Build target All
ExternalBuildToolExecution All
cd /Users/duff/Documents/Arduino/embedXcode/test2/test2
setenv ACTION
setenv ALTERNATE_GROUP staff
setenv ALTERNATE_MODE u+w,go-w,a+rX
setenv ALTERNATE_OWNER duff
setenv ALWAYS_SEARCH_USER_PATHS NO
setenv APPLE_INTERNAL_DEVELOPER_DIR /AppleInternal/Developer
setenv APPLE_INTERNAL_DIR /AppleInternal
setenv APPLE_INTERNAL_DOCUMENTATION_DIR /AppleInternal/Documentation
setenv APPLE_INTERNAL_LIBRARY_DIR /AppleInternal/Library
setenv APPLE_INTERNAL_TOOLS /AppleInternal/Developer/Tools
setenv APPLY_RULES_IN_COPY_FILES NO
setenv ARCHS x86_64
setenv AVAILABLE_PLATFORMS "iphonesimulator macosx iphoneos"
setenv BOARD_PORT "/dev/tty.usbmodem*"
setenv BOARD_TAG teensy3
setenv BUILD_COMPONENTS "headers build"
setenv BUILD_DIR /Users/duff/Library/Developer/Xcode/DerivedData/test2-afukhabmrolvpgfljastacoxfiwt/Build/Products
setenv BUILD_ROOT /Users/duff/Library/Developer/Xcode/DerivedData/test2-afukhabmrolvpgfljastacoxfiwt/Build/Products
setenv BUILD_STYLE
setenv BUILD_VARIANTS normal
setenv BUILT_PRODUCTS_DIR /Users/duff/Library/Developer/Xcode/DerivedData/test2-afukhabmrolvpgfljastacoxfiwt/Build/Products/Debug
setenv CACHE_ROOT /var/folders/bj/vlzk0z7x3bqb_jzmz0k0vv2h0000gp/C/com.apple.DeveloperTools/5.0.2-5A3005/Xcode
setenv CLANG_CXX_LANGUAGE_STANDARD gnu++0x
setenv CLANG_CXX_LIBRARY libc++
setenv CLANG_ENABLE_OBJC_ARC YES
setenv CLANG_WARN_BOOL_CONVERSION YES
setenv CLANG_WARN_CONSTANT_CONVERSION YES
setenv CLANG_WARN_DIRECT_OBJC_ISA_USAGE YES_ERROR
setenv CLANG_WARN_EMPTY_BODY YES
setenv CLANG_WARN_ENUM_CONVERSION YES
setenv CLANG_WARN_INT_CONVERSION YES
setenv CLANG_WARN_OBJC_ROOT_CLASS YES_ERROR
setenv CLANG_WARN__DUPLICATE_METHOD_MATCH YES
setenv CLASS_FILE_DIR /Users/duff/Library/Developer/Xcode/DerivedData/test2-afukhabmrolvpgfljastacoxfiwt/Build/Intermediates/test2.build/Debug/All.build/JavaClasses
setenv CLONE_HEADERS NO
setenv CODE_SIGNING_ALLOWED NO
setenv COLOR_DIAGNOSTICS NO
setenv CONFIGURATION Debug
setenv CONFIGURATION_BUILD_DIR /Users/duff/Library/Developer/Xcode/DerivedData/test2-afukhabmrolvpgfljastacoxfiwt/Build/Products/Debug
setenv CONFIGURATION_TEMP_DIR /Users/duff/Library/Developer/Xcode/DerivedData/test2-afukhabmrolvpgfljastacoxfiwt/Build/Intermediates/test2.build/Debug
setenv COPYING_PRESERVES_HFS_DATA NO
setenv COPY_PHASE_STRIP NO
setenv CREATE_INFOPLIST_SECTION_IN_BINARY NO
setenv DEAD_CODE_STRIPPING NO
setenv DEBUGGING_SYMBOLS YES
setenv DEFAULT_COMPILER com.apple.compilers.llvm.clang.1_0
setenv DEFAULT_KEXT_INSTALL_PATH /Library/Extensions
setenv DEPLOYMENT_LOCATION NO
setenv DEPLOYMENT_POSTPROCESSING NO
setenv DERIVED_FILES_DIR
setenv DERIVED_FILE_DIR /Users/duff/Library/Developer/Xcode/DerivedData/test2-afukhabmrolvpgfljastacoxfiwt/Build/Intermediates/test2.build/Debug/All.build/DerivedSources
setenv DERIVED_SOURCES_DIR /Users/duff/Library/Developer/Xcode/DerivedData/test2-afukhabmrolvpgfljastacoxfiwt/Build/Intermediates/test2.build/Debug/All.build/DerivedSources
setenv DEVELOPER_APPLICATIONS_DIR /Applications/Xcode.app/Contents/Developer/Applications
