Projectitis
Thanks Luni. VisualTeensy is awesome
As a workaround you can also directly copy the library into the /lib subfolder of the project. To update the makefile just reopen the project in VisualTeensy. It will detect the new library and set up the corresponding makefile and the vsCode jsons. However, this sometimes requires adjustments in vsTeensy.json.
I actually *don’t* want them copied to the lib folder
Hey there! First of all thanks for this amazing tool, wanted to escape arduino IDE for years but always struggling (i'm quite a noob)
It's probably a super easy thing... but can you help me understand what is wrong?
Lorenzo
Thank you very much for this!
I followed all the steps but i cant compile i keep getting this error?
I'm trying to import an old project I made and I want to load it using the standard Arduino builder, it uses an external library.
Yes!It might help to turn on Verbose Compile output (in preferences) in the IDE and post the end part where it shows the library include paths in case ArduinoJson isn't where it is expected to be
LIBRARIES := -libraries="C:\Users\lutz\Documents\Arduino/libraries"
LIBRARIES += -libraries="C:\Program Files\Arduino\arduino-1.8.12/hardware/teensy/avr/libraries"
LIBRARIES += -libraries="C:\Program Files\Arduino\arduino-1.8.12/libraries"
Using library EEPROM at version 2.0 in folder: C:\Users\Lorenzo\Desktop\Arduinos\Teensy\arduino-1.8.13 - TeensyDuino 1.53\arduino-1.8.13\hardware\teensy\avr\libraries\EEPROM
exit status 1
make.exe: *** [makefile:49: all] Error 1
The terminal process "C:\WINDOWS\System32\cmd.exe /d /c C:/Users/Lorenzo/Desktop/Arduinos/Teensy/VisualTeensy_v0_9_9_0/make.exe all " terminated with exit code: 2.
all:
$(BUILDER) $(FLAGS) -build-path=$(BUILD_PATH) -fqbn=$(FQBN) $(HARDWARE) $(TOOLS) $(LIBRARIES) $(SKETCH_NAME)
The makefile for *.ino builds is actually quite simple it just calls the builder with the give arguments. In case you are not familiar with makefile syntax, the $(XXX) parts are variables which are defined a few lines above.I suppose this error is the same due to some patch on this line that are not correct, but the other paths seems correct only the libraries are in a different location when using portable.
T:\arduino-1.8.12>dir Nportable /s /d
Volume in drive T is Temp_T
Directory of T:\arduino-1.8.12\Nportable
[.] library_index.json package_index.json [sketchbook]
[..] library_index.json.sig package_index.json.sig
[cache] [logs] preferences.txt
5 File(s) 11,718,702 bytes
Directory of T:\arduino-1.8.12\Nportable\cache
[.] [..] cache.json [downloads.arduino.cc]
1 File(s) 2,164 bytes
Directory of T:\arduino-1.8.12\Nportable\cache\downloads.arduino.cc
[.] [..] [libraries] [packages]
0 File(s) 0 bytes
Directory of T:\arduino-1.8.12\Nportable\cache\downloads.arduino.cc\libraries
[.] library_index.json.gz
2 File(s) 1,182,069 bytes
Directory of T:\arduino-1.8.12\Nportable\cache\downloads.arduino.cc\packages
[.] package_index.json
[..] package_index.json.sig
2 File(s) 288,318 bytes
Directory of T:\arduino-1.8.12\Nportable\logs
[.] [..] application.log
1 File(s) 25,624 bytes
Directory of T:\arduino-1.8.12\Nportable\sketchbook
0 File(s) 0 bytes
Directory of T:\arduino-1.8.12\Nportable\sketchbook\libraries
[.] [..] readme.txt
1 File(s) 87 bytes
I'll try that...From the IDE going 'portable' just uses that folder in place of the normal paths: It puts sketchbook\libraries there when 'portable' exists in the arduino install folder.
