What is the max output frequency of analog ouput Teensy3.1?
Hi all,
I searched for informations to known how I can generate 10Mhz to 15Mhz sinus signal on analog output (that it will be use to control a NE612 mixer).
It's possible with Teensy 3.1 ?
It's depend of the setup in makefile (from fresh generated project with avr-project cmd line ):
line 21 of Makefile: -> CLOCK = 8000000 must be set to 75000000 ????
Teensy 3.1 must be over-clocked ?
It seem that the nominal frequency of Teensy 3.1 is 72Mhz ( https://www.pjrc.com/teensy/teensy31.html#specs )
Thank you in advance. Bruno
