Combining FastLED and Other Functionality Simulataneously; Animatronics
Teensy 3.5. Custom PCB (not audio shield). I am an EE Tech I make my own shields.
OK! The source code below works! My animatronic skull model turns on when I trigger the sensor and the jaw servo maps to the audio output!
So now I need to integrate some FastLED into the action. How is this done without multi-threading? I am still teaching myself about timing loops and Arduino here so bear with me (or better yet fill me in).
Thank you!!
Source Code:
#include <PWMServo.h>
// Configuration
// Connections
#define SERVO_PIN 10 // Jaw servo
#define PING_PIN 5 // ping / echo for sonar distance sensor
#define ECHO_PIN 6
#define MOSFETPin 9 // mostfet for servo power control
// How long until the ping returns to consider it a "trigger"
#define SONAR_THRESHOLD 900 // microseconds.
// Speed of sound in air is about 343 m/s, so this is about 15 cm (~6 in), or a 30cm round trip.
// Quick calculators:
// const SONAR_THRESHOLD (148 * 6) // ~inches
// const SONAR_THRESHOLD (58 * 15) // ~cm
// Servo range configuration
#define JAW_OPEN 70
#define JAW_CLOSED 0
// Length of time for `loop()` to run. 1000/25 Hz (40ms) should be pretty fluid
#define SAMPLE_TIME 200 // ms
// Sound file to play when sonar triggers
#define SAMPLE_FILE "01.wav"
// Delay playback to compensate for the jaw servo's lag.
#define SERVO_DELAY 50 // ms
// To play with this, import the below block into https://www.pjrc.com/teensy/gui/
// playSdWav1 will use the built-in sd card slot, assumed to have a fat32 filesystem.
// If you're using some other way to attach SD, or you'd like to use in-memory or
// whatever, there are other options.
AudioPlaySdWav playSdWav1; //xy=329,371
AudioMixer4 mixer1; //xy=548,386
AudioEffectDelay delay1; //xy=749,424
AudioOutputAnalog dac1; //xy=951,421
AudioAnalyzePeak peak1; //xy=973,360
AudioConnection patchCord1(playSdWav1, 0, mixer1, 0);
AudioConnection patchCord2(playSdWav1, 1, mixer1, 1);
AudioConnection patchCord3(mixer1, delay1);
AudioConnection patchCord4(delay1, 0, peak1, 0);
AudioConnection patchCord5(delay1, 1, dac1, 0);
#define SDCARD_CS_PIN BUILTIN_SDCARD
#define SDCARD_MOSI_PIN 11 // not actually used
#define SDCARD_SCK_PIN 13
PWMServo jaw;
// Entirely optional. For stable sample management. `elapsedMillis` is a teensy type that
// automatically counts up, so it's useful for making sure if you want 25Hz, you _get_ 25Hz.
elapsedMillis timing;
int ping() {
digitalWrite(PING_PIN, LOW);
delayMicroseconds(2);
digitalWrite(PING_PIN, HIGH);
delayMicroseconds(10);
if (pulseIn(ECHO_PIN, HIGH, SONAR_THRESHOLD) != 0) {
return HIGH;
return LOW;
uint8_t mosfet_state = LOW;
void set_mosfet(uint8_t state) {
if (state != mosfet_state) {
Serial.print("Setting MOSFET to ");
Serial.println(state == LOW ? "LOW" : "HIGH");
mosfet_state = state;
digitalWrite(MOSFETPin, mosfet_state);
Serial.println("initializing audio memory");
// Set up audio memory. You need at least 1 block for each 2.9 ms of delay, plus
// a minimum of 8 blocks for the player.
