Page 3 of 4 FirstFirst 1 2 3 4 LastLast
Results 51 to 75 of 88
Thread: Teensy 3 MicroSD guide
  1. #51
    San Francisco Bay Area
    641
    That's pretty cool!
    So you are using the SD adapter portion as a slot for exchanging the microSD card.
  2. #52
    Junior Member keeb's Avatar
    Dec 2013
    19
    Thanks. Yep, it can be used any way one would use any of the many SD breakout boards available (as long as it is used with 3.3v signals).
  3. #53
    Member dlchambers's Avatar
    Elkins, NH
    47
    Paul, could you kindly provide the mfr (Hirose?) and part # for the SD connector on the board?
    (board: http://www.pjrc.com/teensy/sd_adaptor.html)
    It kinda looks like this: http://www.digikey.com/product-detai...1CT-ND/1786515
  4. #54
    Dec 2013
    19
    I can't verify this, but in a separate thread it was said to be the Hirose DM3D-SF (the same one you've linked to).
  5. #55
    Oct 2014
    4
    If you use a 2-row pin header cut to size...
    ...and slightly bend the top pins inwards....
    ...you have a super-simple breadboard friendly SD adaptor that allows easy card insertion/removal.
  6. #56
    Oct 2014
    1
    I am using the cardinfo program but I get this error:
    Sd2Card.cpp:77:2: error: #error "MK20DX128 bus frequency must be 48 or 24 MHz"
    What do I need to change here to get rid of it?
  7. #57
    Senior Member sumotoy's Avatar
    Venezia, Italia
    421
    Quote Originally Posted by stim View Post
    I will like to thanks for this! It's the best SD holder I've tried and actually the only one that really works!
  8. #58
    Hello Paul,
    Adafruit 2.8" TLT & microSD pins to Teensy 3.1 - see sketch bellow;
    - is 3,3V needed ? and where to connect RST to Teensy
    Thanks,
    mike
  9. #59
    7,615
    Paul, can answer better than I can!
    The Reset Pin on the T3.1 is on the bottom of the board, with a small pad, that you can solder a wire to and then connect it to the Reset circuit. However warning, that pad is fragile and I have had the wire I soldered on the T3.1 pull the pad off on a couple of occasions. Alternatively there are spring loaded pins (pongo ?) that you can get that solder into the board and use spring pressure pushing up to make contact. I have not personally tried them yet. Not sure how much clearance these need on the top and bottom of the board to work.
    Good Luck.
  10. #60
    22,644
    On Arduino, the reset button has something of a dual personality. It can be used to put the Arduino into programming mode, or to reboot the board to your application, after a delay when the programming mode gives up.
    On Teensy, the programming mode doesn't time out. So you really need to decide what the purpose of the RST signal really is. Or you could design a jumper or switch onto your board, if you can't decide, or wish to change your mind later.
  11. #61
    I don't think my question was clear enough and therefore the answers are kind of confusing..
    Let me put the question this way:
    1) On Arduino Touch Shield 2.8" touch screen shield there is a microSD card socket installed and connected to the same pins (Pin 11, 12, 13) as the TFT (correct ??).
    In addition to this pins (11,12,13) ->> which TFT pins I need to wire-up to Teensy3.1 to get the SD card running?
    2) After studying the schematics from TFT 2.8" Touch ShielD I see that my above PCB wire up to Teensy3.1 is completly wrong becouse ICSP /SPI on TFT 2.8" I do not need to use because I have pins (Pin 11, 12, 13) already ready to use for SD but I need some additional
    --->> which ones would be needed to connect in addition to Teensy3.1??
    Thanks,
    Mike
  12. #62
    22,644
    Mike, which display are you using? I see "Adafruit 2.8" TLT & microSD" in msg #58 and "Arduino Touch Shield 2.8" touch screen shield" in msg #61. You mentioned the schematic too.
    Can you please post a link to the exact product you really have, and a direct link to its schematic. I can take a look and try to give you some specific advice. Direct links to the correct technical info would really help me to try to help you.
  13. #63
    Apr 2015
    1
    First, thanks Ztik for making the guide.
    Now my problem. I'm trying to use a microSD card (Samsung 16GB Evo SDHC) to record data from an MPU9250 from Invensense via Teensy 3.1. I've got everything wired up correctly, as far as I can tell and I've done about 10 times now, and I'm using the CardInfo example from Arduino. However, as I watch the serial monitor, it keeps saying that it can't find the microSD card. I've tried another card as well, no dice. I've contemplated using some of the clever ideas here in this thread utilizing microSD to SD adapters but the one that I have I need to read the data on my laptop from the microSD. Is there a way to tell if the Teensy adapter is faulty?
  14. #64
    Hello Paul,
    I am using 2.8TFT Touch Shield Arduino Resistive Touch ID: 1651 with micro SD.
    I have made a PinOut as per EagleCad from your web and MIRRORED the 2.8 as it is installed on my carrier PC board for Teensy3.1
ID:	4030 Name:  2,8TLT&Teensy31.png
    Pls refer as well to;
    https://forum.pjrc.com/threads/25718...9925#post69925 see #36& #37
    Here the overall picture in real life;
    I hope this will work now - I will need some support with the code for microSD and data-logging!!
    Thanks,
    Mike
  15. #65
    I connected the microUSB adapter hack (@keeb member) to OctoWS2811 + Teensy 3.1
    Uploaded the program VideoSDcard.ino using arduino 1.6.4
    The serial monitor prints "Could not access SD card"
    Do I need to cut the pins like suggested at
    https://github.com/PaulStoffregen/Oc...d/hardware.jpg
    PS. I ordered "WIZ820io & Micro SD Card Adaptor" but my project is in a rush and I cannot wait weeks for it to arrive.
