ");
switch (ism330dhcx.getGyroRange()) {
case LSM6DS_GYRO_RANGE_125_DPS:
Serial.println("125 degrees/s");
case LSM6DS_GYRO_RANGE_250_DPS:
Serial.println("250 degrees/s");
case LSM6DS_GYRO_RANGE_500_DPS:
Serial.println("500 degrees/s");
case LSM6DS_GYRO_RANGE_1000_DPS:
Serial.println("1000 degrees/s");
case LSM6DS_GYRO_RANGE_2000_DPS:
Serial.println("2000 degrees/s");
case ISM330DHCX_GYRO_RANGE_4000_DPS:
Serial.println("4000 degrees/s");
// ism330dhcx.setAccelDataRate(LSM6DS_RATE_12_5_HZ);
Serial.print("Accelerometer data rate set to: ");
switch (ism330dhcx.getAccelDataRate()) {
case LSM6DS_RATE_SHUTDOWN:
Serial.println("0 Hz");
case LSM6DS_RATE_12_5_HZ:
Serial.println("12.5 Hz");
case LSM6DS_RATE_26_HZ:
Serial.println("26 Hz");
case LSM6DS_RATE_52_HZ:
Serial.println("52 Hz");
case LSM6DS_RATE_104_HZ:
Serial.println("104 Hz");
case LSM6DS_RATE_208_HZ:
Serial.println("208 Hz");
case LSM6DS_RATE_416_HZ:
Serial.println("416 Hz");
case LSM6DS_RATE_833_HZ:
Serial.println("833 Hz");
case LSM6DS_RATE_1_66K_HZ:
Serial.println("1.66 KHz");
case LSM6DS_RATE_3_33K_HZ:
Serial.println("3.33 KHz");
case LSM6DS_RATE_6_66K_HZ:
Serial.println("6.66 KHz");
// ism330dhcx.setGyroDataRate(LSM6DS_RATE_12_5_HZ);
Serial.print("Gyro data rate set to: ");
switch (ism330dhcx.getGyroDataRate()) {
ism330dhcx.configInt1(false, false, true); // accelerometer DRDY on INT1
ism330dhcx.configInt2(false, true, false); // gyro DRDY on INT2
// IMU
// /* Get a new normalized sensor event */
sensors_event_t accel;
sensors_event_t gyro;
sensors_event_t temp;
ism330dhcx.getEvent(&accel, &gyro, &temp);
Serial.print("\t\tTemperature ");
Serial.print(temp.temperature);
Serial.println(" deg C");
/* Display the results (acceleration is measured in m/s^2) */
Serial.print("\t\tAccel X: ");
Serial.print(accel.acceleration.x);
Serial.print(" \tY: ");
Serial.print(accel.acceleration.y);
Serial.print(" \tZ: ");
Serial.print(accel.acceleration.z);
Serial.println(" m/s^2 ");
/* Display the results (rotation is measured in rad/s) */
Serial.print("\t\tGyro X: ");
Serial.print(gyro.gyro.x);
Serial.print(gyro.gyro.y);
Serial.print(gyro.gyro.z);
Serial.println(" radians/s ");
// // serial plotter friendly format
// Serial.print(temp.temperature);
// Serial.print(",");
// Serial.print(accel.acceleration.x);
// Serial.print(","); Serial.print(accel.acceleration.y);
// Serial.print(","); Serial.print(accel.acceleration.z);
// Serial.print(gyro.gyro.x);
// Serial.print(","); Serial.print(gyro.gyro.y);
// Serial.print(","); Serial.print(gyro.gyro.z);
// Serial.println();
// delayMicroseconds(10000);
ISM330DHCX Found!