AudioMemory((int) (ceil(SERVO_DELAY / 2.9) + 8));
Serial.println("initializing pins");
jaw.attach(SERVO_PIN);
pinMode(PING_PIN, OUTPUT);
pinMode(ECHO_PIN, INPUT);
pinMode(MOSFETPin, OUTPUT);
delay1.delay(0, 0);
delay1.delay(1, SERVO_DELAY);
delay1.disable(2);
delay1.disable(3);
delay1.disable(4);
delay1.disable(5);
delay1.disable(6);
delay1.disable(7);
mixer1.gain(0, 1.0);
mixer1.gain(1, 1.0);
mixer1.gain(2, 0);
mixer1.gain(3, 0);
Serial.println("initializing SD access");
SPI.setMOSI(SDCARD_MOSI_PIN);
SPI.setSCK(SDCARD_SCK_PIN);
// stop here, but print a message repetitively
while (1) {
Serial.println(SD.begin(SDCARD_CS_PIN));
void loop_state_waiting() {
if (mosfet_state == HIGH) {
Serial.println("playback ended; returning to sleep.");
set_mosfet(LOW);
if (ping() == HIGH) {
Serial.println("sonar ping! Starting sound/animation.");
set_mosfet(HIGH);
playSdWav1.play(SAMPLE_FILE);
delay(5);
void loop_state_playing() {
if (peak1.available()) {
float level = peak1.readPeakToPeak();
int new_servo_pos = (int) (level * (JAW_OPEN - JAW_CLOSED) / 2.0 + JAW_CLOSED);
Serial.print("Level: ");
Serial.print(level);
Serial.print("; servo: ");
Serial.println(new_servo_pos);
jaw.write(new_servo_pos);
// resets the counter
timing = 0;
if (!playSdWav1.isPlaying()) {
loop_state_waiting();
loop_state_playing();
// Only delay for the remaining time in the sample.
delay(SAMPLE_TIME - timing);
Want to include:
//Skull Eyes
#define FRAMES_PER_SECOND 8
#include <FastLED.h>
bool gReverseDirection = false;
#define NUM_LEDS_PER_STRIP 10
CRGB leds[NUM_LEDS_PER_STRIP];
// For mirroring strips, all the "special" stuff happens just in setup. We
// just addLeds multiple times, once for each strip
// tell FastLED there's 60 NEOPIXEL leds on pin 4
FastLED.addLeds<NEOPIXEL, 2>(leds, NUM_LEDS_PER_STRIP);
// tell FastLED there's 60 NEOPIXEL leds on pin 5
FastLED.addLeds<NEOPIXEL, 3>(leds, NUM_LEDS_PER_STRIP);
// Add entropy to random number generator; we use a lot of it.
// random16_add_entropy( random());
Fire2012(); // run simulation frame
FastLED.show(); // display this frame
FastLED.delay(1000 / FRAMES_PER_SECOND);
#define COOLING 55
// SPARKING: What chance (out of 255) is there that a new spark will be lit?
// Higher chance = more roaring fire. Lower chance = more flickery fire.
// Default 120, suggested range 50-200.
#define SPARKING 120
void Fire2012()
// Array of temperature readings at each simulation cell
static byte heat[NUM_LEDS_PER_STRIP];
// Step 1. Cool down every cell a little
for( int i = 0; i < NUM_LEDS_PER_STRIP; i++) {
heat[i] = qsub8( heat[i], random8(0, ((COOLING * 10) / NUM_LEDS_PER_STRIP) + 2));
// Step 2. Heat from each cell drifts 'up' and diffuses a little
for( int k= NUM_LEDS_PER_STRIP - 1; k >= 2; k--) {
heat[k] = (heat[k - 1] + heat[k - 2] + heat[k - 2] ) / 3;
// Step 3. Randomly ignite new 'sparks' of heat near the bottom
if( random8() < SPARKING ) {
int y = random8(7);
heat[y] = qadd8( heat[y], random8(160,255) );
// Step 4. Map from heat cells to LED colors
for( int j = 0; j < NUM_LEDS_PER_STRIP; j++) {
CRGB color = HeatColor( heat[j]);
int pixelnumber;
if( gReverseDirection ) {
pixelnumber = (NUM_LEDS_PER_STRIP-1) - j;
pixelnumber = j;
leds[pixelnumber] = color;
