cfredisded
Hey all,
Really been enjoying learning 'programming' with the teensy 3.2 + audio board, and I cant wait for some type of real time audio pitch shifting (which I've read is at least on a todo list for the audio library).
I managed to scrounge some code together from examples that tracks the pitch and amplitude of the incoming signal and creates a sine wave that follows. Please excuse the messy state that the code is in... I've comment out a lot of failed attempts at adding different things, rather then deleting them. I'm wondering if i could get some help adding a glissando type of effect to the sine output. So that if the pitch change between the last tracked note and the current tracked note is greater then `5 or so, the sine wave will change at a controlled rate from the previous note to the new note..... if that makes sense... Here's the messy code and appreciate any insight.
Also if anyone wants to play with the code.. you can get a wacky effect by changing
sine_fm1.frequency(note1);
to
sine_fm1.frequency(note1+arp);
Cheers,
* A simple hardware test which receives audio from the audio shield
* Line-In pins and send it to the Line-Out pins and headphone jack.
* This example code is in the public domain.
C C# D Eb E F F# G G# A Bb B
0 16.35 17.32 18.35 19.45 20.60 21.83 23.12 24.50 25.96 27.50 29.14 30.87
1 32.70 34.65 36.71 38.89 41.20 43.65 46.25 49.00 51.91 55.00 58.27 61.74
2 65.41 69.30 73.42 77.78 82.41 87.31 92.50 98.00 103.8 110.0 116.5 123.5
3 130.8 138.6 146.8 155.6 164.8 174.6 185.0 196.0 207.7 220.0 233.1 246.9
4 261.6 277.2 293.7 311.1 329.6 349.2 370.0 392.0 415.3 440.0 466.2 493.9
5 523.3 554.4 587.3 622.3 659.3 698.5 740.0 784.0 830.6 880.0 932.3 987.8
6 1047 1109 1175 1245 1319 1397 1480 1568 1661 1760 1865 1976
7 2093 2217 2349 2489 2637 2794 2960 3136 3322 3520 3729 3951
8 4186 4435 4699 4978 5274 5588 5920 6272 6645 7040 7459 7902
Guitar strings are E2=82.41Hz, A2=110Hz, D3=146.8Hz, G3=196Hz, B3=246.9Hz, E4=329.6Hz
Bass strings are (5th string) B0=30.87Hz, (4th string) E1=41.20Hz, A1=55Hz, D2=73.42Hz, G2=98Hz
This example tests the yin algorithm with actual notes from nylon string guitar recorded
as wav format at 16B @ 44100 samples/sec. Since the decay of the notes will be longer than what
the teensy can store in flash these notes are truncated to ~120,000B or about 1/2 of the whole
signal.
#include <SerialFlash.h>
AudioInputI2S i2s1; //xy=311,268
AudioAnalyzeNoteFrequency notefreq1; //xy=427,457
AudioAnalyzeRMS rms1; //xy=442,409
AudioSynthWaveformSineModulated sine_fm1; //xy=507,315
AudioMixer4 mixer1; //xy=698,285
AudioOutputI2S i2s2; //xy=923,279
AudioConnection patchCord1(i2s1, 0, sine_fm1, 0);
AudioConnection patchCord2(i2s1, 0, notefreq1, 0);
AudioConnection patchCord3(i2s1, 0, mixer1, 0);
AudioConnection patchCord4(i2s1, 0, rms1, 0);
AudioConnection patchCord5(sine_fm1, 0, mixer1, 1);
AudioConnection patchCord6(mixer1, 0, i2s2, 0);
AudioConnection patchCord7(mixer1, 0, i2s2, 1);
AudioControlSGTL5000 sgtl5000_1; //xy=240,67
const int myInput = AUDIO_INPUT_LINEIN; //const int myInput = AUDIO_INPUT_MIC;
float note1;
float note2;
int amp;
int amp1;
int a1history=0;
int arp;
float ampprint;
//int arpamount
///int sinfreq = note;
///int sinamp = .8;
// Audio connections require memory to work. For more
AudioMemory(30);
notefreq1.begin(.10);
sgtl5000_1.enable();
sgtl5000_1.volume(0.5);
//Set sinwave freq and amp variables
//sine_fm1.amplitude(amp);
// sine_fm1.frequency(note);
//set mix gain
mixer1.gain(0, 0.0);
mixer1.gain(1, 0.8);
//arp == 0;
//a1history = analogRead(A1);
//elapsedMillis volmsec=0;
//void loop() {
// every 50 ms, adjust the volume
/// if (volmsec > 50) {
///float vol = analogRead(15);
/// vol = vol / 1023.0;
//audioShield.volume(vol); // <-- uncomment if you have the optional
/// volmsec = 0; // volume pot on your audio shield
//if (peak1.available()) {
// float amp = peak1.read();
// sine1.amplitude(amp);
elapsedMillis fps;
//waits 25 mils to read peak
// for (arp = 0; arp < 100; arp++) {
// for (arp = 100; arp > 0; arp--) {
//int arp = analogRead(A1);
arp++;
//arpamount = arpamount + arp'
// if(arp >= 1000) ;
// float arp = arp-- ;
if(fps > 25) {
while (rms1.available()) {
fps=0;
float amp = rms1.read()*10 ; ///amp int equals peak1 times 10
//Serial.printf("amplitude: %f", amp);
// Serial.println(amp);
if (notefreq1.available()) {
float note1 = notefreq1.read();
float prob = notefreq1.probability();
int a1 = analogRead(A1);
// if (note1<note2){
// note1++;
// sine_fm1.frequency(note1);
// float note2 = notefreq1.read();
// if (note1>note2){
// note1--;
// float note1 = notefreq1.read();
Serial.printf("Note: %3.2f | Probability: %.2f\n", note1, prob);
Serial.print("Knob (pin A1) = ");
Serial.println(a1);
Serial.print("note1 = ");
Serial.println(note1);
Serial.print("arp value = ");
Serial.println(arp);
// Serial.printf("amplitude: %f", amp);
//note1=note2;
if(arp>1000) {
arp=0;}
to
Cheers,
