Page 1 of 2 1 2 LastLast
Results 1 to 25 of 42
Thread: Teensy3 alternative for dtostrf() ?
    Oct 2012
    Portland OR
    676
    I have some Arduino code working now using the Adafruit 128x64 LCD using their ST7565 library, and want to port it to Teensy 3. The library required two minor fixes to compile:
    (1) They assume they can use 'A0' as a dummy variable in their class definition, but it is already defined as a numeric constant in the T3 environment.
    (2) They #include <util/delay.h> to use _delay_ms() instead of just using delay()
    Now, to show a floating-point variable on the LCD with the ST7565 library, I need to convert the number into a string. I see that 'dtostrf()' is not available for Teensy 3. Should I instead use 'FloatToString()' http://arduino.cc/playground/Main/FloatToString or is there a better way?
    I wanted to ask the same thing: I have to convert a float into a string to calculate a checksum before sending it over the line, and dtostrf() works on Teensy 2, but not Teensy 3. What is the best way to convert a float to a string on a Teensy 3?
    Sorry for the noise: Solved it with using sprintf(), and %f format strings, and the code is easier to read too.
    20,574
    Are you using Teensyduino version 1.13? I recently made some changes, to support this library. Please give 1.13 a try with Arduino 1.0.4. This library is now supposed to compile and work without any editing.
    Jun 2014
    11
    more on dtostrf() and sprintf() for Teensy 2, Teensy 3
    I also ran into the issue of dtostrf() not working on T3 after porting some code I wrote while using a different Arduino board. Found that it works most of the time, which made the problem go un-noticed for a while; discovered that it seems to error only on small numbers. As you say, the sprintf() works fine for T3, as does dtostrf() for T2. It is just another thing to remember wrt portability. Here's the code I used to test and document the issue for myself.
    // formatted float printing: Teensy 2 vs. 3
    // dtostrf() errors for small numbers ~ < 0.1 on T3
    char cbuf[20] = "";
      while (!Serial && millis() < 5000) {}    // with timeout
      float y;
      // -nn.nnnn
      y = -(sin(3.1416 / 4)) * 10;   // big
      dtostrf(y, 10, 5, cbuf);       //   correct on T3
      Serial.println(cbuf);
      sprintf(cbuf, "%10.5f", y);    //   correct on T3
      y = +(sin(3.1416 / 4)) / 200;  // small
      dtostrf(y, 10, 5, cbuf);       // incorrect on T3
    9,700
    Indeed it isn't right, but . . .
    Perhaps showing the output and indicating where you see the problem would help focus on the nature of the problem. Especially showing the 'right' answer from the T2 as well.
      Serial.println("-small-");
      y = -0.00123456;  // small
    My output - with the code quoted in the USB output:
    -small-
    dtostrf(y, 10, 5, cbuf); == -12346
    sprintf(cbuf, "%10.5f", y); == -0.00123
    Also the + or - before the sin is a red herring - it is wrong in both cases leaving them both the same would have been clearer.
    And the sin() itself is another - it makes the expected value unclear using this constant instead would have helped me: "y = -0.00353554; // small"
    I had to build the sketch and add to it before it became clear where the issue is. I was busy staring at the trees and missed the forest, I thought the problem was the last digit rounding, and wholly skipped the missing decimal place as not normal behavior for dtostrf() - because the actual number has a '3535' pattern, so this value is even better: "y = -0.00123456; // small"
    My not knowing dtostrf() I didn't know what to expect - you asked for 5 digits and got five? This is probably behind the error in dtostrf(), once it passes the decimal - it is out of sight and out of mind - and starts focusing on the first digit it finds since the 'leading' zeroes are boring to look at once the decimal passes because counting zeroes takes effort.
    20,574
    Yup, there's probably a bug in my attempt to emulate dtostrf. Here's the code.
    https://github.com/PaulStoffregen/co...3/nonstd.c#L69
    Ultimately it uses fcvt(), which is a standard C function, but quite difficult to use correctly. I must have missed some of the cases. I've put this on my list of bugs to investigate, but realistically it's unlikely I'll be able to spend time on this until mid-November.
    If anyone has any ideas about where I went wrong in trying to emulate avr-libc's dtostrf(), please speak up!
    Germany NRW
    5,679
    Problay not part of the problem, but shouldnt "val" be double?
    9,700
    Reading the manual:
    The string itself does not contain a decimal point; however, the position of the decimal point relative to the start of the string is stored in *decpt.
    I'll go glance at GitHub now
    9,700
    I have NO IDEA of any side effects - or other cases this may affect - but on my sample this works - adding the ELSE at line 97 {"I:\Teensy165\hardware\teensy\avr\cores\teensy3\non std.c"}:
    	if (decpt == 0 && precision > 0) {
    		*p++ = '0';
    		*p++ = '.';
    	else if (decpt < 0 && precision > 0) {
    		*p++ = '0';
    		*p++ = '.';
    		e++;
    		while ( decpt < 0 ) {
    			decpt++;
    			*p++ = '0';
    -small-
    dtostrf(y, 10, 5, cbuf); == -0.00123
    9,700
    My sample test looks right - not showing anything odd (using edited nonstd.c code from post #10):
    <EDIT>: Sample INO starts with a SMALL negative Y and then loops to multiply it by 10 each loop to go from SMALL float to LARGER float.
