Jacob.Schultz
It look like the SCB _ACTRL register is missing in the kinetic.h
Maybe not the most important one, but it should be there.
#define SCB_ACTRL (*(volatile uint32_t *)0xE000E008) // Auxiliary control register
Bits 31:10 Reserved
Bit 9 DISOOFP
Disables floating point instructions completing out of order with respect to integer instructions.
Bit 8 DISFPCA
Disables automatic update of CONTROL.FPCA.
The value of this bit should be written as zero or preserved (SBZP).
Bit 7:3 Reserved
Bit 2 DISFOLD
Disables folding of IT instructions:
0: Enables IT instructions folding.
1: Disables IT instructions folding.
In some situations, the processor can start executing the first instruction in an IT block while it
is still executing the IT instruction. This behavior is called IT folding, and improves
performance, However, IT folding can cause jitter in looping. If a task must avoid jitter, set the
DISFOLD bit to 1 before executing the task, to disable IT folding.
Bit 1 DISDEFWBUF
This bit only affects write buffers implemented in the Cortex-M4 processor.
Disables write buffer use during default memory map accesses: This causes all BusFaults to
be precise BusFaults but decreases performance because any store to memory must
complete before the processor can execute the next instruction.
0: Enable write buffer use
1: Disable write buffer use: Stores to memory is completed before next instruction.
Bit 0 DISMCYCINT
Disables interrupt of multi-cycle instructions. When set to 1, disables interruption of load
multiple and store multiple instructions. This increases the interrupt latency of the processor
because any LDM or STM must complete before the processor can stack the current state and
enter the interrupt handler.
0: Enable interruption latency of the processor (load/store and multiply/divide operations).
1: Disable interruptions latency.
