INPUT, pinMode not declared Compiler Error with #ifdef and Classes
mcivan
I am trying to learn/implement classes in my program, however I have hit a strange compiler error that I can't solve. Some how there references to the Teensyduino libraries are getting broken. However this only happens in one case.
I am not confident in my implementation, and use of static, however I can't find any error between the two implementations. One compiles, and one gives weird errors. Any help or suggestions welcome! :)
Arduino 1.0.6
Teensyduino 1.20 (downloaded and installed today)
The code should compile on copy/paste, but swap the commented //#define and the second should fail stating OUTPUT undefined, and highlighting the wrong line.
#define ZARL_01  //Set my hardware version to 01
//#define ZARL_00    //Set my hardware version to 01
#include "math.h"
#ifdef ZARL_01
class PINS{
public:
  static const int Qo_Leds = 12;
  static const int PwmRes = 16;
  static const int PwmMaxValue = pow( 2, PwmRes) -1;
  int Led[2][Qo_Leds] = {
      25, 32, 3, 4, 5, 9, 21, 22, 6, 10, 20, 23                         }
    , // RGBW, 1-8 spots addressed clockwise starting at 4 o'clock
    }                                                 // Second row to hold set values
  const int Red   = Led[0][0];
  const int Green = Led[0][1];
  const int Blue  = Led[0][2];
  const int White = Led[0][3];
  const int Touch[3][5] = {
      0, 1, 16, 17, 33
    ,                        // 5 touch pins; touch pin calibration; last reading
  const int TeensyLed = 13;
  const int vibe = A14;
  const int audio = 15;
  const int light = 14;
  const int SysVoltage = A13;
  const int BattPowerGood = 11;
  const int BattStatOne = 7;
  const int BattStatTwo = 8;
  const int MpuInterrupt = 2;
  void Config() {
    for ( int i = 0; i < Qo_Leds; ++i ) pinMode( Led[0][i], OUTPUT );
    for ( int i = 0; i < 5; ++i ) pinMode( Touch[0][i], INPUT );
    pinMode( TeensyLed, OUTPUT );
    pinMode( vibe, OUTPUT );
    pinMode( audio, INPUT );
    pinMode( light, INPUT );
    pinMode( SysVoltage, INPUT );
    pinMode( BattPowerGood, INPUT );
    pinMode( BattStatOne, INPUT );
    pinMode( BattStatTwo, INPUT );
    pinMode( MpuInterrupt, INPUT );
#ifdef ZARL_00
class PINS {
public:
  static const int Qo_Leds = 4;
  static const int PwmMaxValue = (pow( 2, PwmRes) -1);
      3, 4, 5, 6
    }                                           // Second row to hold values
  static const int audio = 23;
  static const int light = 22;
  static const int MpuInterrupt = 14;
  static const int TeensyLed = 13;
  void Config() {   //Comment out the next 5 lines, and the code will compile
PINS pin;
  pin.Config();
Alright, restarted with a simplified approach. Was compiling frequently, then hit the same problem, but I was able to take a few steps back and saw I had accidentally nested #ifdef statements. I saw this trick online, but I didn't consider that I had an #ifdef in the code I was to mark as old!
Apparently #ifdef cannot be nested! *shrugs* :roll eyes:
ATTACH=CONFIG]2791[/ATTACH]
//#ifdef OLD
//// TEST PIN OUTS
//void pinTest() {
//  for ( int i = 0; i < Qo_LEDS; ++i) {
//    digitalWrite( LED[i], HIGH );
//    delay(200);
//  digitalWrite ( POWER_LED, HIGH );
//#ifdef ZARL_01 analogWrite ( VIBE_MOTOR, 1023);
//  delay(500);
//  analogWrite( VIBE_MOTOR, 0 );
//#endif
//  digitalWrite ( POWER_LED, LOW );
//  for ( int i = 0; i < Qo_LEDS; ++i) digitalWrite( LED[i], LOW );
//#endif
Note, you have the wrong syntax for the second #ifdef.
The #ifdef can only be followed by a single identifer, i.e.:
#ifdef ZARL_01
Since the IDE, decides to hide some error messages (particularly include file not found), perhaps it is deleting the error message that the compiler gives that the #ifdef is mal-formed. So, the first #endif winds up closing the first #ifdef, instead of the second, and the second #endif is also an error.
Thanks for the clarification!
I went back and played with this... and strangely the error is completely gone, regardless of the syntax mentioned above.
... I'll be proceeding with caution.
The #ifdef isn't very clean in my implementation, but it is convenient to have one piece of software work on two different hardware iterations of the same project!