> Executing task: C:/Users/Lorenzo/Desktop/Arduinos/Teensy/VisualTeensy_v0_9_9_0/make.exe all <
C:\Users\Lorenzo\Desktop\Arduinos\Teensy\arduino-1.8.13 - TeensyDuino 1.53\arduino-1.8.13/arduino-builder -verbose=1 -warnings=all -build-path=C:/Users/Lorenzo/Desktop/test_visualteensy/Blink/Blink/.vsTeensy/build -fqbn=teensy:avr:teensy36:usb=serial,speed=180,opt=o2std,keys=en-us -hardware="C:\Users\Lorenzo\Desktop\Arduinos\Teensy\arduino-1.8.13 - TeensyDuino 1.53\arduino-1.8.13/hardware" -tools="C:\Users\Lorenzo\Desktop\Arduinos\Teensy\arduino-1.8.13 - TeensyDuino 1.53\arduino-1.8.13\tools-builder" -libraries="C:\Users\Lorenzo\Documents\Arduino/libraries" -libraries="C:\Users\Lorenzo\Desktop\Arduinos\Teensy\arduino-1.8.13 - TeensyDuino 1.53\arduino-1.8.13/hardware/teensy/avr/libraries" -libraries="C:\Users\Lorenzo\Desktop\Arduinos\Teensy\arduino-1.8.13 - TeensyDuino 1.53\arduino-1.8.13/libraries" Blink.ino
Using board 'teensy36' from platform in folder: C:\Users\Lorenzo\Desktop\Arduinos\Teensy\arduino-1.8.13 - TeensyDuino 1.53\arduino-1.8.13\hardware\teensy\avr
Using core 'teensy3' from platform in folder: C:\Users\Lorenzo\Desktop\Arduinos\Teensy\arduino-1.8.13 - TeensyDuino 1.53\arduino-1.8.13\hardware\teensy\avr
Detecting libraries used...
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors
-std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=153 -DARDUINO=10600 -DARDUINO_TEENSY36 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\sketch\\Blink.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
-std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=153 -DARDUINO=10600 -DARDUINO_TEENSY36 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\sketch\\Blink.ino.cpp" -o "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\preproc\\ctags_target_for_gcc_minus_e.cpp" -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/precompile_helper" "C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr/cores/teensy3" "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build" "C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -x c++-header -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=153 -DARDUINO=10600
-DARDUINO_TEENSY36 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr/cores/teensy3" "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build/pch/Arduino.h" -o "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build/pch/Arduino.h.gch"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=153 -DARDUINO=10600 -DARDUINO_TEENSY36 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build/pch" "-IC:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\sketch\\Blink.ino.cpp" -o "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\sketch\\Blink.ino.cpp.o"
Compiling libraries...
Compiling core...
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -x assembler-with-cpp -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=153 -DARDUINO=10600 -DARDUINO_TEENSY36 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3\\memcpy-armv7m.S" -o "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\memcpy-armv7m.S.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -x assembler-with-cpp -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=153 -DARDUINO=10600 -DARDUINO_TEENSY36 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3\\memset.S" -o "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\memset.S.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=153 -DARDUINO=10600 -DARDUINO_TEENSY36 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3\\math_helper.c" -o "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\math_helper.c.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=153 -DARDUINO=10600 -DARDUINO_TEENSY36 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3\\eeprom.c" -o "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\eeprom.c.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=153 -DARDUINO=10600 -DARDUINO_TEENSY36 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3\\keylayouts.c" -o "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\keylayouts.c.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=153 -DARDUINO=10600 -DARDUINO_TEENSY36 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3\\analog.c" -o "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\analog.c.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=153 -DARDUINO=10600 -DARDUINO_TEENSY36 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3\\mk20dx128.c" -o "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\mk20dx128.c.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=153 -DARDUINO=10600 -DARDUINO_TEENSY36 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3\\nonstd.c" -o "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\nonstd.c.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=153 -DARDUINO=10600 -DARDUINO_TEENSY36 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3\\pins_teensy.c" -o "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\pins_teensy.c.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=153 -DARDUINO=10600 -DARDUINO_TEENSY36 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3\\ser_print.c" -o "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\ser_print.c.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=153 -DARDUINO=10600 -DARDUINO_TEENSY36 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3\\serial1.c" -o "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\serial1.c.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=153 -DARDUINO=10600 -DARDUINO_TEENSY36 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3\\serial2.c" -o "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\serial2.c.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=153 -DARDUINO=10600 -DARDUINO_TEENSY36 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3\\serial3.c" -o "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\serial3.c.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=153 -DARDUINO=10600 -DARDUINO_TEENSY36 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3\\serial4.c" -o "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\serial4.c.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=153 -DARDUINO=10600 -DARDUINO_TEENSY36 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3\\serial6.c" -o "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\serial6.c.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=153 -DARDUINO=10600 -DARDUINO_TEENSY36 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3\\serial6_lpuart.c" -o "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\serial6_lpuart.c.