setenv DEVELOPER_BIN_DIR /Applications/Xcode.app/Contents/Developer/usr/bin
setenv DEVELOPER_DIR /Applications/Xcode.app/Contents/Developer
setenv DEVELOPER_FRAMEWORKS_DIR /Applications/Xcode.app/Contents/Developer/Library/Frameworks
setenv DEVELOPER_FRAMEWORKS_DIR_QUOTED /Applications/Xcode.app/Contents/Developer/Library/Frameworks
setenv DEVELOPER_LIBRARY_DIR /Applications/Xcode.app/Contents/Developer/Library
setenv DEVELOPER_SDK_DIR /Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs
setenv DEVELOPER_TOOLS_DIR /Applications/Xcode.app/Contents/Developer/Tools
setenv DEVELOPER_USR_DIR /Applications/Xcode.app/Contents/Developer/usr
setenv DEVELOPMENT_LANGUAGE English
setenv DO_HEADER_SCANNING_IN_JAM NO
setenv DSTROOT /tmp/test2.dst
setenv DT_TOOLCHAIN_DIR /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain
setenv DWARF_DSYM_FILE_NAME .dSYM
setenv DWARF_DSYM_FILE_SHOULD_ACCOMPANY_PRODUCT NO
setenv DWARF_DSYM_FOLDER_PATH /Users/duff/Library/Developer/Xcode/DerivedData/test2-afukhabmrolvpgfljastacoxfiwt/Build/Products/Debug
setenv EMBEDDED_PROFILE_NAME embedded.provisionprofile
setenv ENABLE_HEADER_DEPENDENCIES YES
setenv EXCLUDED_INSTALLSRC_SUBDIRECTORY_PATTERNS ".DS_Store .svn .git .hg CVS"
setenv EXCLUDED_RECURSIVE_SEARCH_PATH_SUBDIRECTORIES "*.nib *.lproj *.framework *.gch *.xcode* (*) .DS_Store CVS .svn .git .hg"
setenv FILE_LIST /Users/duff/Library/Developer/Xcode/DerivedData/test2-afukhabmrolvpgfljastacoxfiwt/Build/Intermediates/test2.build/Debug/All.build/Objects/LinkFileList
setenv FRAMEWORK_VERSION A
setenv GCC3_VERSION 3.3
setenv GCC_C_LANGUAGE_STANDARD gnu99
setenv GCC_DYNAMIC_NO_PIC NO
setenv GCC_OPTIMIZATION_LEVEL 0
setenv GCC_PREPROCESSOR_DEFINITIONS "DEBUG=1 __MK20DX128__ CORE_TEENSY"
setenv GCC_SYMBOLS_PRIVATE_EXTERN NO
setenv GCC_VERSION com.apple.compilers.llvm.clang.1_0
setenv GCC_WARN_64_TO_32_BIT_CONVERSION YES
setenv GCC_WARN_ABOUT_RETURN_TYPE YES_ERROR
setenv GCC_WARN_UNDECLARED_SELECTOR YES
setenv GCC_WARN_UNINITIALIZED_AUTOS YES
setenv GCC_WARN_UNUSED_FUNCTION YES
setenv GCC_WARN_UNUSED_VARIABLE YES
setenv GENERATE_MASTER_OBJECT_FILE NO
setenv GENERATE_PKGINFO_FILE NO
setenv GID 20
setenv GROUP staff
setenv HEADERMAP_INCLUDES_FLAT_ENTRIES_FOR_TARGET_BEING_BUILT YES
setenv HEADERMAP_INCLUDES_FRAMEWORK_ENTRIES_FOR_ALL_PRODUCT_TYPES YES
setenv HEADERMAP_INCLUDES_NONPUBLIC_NONPRIVATE_HEADERS YES
setenv HEADERMAP_INCLUDES_PROJECT_HEADERS YES
setenv HEADER_SEARCH_PATHS "/** /Libraries/**"
setenv INFOPLIST_EXPAND_BUILD_SETTINGS YES
setenv INFOPLIST_OUTPUT_FORMAT same-as-input
setenv INFOPLIST_PREPROCESS NO
setenv INSTALL_DIR /tmp/test2.dst
setenv INSTALL_GROUP staff
setenv INSTALL_MODE_FLAG u+w,go-w,a+rX
setenv INSTALL_OWNER duff
setenv INSTALL_ROOT /tmp/test2.dst
setenv JAVA_APP_STUB /System/Library/Frameworks/JavaVM.framework/Resources/MacOS/JavaApplicationStub
setenv JAVA_ARCHIVE_CLASSES YES
setenv JAVA_ARCHIVE_TYPE JAR
setenv JAVA_COMPILER /usr/bin/javac
setenv JAVA_FRAMEWORK_RESOURCES_DIRS Resources
setenv JAVA_JAR_FLAGS cv
setenv JAVA_SOURCE_SUBDIR .
