Strange error in complilig sketch for Simplewavetable
Hello.
I have a strange error in this sketch at instrucion:
wavetable.setInstrument(ChurhOrgan),
No matching funcion for call to "AudioSynthWavetable::setInstrument(const instrument_data&)'
I have decoded ChurchOrgan with utility Soundfontdecoder from a sf2 files.
Can anyone help me?
Thanks you.
  • SimpleWavetable_ver004.zip
In your Churchorgan_samples.h change this line:
#include <AudioSynthWavetable.h>
to this:
#include <synth_wavetable.h>
It still won't compile but it'll get further along.
Pete
can you post the compile error output
it can be because you are using a old version of Soundfontdecoder
By the way i did a compile myself
There is some reference errors.
As I also had problems the first time
and the problem is in the soundfontdecoder.
I had little time when I did the last post
there has been some changes to the synth_wavetable.h and the soundFontDecoder provided at PaulStoffregen:s github is not updated
I have attached the new version of soundFontDecoder which also includes new options for both teensy 4.0 and teensy 4.1
there is a nice library here (extracted from the GM by wrightflyer using a updated version of the soundFontDecoder)
https://github.com/wrightflyer/Synth/tree/master/src/GMinstrument
you can read this post by wrightflyer how to use them all
https://forum.pjrc.com/threads/65740-Audio-System-Design-Tool-update?p=266172&viewfull=1#post266172
or else if you want to you can change the header yourself (but that will only solve the problem for your current converted soundfont)
this is the right "header" this is just an example and you need to do the changes yourself to match
static const AudioSynthWavetable::sample_data MmmmHumSynth_samples[1] = {
		(int16_t*)sample_0_MmmmHumSynth_MMMMM, // sample
		true, // LOOP
		15, // LENGTH_BITS
		(1 << (32 - 15)) * WAVETABLE_CENTS_SHIFT(-73) * 44100.0 / WAVETABLE_NOTE_TO_FREQUENCY(72) / AUDIO_SAMPLE_RATE_EXACT + 0.5, // PER_HERTZ_PHASE_INCREMENT
		((uint32_t)21844 - 1) << (32 - 15), // MAX_PHASE
		((uint32_t)21843 - 1) << (32 - 15), // LOOP_PHASE_END
		(((uint32_t)21843 - 1) << (32 - 15)) - (((uint32_t)4817 - 1) << (32 - 15)), // LOOP_PHASE_LENGTH
		uint16_t(UINT16_MAX * WAVETABLE_DECIBEL_SHIFT(-0.0)), // INITIAL_ATTENUATION_SCALAR
		uint32_t(0.00 * AudioSynthWavetable::SAMPLES_PER_MSEC / AudioSynthWavetable::ENVELOPE_PERIOD + 0.5), // DELAY_COUNT
		uint32_t(1.00 * AudioSynthWavetable::SAMPLES_PER_MSEC / AudioSynthWavetable::ENVELOPE_PERIOD + 0.5), // ATTACK_COUNT
		uint32_t(0.98 * AudioSynthWavetable::SAMPLES_PER_MSEC / AudioSynthWavetable::ENVELOPE_PERIOD + 0.5), // HOLD_COUNT
		uint32_t(1.00 * AudioSynthWavetable::SAMPLES_PER_MSEC / AudioSynthWavetable::ENVELOPE_PERIOD + 0.5), // DECAY_COUNT
		uint32_t(2500.99 * AudioSynthWavetable::SAMPLES_PER_MSEC / AudioSynthWavetable::ENVELOPE_PERIOD + 0.5), // RELEASE_COUNT
		int32_t((1.0 - WAVETABLE_DECIBEL_SHIFT(-0.0)) * AudioSynthWavetable::UNITY_GAIN), // SUSTAIN_MULT
		uint32_t(0.00 * AudioSynthWavetable::SAMPLES_PER_MSEC / (2 * AudioSynthWavetable::LFO_PERIOD)), // VIBRATO_DELAY