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=153 -DARDUINO=10600 -DARDUINO_TEENSY36 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3\\serial5.c" -o "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\serial5.c.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=153 -DARDUINO=10600 -DARDUINO_TEENSY36 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3\\touch.c" -o "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\touch.c.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=153 -DARDUINO=10600 -DARDUINO_TEENSY36 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3\\usb_desc.c" -o "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\usb_desc.c.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=153 -DARDUINO=10600 -DARDUINO_TEENSY36 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3\\usb_dev.c" -o "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\usb_dev.c.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=153 -DARDUINO=10600 -DARDUINO_TEENSY36 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3\\usb_joystick.c" -o "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\usb_joystick.c.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=153 -DARDUINO=10600 -DARDUINO_TEENSY36 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3\\usb_keyboard.c" -o "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\usb_keyboard.c.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=153 -DARDUINO=10600 -DARDUINO_TEENSY36 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3\\usb_mem.c" -o "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\usb_mem.c.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=153 -DARDUINO=10600 -DARDUINO_TEENSY36 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3\\usb_midi.c" -o "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\usb_midi.c.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=153 -DARDUINO=10600 -DARDUINO_TEENSY36 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3\\usb_mouse.c" -o "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\usb_mouse.c.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=153 -DARDUINO=10600 -DARDUINO_TEENSY36 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3\\usb_mtp.c" -o "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\usb_mtp.c.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=153 -DARDUINO=10600 -DARDUINO_TEENSY36 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3\\usb_rawhid.c" -o "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\usb_rawhid.c.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=153 -DARDUINO=10600 -DARDUINO_TEENSY36 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3\\usb_seremu.c" -o "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\usb_seremu.c.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=153 -DARDUINO=10600 -DARDUINO_TEENSY36 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3\\usb_serial.c" -o "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\usb_serial.c.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=153 -DARDUINO=10600 -DARDUINO_TEENSY36 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3\\usb_serial2.c" -o "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\usb_serial2.c.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=153 -DARDUINO=10600 -DARDUINO_TEENSY36 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3\\usb_serial3.c" -o "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\usb_serial3.c.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=153 -DARDUINO=10600 -DARDUINO_TEENSY36 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3\\usb_touch.c" -o "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\usb_touch.c.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=153 -DARDUINO=10600 -DARDUINO_TEENSY36 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build/pch" "-IC:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3\\AudioStream.cpp" -o "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\AudioStream.cpp.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=153 -DARDUINO=10600 -DARDUINO_TEENSY36 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build/pch" "-IC:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3\\HardwareSerial.cpp" -o "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\HardwareSerial.cpp.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=153 -DARDUINO=10600 -DARDUINO_TEENSY36 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build/pch" "-IC:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3\\DMAChannel.cpp" -o "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\DMAChannel.cpp.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=153 -DARDUINO=10600 -DARDUINO_TEENSY36 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build/pch" "-IC:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3\\EventResponder.cpp" -o "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\EventResponder.cpp.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=153 -DARDUINO=10600 -DARDUINO_TEENSY36 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build/pch" "-IC:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3\\HardwareSerial2.cpp" -o "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\HardwareSerial2.cpp.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=153 -DARDUINO=10600 -DARDUINO_TEENSY36 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build/pch" "-IC:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3\\HardwareSerial1.cpp" -o "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\HardwareSerial1.cpp.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=153 -DARDUINO=10600 -DARDUINO_TEENSY36 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build/pch" "-IC:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3\\HardwareSerial3.cpp" -o "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\HardwareSerial3.cpp.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=153 -DARDUINO=10600 -DARDUINO_TEENSY36 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build/pch" "-IC:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3\\HardwareSerial4.cpp" -o "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\HardwareSerial4.cpp.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=153 -DARDUINO=10600 -DARDUINO_TEENSY36 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build/pch" "-IC:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3\\HardwareSerial5.cpp" -o "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\HardwareSerial5.cpp.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=153 -DARDUINO=10600 -DARDUINO_TEENSY36 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build/pch" "-IC:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3\\HardwareSerial6.cpp" -o "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\HardwareSerial6.cpp.