Results 1 to 3 of 3
Thread: Teensy 2.0 Real Time clock
    7
    Is there anyway to get the Teensy 2.0 to keep time? With the Teensy 3.0 there is the ability to put a crystal and a backup battery. Can this be done with Teensy 2.0?
    You have to use an additional chip for that. Like a DS1307 or a DS3234. The DS1307 needs an additional crystal, and both need a power source to keep time when the teensy is not powered.
    Senior Member Constantin's Avatar
    In the yard with a 17' Dia. Ferris Wheel
    1,408
    Instead of the DS3234, I'd consider the I2C version, the DS3231. Much less fiddly to set IMO, just as accurate, and many commercially available solutions. I personally had great luck with the Chronodot from Macetech. All you need is two lines, two pullup resistors, and there are many libraries available.
