PT8211 has a DC DAC
manatee
Hello!
I'm trying to use the PT8211 has a DC DAC with relative success, but my limited coding knowledge is getting me nowhere...
I know the PT8211 is not the best DAC for this application but is understanding is that since the PT8211 is an R-2R ladder DAC this project should be doable for non precision applications, like LFOs etc.
I've tried to modify this code: https://gist.github.com/dilshan/9044b895dcc8aa05d9df0cac1e928f8e
So far i've simply modified the void loop to do a simple Potentiometer follower. But has is, i've stumbled in to some problems:
- i'm having problems to scale the pot value to the full resolution of the DAC, seems like the dac is bias at half the voltage reference and i can only write to one half or the other.
(if i do: int val = map(pot, 0, 4096, 0, 65536); it writes to the top half of the DAC
if i do: int val = map(pot, 0, 4096, 65536, 0); it writes to the bottom half of the DAC)
-can't understand how to select and write to individual DAC channels, the pot value is always updated to both DACs.
Other than this, seems like it works smoothly as a DC DAC and could be a nice/cheap alternative for the more expensive DACs.
What would be needed to modify in order to use it as a simple DC DAC?
Here is where i am so far:
//#include <limits.h>
#ifndef PIN_BCK
#define PIN_BCK   21
#ifndef PIN_WS
#define PIN_WS    20
#ifndef PIN_DIN
#define PIN_DIN   7
#define NOP __asm__ __volatile__ ("nop\n\t")
void writeDACChannel(short waveData)
  unsigned char pos = 16;
  // Send data into PT8211 in least significant bit justified (LSBJ) format.
  while(pos > 0)
    pos--;
    digitalWrite(PIN_BCK, LOW);
    // Write next bit in stream into DIN.
    digitalWrite(PIN_DIN, (waveData & (1 << pos)) ? HIGH : LOW);
    NOP;
    // Toggle BCK.
    digitalWrite(PIN_BCK, HIGH);
    NOP;
void writeDAC(short waveData)
  digitalWrite(PIN_WS, LOW);
  // Write data into right channel of DAC.
  writeDACChannel(waveData);
  digitalWrite(PIN_WS, HIGH);
  // Write data into left channel of DAC.
  pinMode(PIN_BCK, OUTPUT);
  pinMode(PIN_WS, OUTPUT);
  pinMode(PIN_DIN, OUTPUT);
  analogWriteResolution(12);
    int pot = analogRead(A0);
    writeDAC(val);
Thanks in advance!
Thanks Paul!
oh, silly me...that fixed the scaling problem :)
Any simple solution to select channels and write different values to them?
Maybe just write different values, sorta like this?
void writeDAC(short waveData1, short waveData2)
  writeDACChannel(waveData1);
  writeDACChannel(waveData2);