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=153 -DARDUINO=10600 -DARDUINO_TEENSY36 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build/pch" "-IC:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3\\IPAddress.cpp" -o "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\IPAddress.cpp.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=153 -DARDUINO=10600 -DARDUINO_TEENSY36 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build/pch" "-IC:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3\\IntervalTimer.cpp" -o "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\IntervalTimer.cpp.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=153 -DARDUINO=10600 -DARDUINO_TEENSY36 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build/pch" "-IC:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3\\Print.cpp" -o "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\Print.cpp.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=153 -DARDUINO=10600 -DARDUINO_TEENSY36 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build/pch" "-IC:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3\\Stream.cpp" -o "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\Stream.cpp.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=153 -DARDUINO=10600 -DARDUINO_TEENSY36 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build/pch" "-IC:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3\\Tone.cpp" -o "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\Tone.cpp.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=153 -DARDUINO=10600 -DARDUINO_TEENSY36 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build/pch" "-IC:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3\\WMath.cpp" -o "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\WMath.cpp.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=153 -DARDUINO=10600 -DARDUINO_TEENSY36 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build/pch" "-IC:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3\\WString.cpp" -o "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\WString.cpp.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=153 -DARDUINO=10600 -DARDUINO_TEENSY36 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build/pch" "-IC:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3\\avr_emulation.cpp" -o "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\avr_emulation.cpp.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=153 -DARDUINO=10600 -DARDUINO_TEENSY36 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build/pch" "-IC:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3\\main.cpp" -o "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\main.cpp.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=153 -DARDUINO=10600 -DARDUINO_TEENSY36 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build/pch" "-IC:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3\\new.cpp" -o "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\new.cpp.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=153 -DARDUINO=10600 -DARDUINO_TEENSY36 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build/pch" "-IC:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3\\serialEvent.cpp" -o "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\serialEvent.cpp.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=153 -DARDUINO=10600 -DARDUINO_TEENSY36 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build/pch" "-IC:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3\\serialEvent1.cpp" -o "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\serialEvent1.cpp.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=153 -DARDUINO=10600 -DARDUINO_TEENSY36 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build/pch" "-IC:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3\\serialEvent2.cpp" -o "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\serialEvent2.cpp.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=153 -DARDUINO=10600 -DARDUINO_TEENSY36 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build/pch" "-IC:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3\\serialEvent3.cpp" -o "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\serialEvent3.cpp.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=153 -DARDUINO=10600 -DARDUINO_TEENSY36 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build/pch" "-IC:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3\\serialEvent4.cpp" -o "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\serialEvent4.cpp.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=153 -DARDUINO=10600 -DARDUINO_TEENSY36 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build/pch" "-IC:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3\\serialEvent5.cpp" -o "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\serialEvent5.cpp.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=153 -DARDUINO=10600 -DARDUINO_TEENSY36 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build/pch" "-IC:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3\\serialEvent6.cpp" -o "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\serialEvent6.cpp.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=153 -DARDUINO=10600 -DARDUINO_TEENSY36 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build/pch" "-IC:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3\\serialEventUSB1.cpp" -o "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\serialEventUSB1.cpp.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=153 -DARDUINO=10600 -DARDUINO_TEENSY36 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build/pch" "-IC:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3\\serialEventUSB2.cpp" -o "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\serialEventUSB2.cpp.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=153 -DARDUINO=10600 -DARDUINO_TEENSY36 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build/pch" "-IC:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3\\usb_audio.cpp" -o "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\usb_audio.cpp.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=153 -DARDUINO=10600 -DARDUINO_TEENSY36 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build/pch" "-IC:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3\\usb_flightsim.cpp" -o "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\usb_flightsim.cpp.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=153 -DARDUINO=10600 -DARDUINO_TEENSY36 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build/pch" "-IC:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3\\usb_inst.cpp" -o "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\usb_inst.cpp.