I am curious if anyone knows if or how I could use a Teensy 4.1 to to play the WAV files on the SD card of an audio shield that is connected to a separate Teensy 4.0.
From reading other posts on here, my impression is that setting the Teensy to slave mode is difficult to do or does not working well. I am hoping that offloading this playback to a separate device will solve the problems I experienced in an earlier post I made (https://forum.pjrc.com/threads/6398...ev-D-play-wav-files-and-record-simultaneously). For my idea to work, I would need the audio to be played from the Teensy 4.1 and output back to the audio shield for recording. I know there is a DAC on the T4.1.
Any thoughts on whether this could solve my recording/playback issues that I outlined originally, or of this is feasible with two Teensy devices?
Any advice is appreciated, thank you!!
