Good afternoon - The Adafruit display should work with previously defined tab color: tft.initR(INITR_MINI160x80);
I don't believe theirs is an S... Could be wrong. But fingers crossed should be the same as before... I thought I had one around here, earlier, but don't see it right now, new one should arrive with my Mouser order.
Good Evening
Yep you are right the Adafruit display works fine with the tft.initR(INITR_MINI160x80); initialization
What is curious about the display is the datasheet for the display shows a ST7735S? (https://learn.adafruit.com/adafruit-...kout/downloads)
Good Evening,
Maybe it also is an S display, but they definitely configured it differently. So will keep fingers crossed that most of them follow one or the other...
EDIT: Tomorrow or so the new Adafruit display 160x80 will arrive. So of course the one I thought I already had... I just found :o And looks like it works, the same as yours.
So looks like I should organize some of my junk! It was buried in my sensors box and not in the displays box. Probably should organize this a lot more!
To update the issues that I originally posted about....in case someone is coming across this thread...
Regarding a .96 80X160 screen like this one https://www.banggood.com/Geekcreit-0...r_warehouse=CN (I mention this because different screens are used in the thread).
Using ST7735_t3 that can be installed using Teensyduino 1.53 and choosing: tft.initR(INITR_MINI160x80_ST7735S); the issues that I mentioned in my OP are fixed. That option was not available before and results in a modified command set in ST7735_t3. I did not test everything outside of the issues mentioned.
Even the colors do not need to be #defined as inversion is correctly set. I note that CASET and RASET are set to slightly different values that I had kludged, but they seem to work fine suggesting that I don't completely understand CASET and RASET :)
Good Deal!
