Trying to understand how it is possible to run a web server (preferably Node JS) on the Teensy via the USB port (i.e. as a pendrive kind of thing)
The idea is to build a device that can be first setup via USB connection using the server, while then eventually connect to a WAP WiFi network for example.
My guess is that in the old days modems would connect to the internet via Serial Port; nowadays we have USB, and there must be a way to connect from serial to a TCP socket to run a HTTP server.
Any hint at the direction to look would be helpful.
Browsing the web I see many project aiming at running a server on the computer to talk to the Teensy or Arduino hardware, but not much about running the server on the Teensy itself.
Thanks for help.
Thanks for help.