setenv JAVA_USE_DEPENDENCIES YES
setenv JAVA_ZIP_FLAGS -urg
setenv KEEP_PRIVATE_EXTERNS NO
setenv LD_DEPENDENCY_INFO_FILE //All_dependency_info.dat
setenv LD_GENERATE_MAP_FILE NO
setenv LD_MAP_FILE_PATH /Users/duff/Library/Developer/Xcode/DerivedData/test2-afukhabmrolvpgfljastacoxfiwt/Build/Intermediates/test2.build/Debug/All.build/All-LinkMap--.txt
setenv LD_NO_PIE NO
setenv LD_QUOTE_LINKER_ARGUMENTS_FOR_COMPILER_DRIVER YES
setenv LEGACY_DEVELOPER_DIR /Applications/Xcode.app/Contents/PlugIns/Xcode3Core.ideplugin/Contents/SharedSupport/Developer
setenv LIBRARY_FLAG_NOSPACE YES
setenv LIBRARY_KEXT_INSTALL_PATH /Library/Extensions
setenv LINKER_DISPLAYS_MANGLED_NAMES NO
setenv LINK_WITH_STANDARD_LIBRARIES YES
setenv LOCAL_ADMIN_APPS_DIR /Applications/Utilities
setenv LOCAL_APPS_DIR /Applications
setenv LOCAL_DEVELOPER_DIR /Library/Developer
setenv LOCAL_LIBRARY_DIR /Library
setenv MACOSX_DEPLOYMENT_TARGET 10.9
setenv MAC_OS_X_PRODUCT_BUILD_VERSION 12F45
setenv MAC_OS_X_VERSION_ACTUAL 1085
setenv MAC_OS_X_VERSION_MAJOR 1080
setenv MAC_OS_X_VERSION_MINOR 0805
setenv MODULE_CACHE_DIR /Users/duff/Library/Developer/Xcode/DerivedData/ModuleCache
setenv OBJECT_FILE_DIR /Users/duff/Library/Developer/Xcode/DerivedData/test2-afukhabmrolvpgfljastacoxfiwt/Build/Intermediates/test2.build/Debug/All.build/Objects
setenv OBJROOT /Users/duff/Library/Developer/Xcode/DerivedData/test2-afukhabmrolvpgfljastacoxfiwt/Build/Intermediates
setenv ONLY_ACTIVE_ARCH NO
setenv OPTIMIZATION_LEVEL 0
setenv OS MACOS
setenv PATH "/Applications/Xcode.app/Contents/Developer/usr/bin:/usr/bin:/bin:/usr/sbin:/sbin:/Users/duff/Documents/Arduino/embedXcode/test2"
setenv PATH_PREFIXES_EXCLUDED_FROM_HEADER_DEPENDENCIES "/usr/include /usr/local/include /System/Library/Frameworks /System/Library/PrivateFrameworks /Applications/Xcode.app/Contents/Developer/Headers /Applications/Xcode.app/Contents/Developer/SDKs /Applications/Xcode.app/Contents/Developer/Platforms"
setenv PLATFORM_NAME macosx
setenv PLIST_FILE_OUTPUT_FORMAT same-as-input
setenv PRECOMPS_INCLUDE_HEADERS_FROM_BUILT_PRODUCTS_DIR YES
setenv PRECOMP_DESTINATION_DIR /Users/duff/Library/Developer/Xcode/DerivedData/test2-afukhabmrolvpgfljastacoxfiwt/Build/Intermediates/test2.build/Debug/All.build/PrefixHeaders
setenv PRESERVE_DEAD_CODE_INITS_AND_TERMS NO
setenv PRODUCT_NAME All
setenv PROFILING_CODE NO
setenv PROJECT test2
setenv PROJECT_DERIVED_FILE_DIR /Users/duff/Library/Developer/Xcode/DerivedData/test2-afukhabmrolvpgfljastacoxfiwt/Build/Intermediates/test2.build/DerivedSources
setenv PROJECT_DIR /Users/duff/Documents/Arduino/embedXcode/test2
setenv PROJECT_FILE_PATH /Users/duff/Documents/Arduino/embedXcode/test2/test2.xcodeproj
setenv PROJECT_NAME test2
setenv PROJECT_TEMP_DIR /Users/duff/Library/Developer/Xcode/DerivedData/test2-afukhabmrolvpgfljastacoxfiwt/Build/Intermediates/test2.build
setenv PROJECT_TEMP_ROOT /Users/duff/Library/Developer/Xcode/DerivedData/test2-afukhabmrolvpgfljastacoxfiwt/Build/Intermediates
setenv REMOVE_CVS_FROM_RESOURCES YES
setenv REMOVE_GIT_FROM_RESOURCES YES
setenv REMOVE_HG_FROM_RESOURCES YES
setenv REMOVE_SVN_FROM_RESOURCES YES
