This is a library written for the SCD30
SparkFun sells these at its website: www.sparkfun.com
Do you like this library? Help support SparkFun. Buy a board!
https://www.sparkfun.com/products/14751
Written by Nathan Seidle @ SparkFun Electronics, May 22nd, 2018
The SCD30 measures CO2 with accuracy of +/- 30ppm.
This library handles the initialization of the SCD30 and outputs
CO2 levels, relative humidty, and temperature.
https://github.com/sparkfun/SparkFun_SCD30_Arduino_Library
Development environment specifics:
Arduino IDE 1.8.5
This program is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
GNU General Public License for more details.
You should have received a copy of the GNU General Public License
along with this program. If not, see <http://www.gnu.org/licenses/>.
#include "SparkFun_SCD30_Arduino_Library.h"
SCD30::SCD30(void)
// Constructor
//Initialize the Serial port
boolean SCD30::begin(TwoWire &wirePort)
_i2cPort = &wirePort; //Grab which port the user wants us to use
//We expect caller to begin their I2C port, with the speed of their choice external to the library
//But if they forget, we start the hardware here.
_i2cPort->begin();
/* Especially during obtaining the ACK BIT after a byte sent the SCD30 is using clock stretching (but NOT only there)!
* The need for clock stretching is described in the Sensirion_CO2_Sensors_SCD30_Interface_Description.pdf
* The default clock stretch (maximum wait time) on the ESP8266-library (2.4.2) is 230us which is set during _i2cPort->begin();
* In the current implementation of the ESP8266 I2C driver there is NO error message when this time expired, while
* the clock stretch is still happening, causing uncontrolled behaviour of the hardware combination.
* To set ClockStretchlimit() a check for ESP8266 boards has been added in the driver.
* With setting to 20000, we set a max timeout of 20mS (> 20x the maximum measured) basically disabling the time-out
* and now wait for clock stretch to be controlled by the client.
#if defined(ARDUINO_ARCH_ESP8266)
_i2cPort->setClockStretchLimit(200000);
//Check for device to respond correctly
if(beginMeasuring() == true) //Start continuous measurements
setMeasurementInterval(2); //2 seconds between measurements
setAutoSelfCalibration(true); //Enable auto-self-calibration
return (true);
return (false); //Something went wrong
//Returns the latest available CO2 level
//If the current level has already been reported, trigger a new read
uint16_t SCD30::getCO2(void)
if (co2HasBeenReported == true) //Trigger a new read
readMeasurement(); //Pull in new co2, humidity, and temp into global vars
co2HasBeenReported = true;
return (uint16_t)co2; //Cut off decimal as co2 is 0 to 10,000
//Returns the latest available humidity
float SCD30::getHumidity(void)
if (humidityHasBeenReported == true) //Trigger a new read
humidityHasBeenReported = true;
return humidity;
//Returns the latest available temperature
float SCD30::getTemperature(void)
if (temperatureHasBeenReported == true) //Trigger a new read
temperatureHasBeenReported = true;
return temperature;
//Enables or disables the ASC
void SCD30::setAutoSelfCalibration(boolean enable)
if (enable)
sendCommand(COMMAND_AUTOMATIC_SELF_CALIBRATION, 1); //Activate continuous ASC
sendCommand(COMMAND_AUTOMATIC_SELF_CALIBRATION, 0); //Deactivate continuous ASC
//Set the forced recalibration factor. See 1.3.7.
//The reference CO2 concentration has to be within the range 400 ppm ≤ cref(CO2) ≤ 2000 ppm.
void SCD30::setForcedRecalibrationFactor(uint16_t concentration)
if(concentration < 400 || concentration > 2000) return; //Error check.
sendCommand(COMMAND_SET_FORCED_RECALIBRATION_FACTOR, concentration);
//Set the temperature offset. See 1.3.8.
void SCD30::setTemperatureOffset(float tempOffset)
int16_t tickOffset = tempOffset * 100;
sendCommand(COMMAND_SET_TEMPERATURE_OFFSET, tickOffset);
//Set the altitude compenstation. See 1.3.9.
void SCD30::setAltitudeCompensation(uint16_t altitude)
sendCommand(COMMAND_SET_ALTITUDE_COMPENSATION, altitude);
//Set the pressure compenstation. This is passed during measurement startup.
//mbar can be 700 to 1200
void SCD30::setAmbientPressure(uint16_t pressure_mbar)
if(pressure_mbar < 700 || pressure_mbar > 1200) pressure_mbar = 0; //Error check
sendCommand(COMMAND_CONTINUOUS_MEASUREMENT, pressure_mbar);
//Begins continuous measurements
//Continuous measurement status is saved in non-volatile memory. When the sensor
//is powered down while continuous measurement mode is active SCD30 will measure
//continuously after repowering without sending the measurement command.
