I am keen to port this library so it compiles on the Teensy3.
https://github.com/snowshow/oscuino
I get "fatal error: usb_api.h: No such file or directory".
I have tried to replace usb_api.h with usb_serial.h but it will take more than that.
The library tests for (CORE_TEENSY) but needs to test for T3 and point to the correct headers.
For anyone interested in using OSCuino click here
It works a treat on the Teensy 2++. (using HardwareSerial.h)
"The SLIPSerial object has the same methods as the Serial object with an additional endTransmission method which sends the “End Of Transmission” character (octal 300) which is the message delimiter for the SLIP encoding."
I am hoping it is an easy fix as Serial already works great on the T3.
I have attached a copy of the library and code below
