Results 1 to 3 of 3
Thread: Teensy 2.0 INT6 in Arduino
    1
    i'm using the small Teensy 2.0 and am not able to enable the INT6 (PE6). Reading works properly but interrupt is not fired. This pin is 10k pulled up and i tried to attach a falling signal interrupt - no luck :-(
    Reading the Pin works properly but polling is'n very cool - some keystroke will be lost... :-/
    Config: Arduino 1.0.2, current Tennsyduino
    any suggestion?
    Michael
    1
    Did you ever resolve this issue? I was also trying to use INT6 on the Teensy 2.0 and it failed to work.
    #define CH_PIN 24
    void setup(){
    pinMode(CH_PIN, INPUT);
    attachInterrupt(CH_PIN, CH, FALLING);
    Any help would be greatly appreciated.
    Best,
    Gabe
    Senior Member manitou's Avatar
    1,265
    The forum prefers you provide a full compilable sketch to verify your problems ...
    I don't think Teensy 2 has INT6, but Teensy++2.0 does, but it's on pin 18 (not 24). INT6 works for me with this test sketch
    volatile uint32_t dings;
    void ding() {
      dings++;
    void setup(){
     pinMode(18,INPUT_PULLUP);
     attachInterrupt(18,ding,FALLING);
     void loop(){
       Serial.println(dings);
       delay(2000);
Tags for this Thread