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=153 -DARDUINO=10600 -DARDUINO_TEENSY36 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build/pch" "-IC:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3\\yield.cpp" -o "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\yield.cpp.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\core.a" "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\memcpy-armv7m.S.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\core.a" "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\memset.S.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\core.a" "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\analog.c.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\core.a" "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\eeprom.c.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\core.a" "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\keylayouts.c.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\core.a" "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\math_helper.c.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\core.a" "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\mk20dx128.c.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\core.a" "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\nonstd.c.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\core.a" "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\pins_teensy.c.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\core.a" "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\ser_print.c.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\core.a" "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\serial1.c.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\core.a" "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\serial2.c.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\core.a" "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\serial3.c.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\core.a" "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\serial4.c.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\core.a" "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\serial5.c.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\core.a" "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\serial6.c.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\core.a" "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\serial6_lpuart.c.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\core.a" "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\touch.c.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\core.a" "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\usb_desc.c.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\core.a" "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\usb_dev.c.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\core.a" "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\usb_joystick.c.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\core.a" "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\usb_keyboard.c.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\core.a" "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\usb_mem.c.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\core.a" "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\usb_midi.c.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\core.a" "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\usb_mouse.c.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\core.a" "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\usb_mtp.c.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\core.a" "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\usb_rawhid.c.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\core.a" "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\usb_seremu.c.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\core.a" "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\usb_serial.c.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\core.a" "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\usb_serial2.c.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\core.a" "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\usb_serial3.c.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\core.a" "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\usb_touch.c.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\core.a" "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\AudioStream.cpp.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\core.a" "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\DMAChannel.cpp.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\core.a" "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\EventResponder.cpp.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\core.a" "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\HardwareSerial.cpp.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\core.a" "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\HardwareSerial1.cpp.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\core.a" "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\HardwareSerial2.cpp.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\core.a" "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\HardwareSerial3.cpp.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\core.a" "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\HardwareSerial4.cpp.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\core.a" "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\HardwareSerial5.cpp.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\core.a" "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\HardwareSerial6.cpp.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\core.a" "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\IPAddress.cpp.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\core.a" "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\IntervalTimer.cpp.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\core.a" "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\Print.cpp.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\core.a" "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\Stream.cpp.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\core.a" "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\Tone.cpp.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\core.a" "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\WMath.cpp.