setenv SCAN_ALL_SOURCE_FILES_FOR_INCLUDES NO
setenv SDKROOT
setenv SEPARATE_STRIP NO
setenv SEPARATE_SYMBOL_EDIT NO
setenv SHARED_DERIVED_FILE_DIR /Users/duff/Library/Developer/Xcode/DerivedData/test2-afukhabmrolvpgfljastacoxfiwt/Build/Products/Debug/DerivedSources
setenv SHARED_PRECOMPS_DIR /Users/duff/Library/Developer/Xcode/DerivedData/test2-afukhabmrolvpgfljastacoxfiwt/Build/Intermediates/PrecompiledHeaders
setenv SKETCH_EXTENSION ino
setenv SKIP_INSTALL YES
setenv SOURCE_ROOT /Users/duff/Documents/Arduino/embedXcode/test2
setenv SRCROOT /Users/duff/Documents/Arduino/embedXcode/test2
setenv STRINGS_FILE_OUTPUT_ENCODING UTF-16
setenv STRIP_INSTALLED_PRODUCT YES
setenv STRIP_STYLE all
setenv SUPPORTED_PLATFORMS macosx
setenv SYMROOT /Users/duff/Library/Developer/Xcode/DerivedData/test2-afukhabmrolvpgfljastacoxfiwt/Build/Products
setenv SYSTEM_ADMIN_APPS_DIR /Applications/Utilities
setenv SYSTEM_APPS_DIR /Applications
setenv SYSTEM_CORE_SERVICES_DIR /System/Library/CoreServices
setenv SYSTEM_DEMOS_DIR /Applications/Extras
setenv SYSTEM_DEVELOPER_APPS_DIR /Applications/Xcode.app/Contents/Developer/Applications
setenv SYSTEM_DEVELOPER_BIN_DIR /Applications/Xcode.app/Contents/Developer/usr/bin
setenv SYSTEM_DEVELOPER_DEMOS_DIR "/Applications/Xcode.app/Contents/Developer/Applications/Utilities/Built Examples"
setenv SYSTEM_DEVELOPER_DIR /Applications/Xcode.app/Contents/Developer
setenv SYSTEM_DEVELOPER_DOC_DIR "/Applications/Xcode.app/Contents/Developer/ADC Reference Library"
setenv SYSTEM_DEVELOPER_GRAPHICS_TOOLS_DIR "/Applications/Xcode.app/Contents/Developer/Applications/Graphics Tools"
setenv SYSTEM_DEVELOPER_JAVA_TOOLS_DIR "/Applications/Xcode.app/Contents/Developer/Applications/Java Tools"
setenv SYSTEM_DEVELOPER_PERFORMANCE_TOOLS_DIR "/Applications/Xcode.app/Contents/Developer/Applications/Performance Tools"
setenv SYSTEM_DEVELOPER_RELEASENOTES_DIR "/Applications/Xcode.app/Contents/Developer/ADC Reference Library/releasenotes"
setenv SYSTEM_DEVELOPER_TOOLS /Applications/Xcode.app/Contents/Developer/Tools
setenv SYSTEM_DEVELOPER_TOOLS_DOC_DIR "/Applications/Xcode.app/Contents/Developer/ADC Reference Library/documentation/DeveloperTools"
setenv SYSTEM_DEVELOPER_TOOLS_RELEASENOTES_DIR "/Applications/Xcode.app/Contents/Developer/ADC Reference Library/releasenotes/DeveloperTools"
setenv SYSTEM_DEVELOPER_USR_DIR /Applications/Xcode.app/Contents/Developer/usr
setenv SYSTEM_DEVELOPER_UTILITIES_DIR /Applications/Xcode.app/Contents/Developer/Applications/Utilities
setenv SYSTEM_DOCUMENTATION_DIR /Library/Documentation
setenv SYSTEM_KEXT_INSTALL_PATH /System/Library/Extensions
setenv SYSTEM_LIBRARY_DIR /System/Library
setenv TARGETNAME All
setenv TARGET_BUILD_DIR /Users/duff/Library/Developer/Xcode/DerivedData/test2-afukhabmrolvpgfljastacoxfiwt/Build/Products/Debug
setenv TARGET_NAME All
setenv TARGET_TEMP_DIR /Users/duff/Library/Developer/Xcode/DerivedData/test2-afukhabmrolvpgfljastacoxfiwt/Build/Intermediates/test2.build/Debug/All.build
setenv TEMP_DIR /Users/duff/Library/Developer/Xcode/DerivedData/test2-afukhabmrolvpgfljastacoxfiwt/Build/Intermediates/test2.build/Debug/All.build
