defragster
Senior Member+
@defragster: Now that you have a microphone, and if you also have time, could you see if you have the same problems with the microphone that I reported in
msg #936 Re: microphone problem:
https://forum.pjrc.com/threads/34808-K66-Beta-est?p=110919&viewfull=1#post110919
and msg #955 about processor speeds:
https://forum.pjrc.com/threads/34808-K66-Beta-Test?p=110959&viewfull=1#post110959
Pete
Pete:
Finally sitting here ( fighting my intermittent web connect ) - pasted the first code example from #936 and indeed no sound from mic [at 240 or 96 MHz]. Why does the BuiltinLED flicker - is from i2s with the analog mic on the Audio board? My mic did work on the VoCoder sample?
MichealM had this post noticing seeming lack of analog changes - does the Audio card use the onboard DAC's or any related things for the mic to work>
if only the Audio board came with a Teensy like card - such details might be there.
Whatever happened with 'too large in flash' - for me it worked those few times - then I may have changed the code enough to shuffle stuff - almost like it wasn't clearing all the flash before uploading?
KurtE: (life and) internet too flakey to get to github for your serial # fix - what it seems you did is what I expected would be needed in my earlier note to Paul. Does that mean that EEPROM cannot be read or written in HSRUN? I thought that was how I RTFM. I made a sketch but haven't tried it recently.
