Arduino:1.8.5 (Windows 7), TD: 1.42-beta3, Kort:"Teensy 3.6, Serial, 240 MHz (overclock), Faster, Swedish"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=142 -DARDUINO=10805 -DF_CPU=240000000 -DUSB_SERIAL -DLAYOUT_SWEDISH "@C:\Users\user1\AppData\Local\Temp\arduino_build_589447/sketch/defs.h" "-IC:\Users\user1\AppData\Local\Temp\arduino_build_589447/pch" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files (x86)\Arduino\libraries\Teensy64" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\USBHost_t36" "-IC:\Program Files (x86)\Arduino\libraries\SdFat-master\src" "-IC:\Program Files (x86)\Arduino\libraries\Teensy-reSID-master" "C:\Program Files (x86)\Arduino\libraries\Teensy64\cpu.cpp" -o "C:\Users\user1\AppData\Local\Temp\arduino_build_589447\libraries\Teensy64\cpu.cpp.o"
C:\Program Files (x86)\Arduino\libraries\Teensy64\cpu.cpp: In function 'void cpu_clock(int)':
C:\Program Files (x86)\Arduino\libraries\Teensy64\cpu.cpp:2652:12: warning: variable 'writeCycles' set but not used [-Wunused-but-set-variable]
static int writeCycles = 0;
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=142 -DARDUINO=10805 -DF_CPU=240000000 -DUSB_SERIAL -DLAYOUT_SWEDISH "@C:\Users\user1\AppData\Local\Temp\arduino_build_589447/sketch/defs.h" "-IC:\Users\user1\AppData\Local\Temp\arduino_build_589447/pch" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files (x86)\Arduino\libraries\Teensy64" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\USBHost_t36" "-IC:\Program Files (x86)\Arduino\libraries\SdFat-master\src" "-IC:\Program Files (x86)\Arduino\libraries\Teensy-reSID-master" "C:\Program Files (x86)\Arduino\libraries\Teensy64\keyboard_usb.cpp" -o "C:\Users\user1\AppData\Local\Temp\arduino_build_589447\libraries\Teensy64\keyboard_usb.cpp.o"
C:\Program Files (x86)\Arduino\libraries\Teensy64\keyboard_usb.cpp: In member function 'virtual bool c64USBKeyboard::claim(Device_t*, int, const uint8_t*, uint32_t)':
C:\Program Files (x86)\Arduino\libraries\Teensy64\keyboard_usb.cpp:48:60: error: 'println' was not declared in this scope
println("c64USBKeyboard claim this=", (uint32_t)this, HEX);
C:\Program Files (x86)\Arduino\libraries\Teensy64\keyboard_usb.cpp: In member function 'void c64USBKeyboard::LEDS(uint8_t)':
C:\Program Files (x86)\Arduino\libraries\Teensy64\keyboard_usb.cpp:148:41: error: 'println' was not declared in this scope
println("Keyboard setLEDS ", leds, HEX);
C:\Program Files (x86)\Arduino\libraries\Teensy64\keyboard_usb.cpp: In member function 'void c64USBKeyboard::updateLEDS()':
C:\Program Files (x86)\Arduino\libraries\Teensy64\keyboard_usb.cpp:154:46: error: 'println' was not declared in this scope
println("KBD: Update LEDS", leds_.byte, HEX);
Using library Teensy64 in folder: C:\Program Files (x86)\Arduino\libraries\Teensy64 (legacy)
Using library SPI at version 1.0 in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI
Using library USBHost_t36 at version 0.1 in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\USBHost_t36
Using library SdFat-master at version 1.0.5 in folder: C:\Program Files (x86)\Arduino\libraries\SdFat-master
Using library Teensy-reSID-master in folder: C:\Program Files (x86)\Arduino\libraries\Teensy-reSID-master (legacy)
Error compiling for board Teensy 3.6.
