Originally Posted by
boxxofrobots
BTW blakeA, if I am understanding you correcttly in your point about not doing things "in the audio path" here's something to consider: When you change a CV at a high rate of delta (as you do digitally with ease) you introduce audible steps. This is why my synth does absolutely everything as an analog model in the "signal path" as much as possible: because every "CV" change needs to happen at sample rate, with proper rate limiting. There's more than 30 filters in my machine that just make sure "control voltages" don't change too fast, or even that square waves from lfos behave more "analog."