    It then repeats with a same positive value for SMALL y
    In both cases it shows reference values from sprintf with the same %10.5f and printf for the full number value
    char cbuf[20] = "";
      float y;
      Serial.println("------");
      y = -0.000012345678L;  // small
      for ( int jj = 0; jj < 2; jj++ ) {
        if ( 1 == jj ){
          y = 0.000012345678L;  // small
          Serial.println("\n=================------\n");
        for ( int ii = 0; ii < 10; ii++ ) {
          Serial.print( "dtostrf(y, 10, 5, cbuf); == ");
          Serial.print( "sprintf(cbuf, \"%10.5f\", y); == ");
          Serial.print("printf(\"%f\", y);");
          Serial.printf("%f", y);
          y *= 10;
          Serial.println("\n------");
    dtostrf(y, 10, 5, cbuf); == -0.00001
    sprintf(cbuf, "%10.5f", y); == -0.00001
    printf("%f", y);-0.000012
    dtostrf(y, 10, 5, cbuf); == -0.00012
    sprintf(cbuf, "%10.5f", y); == -0.00012
    printf("%f", y);-0.000123
    printf("%f", y);-0.001235
    dtostrf(y, 10, 5, cbuf); == -0.01234
    sprintf(cbuf, "%10.5f", y); == -0.01235
    printf("%f", y);-0.012346
    dtostrf(y, 10, 5, cbuf); == -0.12346
    sprintf(cbuf, "%10.5f", y); == -0.12346
    printf("%f", y);-0.123457
    dtostrf(y, 10, 5, cbuf); == -1.23457
    sprintf(cbuf, "%10.5f", y); == -1.23457
    printf("%f", y);-1.234568
    dtostrf(y, 10, 5, cbuf); == -12.34568
    sprintf(cbuf, "%10.5f", y); == -12.34568
    printf("%f", y);-12.345678
    dtostrf(y, 10, 5, cbuf); == -123.45679
    sprintf(cbuf, "%10.5f", y); == -123.45679
    printf("%f", y);-123.456787
    dtostrf(y, 10, 5, cbuf); == -1234.56787
    sprintf(cbuf, "%10.5f", y); == -1234.56787
    printf("%f", y);-1234.567871
    dtostrf(y, 10, 5, cbuf); == -12345.67871
    sprintf(cbuf, "%10.5f", y); == -12345.67871
    printf("%f", y);-12345.678711
    dtostrf(y, 10, 5, cbuf); == 0.00001
    sprintf(cbuf, "%10.5f", y); == 0.00001
    printf("%f", y);0.000012
    dtostrf(y, 10, 5, cbuf); == 0.00012
    sprintf(cbuf, "%10.5f", y); == 0.00012
    printf("%f", y);0.000123
    dtostrf(y, 10, 5, cbuf); == 0.00123
    sprintf(cbuf, "%10.5f", y); == 0.00123
    printf("%f", y);0.001235
    dtostrf(y, 10, 5, cbuf); == 0.01234
    sprintf(cbuf, "%10.5f", y); == 0.01235
    printf("%f", y);0.012346
    dtostrf(y, 10, 5, cbuf); == 0.12346
    sprintf(cbuf, "%10.5f", y); == 0.12346
    printf("%f", y);0.123457
    dtostrf(y, 10, 5, cbuf); == 1.23457
    sprintf(cbuf, "%10.5f", y); == 1.23457
    printf("%f", y);1.234568
    dtostrf(y, 10, 5, cbuf); == 12.34568
    sprintf(cbuf, "%10.5f", y); == 12.34568
    printf("%f", y);12.345678
    dtostrf(y, 10, 5, cbuf); == 123.45679
    sprintf(cbuf, "%10.5f", y); == 123.45679
    printf("%f", y);123.456787
    dtostrf(y, 10, 5, cbuf); == 1234.56787
    sprintf(cbuf, "%10.5f", y); == 1234.56787
    printf("%f", y);1234.567871
    dtostrf(y, 10, 5, cbuf); == 12345.67871
    sprintf(cbuf, "%10.5f", y); == 12345.67871
    printf("%f", y);12345.678711
    Last edited by defragster; 10-28-2015 at 05:22 PM. Reason: opps : removed extraneous 'code' printf from output
    9,700
    Issued PULL request. GitHub was harder to navigate than editing the code was - but maybe I'm learning.