		uint32_t(0.1 * AudioSynthWavetable::LFO_PERIOD * (UINT32_MAX / AUDIO_SAMPLE_RATE_EXACT)), // VIBRATO_INCREMENT
		(WAVETABLE_CENTS_SHIFT(0) - 1.0) * 4, // VIBRATO_PITCH_COEFFICIENT_INITIAL
		(1.0 - WAVETABLE_CENTS_SHIFT(0)) * 4, // VIBRATO_COEFFICIENT_SECONDARY
		uint32_t(0.00 * AudioSynthWavetable::SAMPLES_PER_MSEC / (2 * AudioSynthWavetable::LFO_PERIOD)), // MODULATION_DELAY
		uint32_t(5.4 * AudioSynthWavetable::LFO_PERIOD * (UINT32_MAX / AUDIO_SAMPLE_RATE_EXACT)), // MODULATION_INCREMENT
		(WAVETABLE_CENTS_SHIFT(0) - 1.0) * 4, // MODULATION_PITCH_COEFFICIENT_INITIAL
		(1.0 - WAVETABLE_CENTS_SHIFT(0)) * 4, // MODULATION_PITCH_COEFFICIENT_SECOND
		int32_t(UINT16_MAX * (WAVETABLE_DECIBEL_SHIFT(0) - 1.0)) * 4, // MODULATION_AMPLITUDE_INITIAL_GAIN
		int32_t(UINT16_MAX * (1.0 - WAVETABLE_DECIBEL_SHIFT(0))) * 4, // MODULATION_AMPLITUDE_FINAL_GAIN
this is the "header" from ChurchOrgan_samples.cpp which is incorrect
const sample_data ChurchOrgan_samples[1] = {
		(int16_t*)sample_0_ChurchOrgan_ChurchOrgC3,	//16-bit PCM encoded audio sample
		true,	//Whether or not to loop this sample
		12,	//Number of bits needed to hold length
		(1048576*0.9885140203528962*(44100.0 / AUDIO_SAMPLE_RATE_EXACT)) / 391.99543598174927 + 0.5,	//((0x80000000 >> (index_bits - 1)) * cents_offset * sampling_rate / AUDIO_SAME_RATE_EXACT) / sample_freq + 0.5
		((uint32_t)3966-1) << (32 - 12),	//(sample_length-1) << (32 - sample_length_bits)
		((uint32_t)3958-1) << (32 - 12),	//(loop_end-1) << (32 - sample_length_bits) == LOOP_PHASE_END
		(((uint32_t)3958-1) << (32 - 12)) - (((uint32_t)3736-1) << (32 - 12)),	//LOOP_PHASE_END - (loop_start-1) << (32 - sample_length_bits) == LOOP_PHASE_END - LOOP_PHASE_START == LOOP_PHASE_LENGTH
		uint16_t(UINT16_MAX * DECIBEL_SHIFT(-1500/100.0)), //INITIAL_ATTENUATION_SCALAR
		uint32_t(0*SAMPLES_PER_MSEC/8.0+0.5),	//DELAY_COUNT
		uint32_t(0*SAMPLES_PER_MSEC/8.0+0.5),	//ATTACK_COUNT
		uint32_t(0*SAMPLES_PER_MSEC/8.0+0.5),	//HOLD_COUNT
		uint32_t(0*SAMPLES_PER_MSEC/8.0+0.5),	//DECAY_COUNT
		uint32_t(654*SAMPLES_PER_MSEC/8.0+0.5),	//RELEASE_COUNT
		int32_t(0*UNITY_GAIN),	//SUSTAIN_MULT
		uint32_t(0 * SAMPLES_PER_MSEC / (2 * LFO_PERIOD)), 	// VIBRATO_DELAY
		uint32_t(672/1000.0 * LFO_PERIOD * (UINT32_MAX / AUDIO_SAMPLE_RATE_EXACT)), // VIBRATO_INCREMENT
		(CENTS_SHIFT(-0/1000.0) - 1.0)*4, // VIBRATO_PITCH_COEFFICIENT_INITIAL
		(1.0 - CENTS_SHIFT(0/1000.0))*4, // VIBRATO_COEFFICIENT_SECONDARY
		uint32_t(0 * SAMPLES_PER_MSEC / (2 * LFO_PERIOD)), // MODULATION_DELAY
		uint32_t(672/1000.0 * LFO_PERIOD * (UINT32_MAX / AUDIO_SAMPLE_RATE_EXACT)), // MODULATION_INCREMENT
		(CENTS_SHIFT(-0/1000.0) - 1.0)*4, // MODULATION_PITCH_COEFFICIENT_INITIAL
		(1.0 - CENTS_SHIFT(0/1000.0))*4, // MODULATION_PITCH_COEFFICIENT_SECOND
		int32_t(UINT16_MAX * (DECIBEL_SHIFT(-0.1) - 1.0)) *4, // MODULATION_AMPLITUDE_INITIAL_GAIN
		int32_t(UINT16_MAX * (1.0 - DECIBEL_SHIFT(0.1))) *4, // MODULATION_AMPLITUDE_FINAL_GAIN
  • SoundfontDecoder_updatedFiles.zip
a note about the attached SoundfontDecoder
it only contains the changed files and must be extracted in your current SoundfontDecoder folder