  16. #66
    OK. it works.
    I connected the microUSB adapter hack to OctoWS2811 + Teensy 3.1 + VideoSDcard.ino
    Wiring:
    * The SD CS leg goes to OctoWS811 pin 4 (and not to 10, as the original example, which is good too, but for teensy only)
    * Followed the instructions at
    by
    disconnecting teensy pin 3 and pin 4 from octows2811, and
    attaching teensy pin 3 to octows2811 pin 4 and
    octows8211 pin 4 to SD CS.
    I had another problem with the program which used to hang on memcpy.
    I am using width 145 and height 24.
    To workaround this memory issue, I marked out the audio lines from the program, and it released some more memory, and now the program works with no issue.
  17. #67
    162
    I am having a problem increasing the buffer size for my microSD implementation.
    When I use a 1022byte buffer, everything works fine:
    Use a freshly formatted SD for best performance.
    Type any character to start
    Free RAM: 58235
    Type is FAT32
    Card size: 31.91 GB (GB = 1E9 bytes)
    Manufacturer ID: 0X3
    OEM ID: SD
    Product: SL32G
    Version: 8.0
    Serial number: 0X8D4E026
    Manufacturing date: 6/2014
    File size 1 MB
    Buffer size 1022 bytes
    Starting write test, please wait.
    write speed and latency
    speed,max,min,avg
    KB/Sec,usec,usec,usec
    324.31,130960,1268,3144
    Starting read test, please wait.
    read speed and latency
    speed,max,min,avg
    1177.29,4108,424,866
    1182.86,899,424,863
    1182.86,900,424,863
    1182.86,900,424,863
    1182.86,900,423,863
    but when I increase it to 1024, I get read errors (0x3, 0x7, sometimes 0x1, 0x3)
    Free RAM: 58235
    Type is FAT32
    OEM ID: SD
    Product: SL32G
    Version: 8.0
    File size 1 MB
    Buffer size 1024 bytes
    speed,max,min,avg
    426.92,132825,1544,2394
    speed,max,min,avg
    error: read failed
    SD errorCode: 0X3,0X7
    I am using a Sandisk Ultra 32Gb HC card. Is this a problem with my card? I only have one to test right now. I just ordered a samsung Evo to see if that helps my situation...
  18. #68
    Hope it is oké to reuse this threat for a question.
    I have a couple of Teensy 3.1 boards for a GPS logging project I started.
    On my breadboard I just used a DX/Banggood microSD adapters and before that just a soldered SD adapter.
    With my portable prototype I choose to use more PJRC and EU sourced parts.
    And now the trouble starts...
    The microSD cards I used on my breadboard didn't function in the PJRC sd-slot, after some searching I found this threat.
    Is there a simple way to get my other sd-card brands to work with the PJRC adapter or am I bounded to the Sandisk cards? (confirmed working)
    Or do I need to switch to the China sourced no-name sd-slot adapters?
    The small increase in investment when using the PJRC is not the issue, it's the loss of flexibility as it is quite possible my final design will ship across the globe.
    I can't guarantee that they will sell THAT sd-card in the country where I ship the unit to...
  19. #69
    Apr 2013
    1,936
    First up, is this the SD card socket with level converters? The Teensy3 runs at 3.3 volts natively so works fine connected directly to the SD card, where the SD adaptor boards level convert to 5V for the Teensy 1/2 and Uno.
    Otherwise most likely issue with SD cards is either incorrect formatting prior to using them or trying to use cards that are too large. I think there can also be issues using the latest high speed cards that try and run an internal clock as well. So you and your customers are not restricted to Sandisk, but are restricted to older(or at least cheaper spec) and smaller cards.
    See https://github.com/greiman/SdFat
    and
    http://www.arduino.cc/en/Reference/SDCardNotes
  20. #70
    It is the latest available for the Teensy 3 : http://floris.cc/shop/en/teensy/992-...d-adaptor.html
    Funny thing is that the cards that don't work are "old" Sandisk Premier TF 2GB and unbranded class-4 4GB models.
    Used them for XenServer in the past, so I formatted the old cards with the SdFat library to make sure/test they would function. (Formats correctly in the breadboard setup)
    Bought a new Transcend class-10/HC-1 16GB card yesterday to try something else, same issue... (Formats correctly in the breadboard setup)
    Card that is working is a SanDisk Ultra HC-1 16GB that I received months ago and normally use for my RPI-2
  21. #71
    Apr 2013
    1,936
    Ok, that one has a level converter on it so look like you have a couple of cards that can tolerate the out of spec voltages while the others can't. If you want you can covert that one by jumpering the level converter IC or keep it for another project and plan on using a straight card socket for your current design.
  22. #72
    At the backside there is an 3V solder option : http://floris.cc/shop/1290-thickbox_...rd-adaptor.jpg
    That one is closed already.
    Or do I need to change something else?
  23. #73
    Jun 2013
    So. Calif
    2,828
    uSD cards I work with are fine with 3.3V for Vcc
  24. #74
    1,408
    3.3V is not the issue. However, the current source may or may not have the oomph to make it happen. Running a TFT and a SD card off a Teensy power supply is unlikely to have a happy ending.
    For that reason, I always use a external voltage regulator and a series of capacitors (0.1 and 10uF) for a SD card power supply. I am also a big fan of the Yamaichi PTH micro-SD card holder. The only (AFAIK) through-hole micro-SD card holder available (PJS0008).
  25. #75
    Jun 2013
    So. Calif
    2,828
    I've seen uSD read mode power consumption of about 20-30mA and write mode 60-100mA. Sleep mode < 1mA. Indeed, uSD can be power hungry for a 100mA source with other loads too.
Tags for this Thread
