I have read the thread from 2012 about building for and uploading to Teensy from RaspberryPi: https://forum.pjrc.com/threads/3654-Teensy-loader-for-Raspberry-Pi/page2. I assume it is still not possible to just set up the Teensyduino IDE on a Raspberry. If I read correctly it should be possible to build on a normal linux machine and then use the RaspberryPi version of the teensy loader to upload the built machine code. Am I right about that?
Could someone please explain how to do this? Perhaps using the Blink.ino as an example.
Fx I have not found where my laptop puts the hex files mentioned in the threads. Preferably I would like to run the teensy loader via ssh, so I won't need to set up a VNC server on the RaspberryPi. Is that possible?
Sincerely
Sincerely