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\core.a" "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\WString.cpp.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\core.a" "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\avr_emulation.cpp.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\core.a" "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\main.cpp.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\core.a" "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\new.cpp.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\core.a" "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\serialEvent.cpp.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\core.a" "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\serialEvent1.cpp.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\core.a" "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\serialEvent2.cpp.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\core.a" "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\serialEvent3.cpp.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\core.a" "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\serialEvent4.cpp.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\core.a" "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\serialEvent5.cpp.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\core.a" "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\serialEvent6.cpp.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\core.a" "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\serialEventUSB1.cpp.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\core.a" "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\serialEventUSB2.cpp.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\core.a" "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\usb_audio.cpp.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\core.a" "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\usb_flightsim.cpp.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\core.a" "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\usb_inst.cpp.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\core.a" "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\core\\yield.cpp.o"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc" -O2 -Wl,--gc-sections,--relax,--defsym=__rtc_localtime=1604053783 "-TC:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy\\avr\\cores\\teensy3/mk66fx1m0.ld" -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -o "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build/Blink.ino.elf" "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build\\sketch\\Blink.ino.cpp.o" "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build/core\\core.a" "-LC:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build" -larm_cortexM4lf_math -lm -lstdc++
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build/Blink.ino.elf" "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build/Blink.ino.eep"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-objcopy" -O ihex -R .eeprom "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build/Blink.ino.elf" "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build/Blink.ino.hex"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/stdout_redirect" "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build/Blink.ino.lst" "C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-objdump" -d -S -C "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build/Blink.ino.elf"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/stdout_redirect" "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build/Blink.ino.sym" "C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-objdump" -t -C "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build/Blink.ino.elf"
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/teensy_post_compile" -file=Blink.ino "-path=C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build" "-tools=C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/" -board=TEENSY36
Opening Teensy Loader...
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-size" -A "C:\\Users\\Lorenzo\\Desktop\\test_visualteensy\\Blink\\Blink\\.vsTeensy\\build/Blink.ino.elf"
Sketch uses 8676 bytes (0%) of program storage space. Maximum is 1048576 bytes.
Global variables use 3076 bytes (1%) of dynamic memory, leaving 259068 bytes for local variables. Maximum is 262144 bytes.
LIBRARIES += -libraries="C:\Users\Lorenzo\Desktop\Arduinos\Teensy\arduino-1.8.13 - TeensyDuino 1.53\arduino-1.8.13/portable/sketchbook/libraries"
Multiple libraries were found for "Ethernet.h"
Used: C:\Users\Lorenzo\Desktop\Arduinos\Teensy\arduino-1.8.13 - TeensyDuino 1.53\arduino-1.8.13\hardware\teensy\avr\libraries\Ethernet
Not used: C:\Users\Lorenzo\Desktop\Arduinos\Teensy\arduino-1.8.13 - TeensyDuino 1.53\arduino-1.8.13\libraries\Ethernet
Used: C:\Users\Lorenzo\Desktop\Arduinos\Teensy\arduino-1.8.13 - TeensyDuino 1.53\arduino-1.8.13\hardware\teensy\avr\libraries\SD
Not used: C:\Users\Lorenzo\Desktop\Arduinos\Teensy\arduino-1.8.13 - TeensyDuino 1.53\arduino-1.8.13\libraries\SD
Using library Ethernet at version 2.0.0 in folder: C:\Users\Lorenzo\Desktop\Arduinos\Teensy\arduino-1.8.13 - TeensyDuino 1.53\arduino-1.8.13\hardware\teensy\avr\libraries\Ethernet
Using library MIDI at version 5.0.2 in folder: C:\Users\Lorenzo\Desktop\Arduinos\Teensy\arduino-1.8.13 - TeensyDuino 1.53\arduino-1.8.13\hardware\teensy\avr\libraries\MIDI
Using library SPI at version 1.0 in folder: C:\Users\Lorenzo\Desktop\Arduinos\Teensy\arduino-1.8.13 - TeensyDuino 1.53\arduino-1.8.13\hardware\teensy\avr\libraries\SPI
Using library SD at version 1.2.2 in folder: C:\Users\Lorenzo\Desktop\Arduinos\Teensy\arduino-1.8.13 - TeensyDuino 1.53\arduino-1.8.13\hardware\teensy\avr\libraries\SD
Using library ArduinoJson at version 5.13.5 in folder: C:\Users\Lorenzo\Desktop\Arduinos\Teensy\arduino-1.8.13 - TeensyDuino 1.53\arduino-1.8.13\portable\sketchbook\libraries\ArduinoJson
Using library Artnet in folder: C:\Users\Lorenzo\Desktop\Arduinos\Teensy\arduino-1.8.13 - TeensyDuino 1.53\arduino-1.8.13\hardware\teensy\avr\libraries\Artnet (legacy)
Using library EEPROM at version 2.0 in folder: C:\Users\Lorenzo\Desktop\Arduinos\Teensy\arduino-1.8.13 - TeensyDuino 1.53\arduino-1.8.13\hardware\teensy\avr\libraries\EEPROM
"C:\\Users\\Lorenzo\\Desktop\\Arduinos\\Teensy\\arduino-1.8.13 - TeensyDuino 1.53\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-size" -A "C:\\Users\\Lorenzo\\AppData\\Local\\Temp\\arduino_build_470560/Mm2q_V2.27_MidiBeatClock.ino.elf"
Sketch uses 51956 bytes (4%) of program storage space. Maximum is 1048576 bytes.