setenv TEMP_FILES_DIR
setenv TEMP_FILE_DIR /Users/duff/Library/Developer/Xcode/DerivedData/test2-afukhabmrolvpgfljastacoxfiwt/Build/Intermediates/test2.build/Debug/All.build
setenv TEMP_ROOT /Users/duff/Library/Developer/Xcode/DerivedData/test2-afukhabmrolvpgfljastacoxfiwt/Build/Intermediates
setenv UID 502
setenv USER duff
setenv USER_APPS_DIR /Users/duff/Applications
setenv USER_LIBRARY_DIR /Users/duff/Library
setenv XCODE_APP_SUPPORT_DIR /Applications/Xcode.app/Contents/Developer/Library/Xcode
setenv XCODE_PRODUCT_BUILD_VERSION 5A3005
setenv XCODE_VERSION_ACTUAL 0502
setenv XCODE_VERSION_MAJOR 0500
setenv XCODE_VERSION_MINOR 0500
setenv arch x86_64
setenv variant normal
make all
embedXcode
embedXcode+
Embedded Computing on Xcode
© Rei VILO, 2010-2014
All rights reserved
http://embedXcode.weebly.com/
embedXcode • Jan 28, 2014 release 128 • Support for Arduino Yún with USB
embedXcode+ • Jan 28, 2014 release 128 • Support for Arduino Yún with USB Ethernet WiFi
Have you contributed? Thanks!
==== Info ====
---- Project ----
Target all
Name test2
Tag teensy3
Extension ino
User /Users/duff/
---- Platform ----
IDE Teensy
Version 1.0.5
Platform arm
---- Board ----
Name Teensy 3.0
Frequency 24000000
MCU cortex-m4
Flash memory 131072 bytes
SRAM memory 16384 bytes
---- Port ----
Uploader teensy_flash
Serial
---- Libraries ----
. Core libraries
Arduino AudioStream Client HardwareSerial IPAddress IntervalTimer Print Printable SPIFIFO Server Stream Udp WCharacter WConstants WProgram WString arm_common_tables arm_math avr_emulation avr_functions binary core_cm4 core_cm4_simd core_cmInstr core_id core_pins elapsedMillis keylayouts math_helper mk20dx128 new pins_arduino usb_desc usb_dev usb_flightsim usb_joystick usb_keyboard usb_mem usb_midi usb_mouse usb_names usb_rawhid usb_seremu usb_serial wiring wiring_private
. Application libraries of Arduino/chipKIT/Digispark/Energia/Maple/Microduino/Teensy/Wiring
. User libraries from /Users/duff/Documents/Arduino
. Local libraries from /Users/duff/Documents/Arduino/embedXcode/test2/test2
LocalLibrary
==== Info done ====
==== All ====
---- Clean ----
---- Compile ----
1.1-CORE: .o < .c teensy3 Builds/ analog.c
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/arm-none-eabi/bin/arm-none-eabi-gcc -c -mcpu=cortex-m4 -DF_CPU=24000000 -I/Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy3 -g -Os -w -Wall -ffunction-sections -fdata-sections -DARDUINO=105 -DCORE_TEENSY -DEMBEDXCODE=128 -D__MK20DX128__ -nostdlib -mthumb -MMD -DUSB_VID=null -DUSB_PID=null -DUSB_SERIAL -DLAYOUT_US_ENGLISH -DTIME_T=1391190454 /Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy3/analog.c -o Builds/analog.o
1.1-CORE: .o < .c teensy3 Builds/ eeprom.c
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/arm-none-eabi/bin/arm-none-eabi-gcc -c -mcpu=cortex-m4 -DF_CPU=24000000 -I/Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy3 -g -Os -w -Wall -ffunction-sections -fdata-sections -DARDUINO=105 -DCORE_TEENSY -DEMBEDXCODE=128 -D__MK20DX128__ -nostdlib -mthumb -MMD -DUSB_VID=null -DUSB_PID=null -DUSB_SERIAL -DLAYOUT_US_ENGLISH -DTIME_T=1391190454 /Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy3/eeprom.c -o Builds/eeprom.o
