#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <stdarg.h>
#include <sys/types.h>
#include <sys/stat.h>
#include <sys/time.h>
#include <fcntl.h>
#include <unistd.h>
#include <errno.h>
// One of these must be defined, usually via the Makefile
//#define MACOSX
//#define LINUX
#define WINDOWS
#if defined(MACOSX) || defined(LINUX)
#include <termios.h>
#include <sys/select.h>
#define PORTTYPE int
#define BAUD B115200
#if defined(LINUX)
#include <sys/ioctl.h>
#include <linux/serial.h>
#elif defined(WINDOWS)
#include <windows.h>
#define PORTTYPE HANDLE
#define BAUD 115200
#define gettimeofday gettimeofday_
#else
#error "You must define the operating system\n"
// function prototypes
PORTTYPE open_port_and_set_baud_or_die(const char *name, long baud);
void close_port(PORTTYPE port);
int receive_bytes_X(PORTTYPE port, int cnt);
void delay(double sec);
void die(const char *format, ...) __attribute__ ((format (printf, 1, 2)));
int gettimeofday(struct timeval * tp, struct timezone * tzp);
int count=0;
char buf[65537];
int len;
len = sizeof(buf)-1;
int r;
int retry=0;
// non-blocking read mode
fcntl(port, F_SETFL, fcntl(port, F_GETFL) | O_NONBLOCK);
while (count < len) {
r = read(port, buf + count, len - count);
//printf("read, r = %d\n", r);
if (r < 0 && errno != EAGAIN && errno != EINTR) return -1;
else if (r > 0) count += r;
else {
// no data available right now, must wait
fd_set fds;
struct timeval t;
FD_ZERO(&fds);
FD_SET(port, &fds);
t.tv_sec = 1;
t.tv_usec = 0;
r = select(port+1, &fds, NULL, NULL, &t);
//printf("select, r = %d\n", r);
if (r < 0) return -1;
if (r == 0) return count; // timeout
retry++;
if (retry > 1000) return -100; // no input
fcntl(port, F_SETFL, fcntl(port, F_GETFL) & ~O_NONBLOCK);
COMMTIMEOUTS timeout;
DWORD n;
BOOL r;
int waiting=0;
GetCommTimeouts(port, &timeout);
timeout.ReadIntervalTimeout = MAXDWORD; // non-blocking
timeout.ReadTotalTimeoutMultiplier = 0;
timeout.ReadTotalTimeoutConstant = 0;
SetCommTimeouts(port, &timeout);
for ( int ii=0; ii<cnt; ii++ ) {
count = 0;
r = ReadFile(port, buf + count, len - count, &n, NULL);
if (!r) die("read error\n");
if (n > 0) count += n;
else {
if (waiting) break; // 1 sec timeout
timeout.ReadTotalTimeoutMultiplier = MAXDWORD;
timeout.ReadTotalTimeoutConstant = 1000;
waiting = 1;
buf[80]=0;
if ( !(ii%8) || (ii>cnt-8) ) printf( "\n #%d : \n>>%s<<", ii, buf );
return count;
int main(int argc, char **argv)
PORTTYPE fd;
int blkcnt = 200;
if (argc < 2) die("Usage: :) latency_test3 <comport>\n");
fd = open_port_and_set_baud_or_die(argv[1], BAUD);
// if (argc > 2 && argv[2][0] >'0' && argv[2][0] <= '9' ) loopNum = argv[2][0] - '0';
// if (argc > 3 && argv[3][0] >'0' && argv[3][0] <= '9' ) numLengths = ( numLengths / (argv[3][0] - '0'));
printf("port %s opened\n", argv[1]);
struct timeval begin, end;
double elapsed;
int totBytes;
int r;
// test begin