Global variables use 8000 bytes (3%) of dynamic memory, leaving 254144 bytes for local variables. Maximum is 262144 bytes.
Used: C:\Users\Lorenzo\Desktop\Arduinos\Teensy\arduino-1.8.13 - TeensyDuino 1.53\arduino-1.8.13\libraries\Ethernet
Not used: C:\Users\Lorenzo\Desktop\Arduinos\Teensy\arduino-1.8.13 - TeensyDuino 1.53\arduino-1.8.13\hardware\teensy\avr\libraries\Ethernet
Used: C:\Users\Lorenzo\Desktop\Arduinos\Teensy\arduino-1.8.13 - TeensyDuino 1.53\arduino-1.8.13\libraries\SD
Not used: C:\Users\Lorenzo\Desktop\Arduinos\Teensy\arduino-1.8.13 - TeensyDuino 1.53\arduino-1.8.13\hardware\teensy\avr\libraries\SD
Using library Ethernet at version 2.0.0 in folder: C:\Users\Lorenzo\Desktop\Arduinos\Teensy\arduino-1.8.13 - TeensyDuino 1.53\arduino-1.8.13\libraries\Ethernet
Using library SD at version 1.2.4 in folder: C:\Users\Lorenzo\Desktop\Arduinos\Teensy\arduino-1.8.13 - TeensyDuino 1.53\arduino-1.8.13\libraries\SD
exit status 1
make.exe: *** [makefile:49: all] Error 1
The terminal process "C:\WINDOWS\System32\cmd.exe /d /c C:/Users/Lorenzo/Desktop/Arduinos/Teensy/VisualTeensy_v0_9_9_0/make.exe all " terminated with exit code: 2.
C:\Users\Lorenzo\Desktop\test_visualteensy\Mm2q_V2.27_MidiBeatClock\Mm2q_V2.27_MidiBeatClock\Mm2q_V2.27_MidiBeatClock.ino:109:20: error: 'BUILTIN_SDCARD' was not declared in this scope
#define SS_SD_CARD BUILTIN_SDCARD // using SD card in the main board
C:\Users\Lorenzo\Desktop\test_visualteensy\Mm2q_V2.27_MidiBeatClock\Mm2q_V2.27_MidiBeatClock\SD_Read.ino:4:17: note: in expansion of macro 'SS_SD_CARD'
if (!SD.begin(SS_SD_CARD)) {
LIBRARIES := -libraries="C:\Users\Lorenzo\Documents\Arduino/libraries"
LIBRARIES += -libraries="C:\Users\Lorenzo\Desktop\Arduinos\Teensy\arduino-1.8.13 - TeensyDuino 1.53\arduino-1.8.13/hardware/teensy/avr/libraries"
#LIBRARIES += -libraries="C:\Users\Lorenzo\Desktop\Arduinos\Teensy\arduino-1.8.13 - TeensyDuino 1.53\arduino-1.8.13/libraries"
-built-in-libraries C:\Users\lutz\Documents\arduino-1.8.12-Teensyduino153\libraries