    https://github.com/PaulStoffregen/cores/pull/89
    Germany NRW
    5,679
            *p++ = '0';
            *p++ = '.';
            *p++ = '0';
            *p++ = '.';
            e++;
                decpt++;
                *p++ = '0';
    Seems to work!:
    You can omit the previous "if":
    just delete it (incl. else) and write if (decpt <= 0 && precision > 0) { instead
    so the complete function is now:
    char * dtostrf(double val, int width, unsigned int precision, char *buf)
        int decpt, sign, reqd, pad;
        const char *s, *e;
        char *p;
        s = fcvt(val, precision, &decpt, &sign);
        if (precision == 0 && decpt == 0) {
            s = (*s < '5') ? "0" : "1";
            reqd = 1;
            reqd = strlen(s);
            if (reqd > decpt) reqd++;
            if (decpt == 0) reqd++;
        if (sign) reqd++;
        p = buf;
        e = p + reqd;
        pad = width - reqd;
        if (pad > 0) {
            e += pad;
            while (pad-- > 0) *p++ = ' ';
        if (sign) *p++ = '-';
            *p++ = '0';
            *p++ = '.';
            e++;
                decpt++;
                *p++ = '0';
        while (p < e) {
            *p++ = *s++;
            if (p == e) break;
            if (--decpt == 0) *p++ = '.';
        if (width < 0) {
            pad = (reqd + width) * -1;
        *p = 0;
        //char format[20];
        //sprintf(format, "%%%d.%df", width, precision);
        //sprintf(buf, format, val);
        return buf;
    of course, avr_functions.h needs to be edited:
    char * dtostrf(double val, int width, unsigned int precision, char *buf);
    (line101)
    9,700
    @Frank: I thought about that clause being suspect <edit: subject to removal or inclusion> with my change - but I modified the value of 'e' and didn't want to actually look any further in the code for side effects. Without that change it came up one byte short on output - with it in any other case it might start adding digits.
    9,700
    Cool! The PULL is done!
    Germany NRW
    5,679
    cool :O)
    but the "float val" parameter still seems not to be correct for me .
    i just found the declaration of avr-libc:
    http://www.nongnu.org/avr-libc/user-...168b3ce8771d42
    search for dtostrf
    char* dtostrf ( double __val,
    signed char __width,
    unsigned char __prec,
    char * __s
    The dtostrf() function converts the double value passed in val
    3,256
    Yes, the function takes a double argument. However, since C++ requires prototypes in scope, the compiler will automatically convert a float passed to dtostrf to double.
    Even in the case of ancient C without prototypes, it would have worked, since if you don't have a prototype in scope, the compiler will create a prototype for you, and char/short arguments will be converted to int, and float arguments are converted to double.
    Germany NRW
    5,679
    @Michael:
    I don't understand.. sometimes my english is not good enough..
    In avr_functions.h (teensy3-code): char * dtostrf(float val, int width, unsigned int precision, char *buf);
    The function in nonstd.c (teensy3-code) is the same:
    char * dtostrf(float val, int width, unsigned int precision, char *buf) {...}
    So, that float is correct, and instead float the compiler uses double?
    I thought, if you call this function with a double, tha value is converted to float, and then later in the function the float value is again converted to double for fcvt()
    So i am wrong ? Changing it to char * dtostrf(double val, is not needed ??
    Why is in the AVR-LIBC (which is NOT usd here, or is it??) a different prototype?
    3,256
    The documentation that I've seen has a double as the first argument.
    Note, in the AVR system, double is not 64-bits, but it is 32-bits, just like float (presumably to save space). AVR programmers tend to be somewhat lax about the difference between float and double. So, I could imagine that in the AVR specific section, they use float instead of double.
    Germany NRW
    5,679
    I'm still confused!
    Was i wrong with my previous posting or not ? This is no rhetorical question, really, i have problems to understand(=translating to german) your post #17.
    The name is DOUBLEtostrf() . Does it convert DOUBLE or FLOAT (i'm speaking of pauls version) ??
    Yes i know that double is the same as float on avr. But wer're talking about teensy3.
    Germany NRW
    5,679
    This is the Arduino-code for AVR_SAM, which is 32BIT too:
    https://github.com/arduino/ArduinoCo.../avr/dtostrf.c
    char *dtostrf (double val, signed char width, unsigned char prec, char *sout) {
      char fmt[20];
      sprintf(fmt, "%%%d.%df", width, prec);
      sprintf(sout, fmt, val);
      return sout;
    20,574
    Yes, exactly!
    I think it's important to keep in mind dtostrf() is AVR specific. While it could be useful on other platforms, the fact is it only exists on AVR. The avr-libc developers made it up. We're trying to emulate it on ARM only because some authors of Arduino sketches and libraries have used this AVR-only function.
    Since AVR only has single precision, I defined this function with float instead of double. The idea was to get as close as reasonably possible to what AVR actually provides. Ideally, I'd like to replace fcvt() with a single precision function. But not enough to write one myself!
    Germany NRW
    5,679
    just edit fcvt() to fcvtf()
    ok, i understand the compatibility-reason
    so, i'm right that the existing dtostrf really uses float and not double as Michael said ?
    Or did i understand him wrong ?
    Germany NRW
    5,679
    just to make it more clear: the fcvtf() is already existing.
    (This evening i'm a bit afraid that everybody is understanding me wrong.... perhaps i should go back to German forums..)
    Germany NRW
    5,679
    I'm now pause and hear some RAMSTEIN CDs