gettimeofday(&begin, NULL);
r = receive_bytes_X( fd, blkcnt );
gettimeofday(&end, NULL);
elapsed = (double)(end.tv_sec - begin.tv_sec) * 1000.0;
elapsed += (double)(end.tv_usec - begin.tv_usec) / 1000.0;
printf(" ------\t elapsed time %.3f secs for %d bytes\n", elapsed/1000.0, blkcnt*8096 );
close_port(fd);
return 0;
/* Serial Port Functions */
PORTTYPE fd;
#if defined(MACOSX)
struct termios tinfo;
fd = open(name, O_RDWR | O_NONBLOCK);
if (fd < 0) die("unable to open port %s\n", name);
if (tcgetattr(fd, &tinfo) < 0) die("unable to get serial parms\n");
if (cfsetspeed(&tinfo, baud) < 0) die("error in cfsetspeed\n");
tinfo.c_cflag |= CLOCAL;
if (tcsetattr(fd, TCSANOW, &tinfo) < 0) die("unable to set baud rate\n");
fcntl(fd, F_SETFL, fcntl(fd, F_GETFL) & ~O_NONBLOCK);
#elif defined(LINUX)
struct serial_struct kernel_serial_settings;
int r;
fd = open(name, O_RDWR);
r = ioctl(fd, TIOCGSERIAL, &kernel_serial_settings);
if (r >= 0) {
kernel_serial_settings.flags |= ASYNC_LOW_LATENCY;
r = ioctl(fd, TIOCSSERIAL, &kernel_serial_settings);
if (r >= 0) printf("set linux low latency mode\n");
COMMCONFIG cfg;
DWORD n;
char portname[256];
int num;
if (sscanf(name, "COM%d", &num) == 1) {
sprintf(portname, "\\\\.\\COM%d", num); // Microsoft KB115831
strncpy(portname, name, sizeof(portname)-1);
portname[n-1] = 0;
fd = CreateFile(portname, GENERIC_READ | GENERIC_WRITE,
0, 0, OPEN_EXISTING, 0, NULL);
if (fd == INVALID_HANDLE_VALUE) die("unable to open port %s\n", name);
GetCommConfig(fd, &cfg, &n);
//cfg.dcb.BaudRate = baud;
cfg.dcb.BaudRate = 115200;
cfg.dcb.fBinary = TRUE;
cfg.dcb.fParity = FALSE;
cfg.dcb.fOutxCtsFlow = FALSE;
cfg.dcb.fOutxDsrFlow = FALSE;
cfg.dcb.fOutX = FALSE;
cfg.dcb.fInX = FALSE;
cfg.dcb.fErrorChar = FALSE;
cfg.dcb.fNull = FALSE;
cfg.dcb.fRtsControl = RTS_CONTROL_ENABLE;
cfg.dcb.fAbortOnError = FALSE;
cfg.dcb.ByteSize = 8;
cfg.dcb.Parity = NOPARITY;
cfg.dcb.StopBits = ONESTOPBIT;
cfg.dcb.fDtrControl = DTR_CONTROL_ENABLE;
SetCommConfig(fd, &cfg, n);
GetCommTimeouts(fd, &timeout);
timeout.ReadIntervalTimeout = 0;
timeout.WriteTotalTimeoutConstant = 0;
timeout.WriteTotalTimeoutMultiplier = 0;
SetCommTimeouts(fd, &timeout);
return fd;
close(port);
CloseHandle(port);
/* Misc. Functions */
usleep(sec * 1000000);
Sleep(sec * 1000);
va_list args;
va_start(args, format);
vfprintf(stderr, format, args);
exit(1);
#if defined(WINDOWS)
static const unsigned __int64 epoch = ((unsigned __int64) 116444736000000000ULL);
int
gettimeofday_(struct timeval * tp, struct timezone * tzp)
FILETIME file_time;
SYSTEMTIME system_time;
ULARGE_INTEGER ularge;
GetSystemTime(&system_time);
SystemTimeToFileTime(&system_time, &file_time);
ularge.LowPart = file_time.dwLowDateTime;
ularge.HighPart = file_time.dwHighDateTime;
tp->tv_sec = (long) ((ularge.QuadPart - epoch) / 10000000L);
tp->tv_usec = (long) (system_time.wMilliseconds * 1000);
return 0;
