snowsh
I see that Paul S suggests not to use mosfet level shifters...
is this reccommendation only for teensy 3.x? I have used a BSS138 based board (https://www.sparkfun.com/products/12009) on my teensy 4.1 driving 300+ neopixels and it is working fine. Any suggestions before I commit to a PCB fabrication?
Teensy LC has a 5V buffer chip built in, connected to pin 17. The best way to use this buffer is leave pin 17 unused by your program (the pin defaults to a low power disabled state), and connect the data signals from pin 24 (or any other supported pin) to pin 17. Then connect the WS2812 LEDs to the 5V signal output.
For Teensy 3.x, a separate 5V buffer chip should be used. Unidirectional buffer chips like 74HCT245 and 74AHCT125 are best. Do NOT use these mosfet transistor level shifters. They are far too slow for WS2812 LED data.