//Returns true if successful
boolean SCD30::beginMeasuring(uint16_t pressureOffset)
return(sendCommand(COMMAND_CONTINUOUS_MEASUREMENT, pressureOffset));
//Overload - no pressureOffset
boolean SCD30::beginMeasuring(void)
return(beginMeasuring(0));
//Sets interval between measurements
//2 seconds to 1800 seconds (30 minutes)
void SCD30::setMeasurementInterval(uint16_t interval)
sendCommand(COMMAND_SET_MEASUREMENT_INTERVAL, interval);
//Returns true when data is available
boolean SCD30::dataAvailable()
uint16_t response = readRegister(COMMAND_GET_DATA_READY);
if (response == 1) return (true);
return (false);
//Get 18 bytes from SCD30
//Updates global variables with floats
boolean SCD30::readMeasurement()
//Verify we have data from the sensor
if (dataAvailable() == false)
return (false);
uint32_t tempCO2 = 0;
uint32_t tempHumidity = 0;
uint32_t tempTemperature = 0;
_i2cPort->beginTransmission(SCD30_ADDRESS);
_i2cPort->write(COMMAND_READ_MEASUREMENT >> 8); //MSB
_i2cPort->write(COMMAND_READ_MEASUREMENT & 0xFF); //LSB
if (_i2cPort->endTransmission() != 0)
return (0); //Sensor did not ACK
delay(1); // Test , delay(1) before every requestFrom ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
_i2cPort->requestFrom((uint8_t)SCD30_ADDRESS, (uint8_t)18);
if (_i2cPort->available())
for (byte x = 0 ; x < 18 ; x++)
byte incoming = _i2cPort->read();
switch (x)
case 0:
case 1:
case 3:
case 4:
tempCO2 <<= 8;
tempCO2 |= incoming;
case 6:
case 7:
case 9:
case 10:
tempTemperature <<= 8;
tempTemperature |= incoming;
case 12:
case 13:
case 15:
case 16:
tempHumidity <<= 8;
tempHumidity |= incoming;
default:
//Do nothing with the CRC bytes
//Now copy the uint32s into their associated floats
memcpy(&co2, &tempCO2, sizeof(co2));
memcpy(&temperature, &tempTemperature, sizeof(temperature));
memcpy(&humidity, &tempHumidity, sizeof(humidity));
//Mark our global variables as fresh
co2HasBeenReported = false;
humidityHasBeenReported = false;
temperatureHasBeenReported = false;
return (true); //Success! New data available in globals.
//Gets two bytes from SCD30
uint16_t SCD30::readRegister(uint16_t registerAddress)
_i2cPort->write(registerAddress >> 8); //MSB
_i2cPort->write(registerAddress & 0xFF); //LSB
delay(1); // Test, delay(1) before every requestFrom ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
_i2cPort->requestFrom((uint8_t)SCD30_ADDRESS, (uint8_t)2);
uint8_t msb = _i2cPort->read();
uint8_t lsb = _i2cPort->read();
return ((uint16_t)msb << 8 | lsb);
return (0); //Sensor did not respond
//Sends a command along with arguments and CRC
boolean SCD30::sendCommand(uint16_t command, uint16_t arguments)
uint8_t data[2];
data[0] = arguments >> 8;
data[1] = arguments & 0xFF;
uint8_t crc = computeCRC8(data, 2); //Calc CRC on the arguments only, not the command
_i2cPort->write(command >> 8); //MSB
_i2cPort->write(command & 0xFF); //LSB
_i2cPort->write(arguments >> 8); //MSB
_i2cPort->write(arguments & 0xFF); //LSB
_i2cPort->write(crc);
return (false); //Sensor did not ACK
return (true);
//Sends just a command, no arguments, no CRC
boolean SCD30::sendCommand(uint16_t command)
return (true);
//Given an array and a number of bytes, this calculate CRC8 for those bytes
//CRC is only calc'd on the data portion (two bytes) of the four bytes being sent
//From: http://www.sunshine2k.de/articles/coding/crc/understanding_crc.html
//Tested with: http://www.sunshine2k.de/coding/javascript/crc/crc_js.html
//x^8+x^5+x^4+1 = 0x31
uint8_t SCD30::computeCRC8(uint8_t data[], uint8_t len)
uint8_t crc = 0xFF; //Init with 0xFF
for (uint8_t x = 0 ; x < len ; x++)
crc ^= data[x]; // XOR-in the next input byte
for (uint8_t i = 0 ; i < 8 ; i++)
if ((crc & 0x80) != 0)
crc = (uint8_t)((crc << 1) ^ 0x31);
crc <<= 1;
return crc; //No output reflection
