One Wire library for SAMD21
wildernessbagel
New member
Hello, I'm trying to make to use https://github.com/PaulStoffregen/OneWire this library with ATSAMD21G18A, I found the following definitions inside the OneWire_direct_gpio.h file.
#elif defined(__SAMD21G18A__)
#define PIN_TO_BASEREG(pin)             portModeRegister(digitalPinToPort(pin))
#define PIN_TO_BITMASK(pin)             (digitalPinToBitMask(pin))
#define IO_REG_TYPE uint32_t
#define IO_REG_BASE_ATTR
#define IO_REG_MASK_ATTR
#define DIRECT_READ(base, mask)         (((*((base)+8)) & (mask)) ? 1 : 0)
#define DIRECT_MODE_INPUT(base, mask)   ((*((base)+1)) = (mask))
#define DIRECT_MODE_OUTPUT(base, mask)  ((*((base)+2)) = (mask))
#define DIRECT_WRITE_LOW(base, mask)    ((*((base)+5)) = (mask))
#define DIRECT_WRITE_HIGH(base, mask)   ((*((base)+6)) = (mask))
However I can't find what portModeRegister(digitalPinToPort(pin)) and (digitalPinToBitMask(pin)) are defined as, any tips on where to look and how to use One Wire with samd21?
Thanks I found them but the code is still not working. I changed this original code
void OneWire::begin(uint8_t pin)
	pinMode(pin, INPUT);
	bitmask = PIN_TO_BITMASK(pin);
	baseReg = PIN_TO_BASEREG(pin);
#if ONEWIRE_SEARCH
	reset_search();
to
#define digitalPinToPort(P)      (&(PORT->Group[0]))
#define digitalPinToBitMask(P)   (1 << 8)
//#define analogInPinToBit(P)    ()
#define portOutputRegister(port) (&(port->OUT.reg))
#define portInputRegister(port)  (&(port->IN.reg))
#define portModeRegister(port)   (&(port->DIR.reg))
#define pgm_read_byte(addr) (*(const uint8_t *)(addr))
	PORT->Group[0].DIRCLR.reg = (1 << pin);									// set pin as input
So I hardcoded #define digitalPinToPort(P) (&(PORT->Group[0])) and #define digitalPinToBitMask(P) (1 << 8) to pin 8 since that's the data pin I am using, I'll try to make it more modular however I just want to get it working first.
#define digitalPinToPort(P)      (&(PORT->Group[g_APinDescription[P].ulPort]))
#define digitalPinToBitMask(P)   (1 << g_APinDescription[P].ulPin)
this were the original definitions. Did I make any mistakes?