1.1-CORE: .o < .c teensy3 Builds/ keylayouts.c
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/arm-none-eabi/bin/arm-none-eabi-gcc -c -mcpu=cortex-m4 -DF_CPU=24000000 -I/Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy3 -g -Os -w -Wall -ffunction-sections -fdata-sections -DARDUINO=105 -DCORE_TEENSY -DEMBEDXCODE=128 -D__MK20DX128__ -nostdlib -mthumb -MMD -DUSB_VID=null -DUSB_PID=null -DUSB_SERIAL -DLAYOUT_US_ENGLISH -DTIME_T=1391190454 /Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy3/keylayouts.c -o Builds/keylayouts.o
1.1-CORE: .o < .c teensy3 Builds/ math_helper.c
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/arm-none-eabi/bin/arm-none-eabi-gcc -c -mcpu=cortex-m4 -DF_CPU=24000000 -I/Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy3 -g -Os -w -Wall -ffunction-sections -fdata-sections -DARDUINO=105 -DCORE_TEENSY -DEMBEDXCODE=128 -D__MK20DX128__ -nostdlib -mthumb -MMD -DUSB_VID=null -DUSB_PID=null -DUSB_SERIAL -DLAYOUT_US_ENGLISH -DTIME_T=1391190454 /Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy3/math_helper.c -o Builds/math_helper.o
1.1-CORE: .o < .c teensy3 Builds/ mk20dx128.c
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/arm-none-eabi/bin/arm-none-eabi-gcc -c -mcpu=cortex-m4 -DF_CPU=24000000 -I/Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy3 -g -Os -w -Wall -ffunction-sections -fdata-sections -DARDUINO=105 -DCORE_TEENSY -DEMBEDXCODE=128 -D__MK20DX128__ -nostdlib -mthumb -MMD -DUSB_VID=null -DUSB_PID=null -DUSB_SERIAL -DLAYOUT_US_ENGLISH -DTIME_T=1391190454 /Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy3/mk20dx128.c -o Builds/mk20dx128.o
1.1-CORE: .o < .c teensy3 Builds/ nonstd.c
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/arm-none-eabi/bin/arm-none-eabi-gcc -c -mcpu=cortex-m4 -DF_CPU=24000000 -I/Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy3 -g -Os -w -Wall -ffunction-sections -fdata-sections -DARDUINO=105 -DCORE_TEENSY -DEMBEDXCODE=128 -D__MK20DX128__ -nostdlib -mthumb -MMD -DUSB_VID=null -DUSB_PID=null -DUSB_SERIAL -DLAYOUT_US_ENGLISH -DTIME_T=1391190454 /Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy3/nonstd.c -o Builds/nonstd.o
1.1-CORE: .o < .c teensy3 Builds/ pins_teensy.c
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/arm-none-eabi/bin/arm-none-eabi-gcc -c -mcpu=cortex-m4 -DF_CPU=24000000 -I/Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy3 -g -Os -w -Wall -ffunction-sections -fdata-sections -DARDUINO=105 -DCORE_TEENSY -DEMBEDXCODE=128 -D__MK20DX128__ -nostdlib -mthumb -MMD -DUSB_VID=null -DUSB_PID=null -DUSB_SERIAL -DLAYOUT_US_ENGLISH -DTIME_T=1391190454 /Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy3/pins_teensy.c -o Builds/pins_teensy.o
1.1-CORE: .o < .c teensy3 Builds/ serial1.c
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/arm-none-eabi/bin/arm-none-eabi-gcc -c -mcpu=cortex-m4 -DF_CPU=24000000 -I/Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy3 -g -Os -w -Wall -ffunction-sections -fdata-sections -DARDUINO=105 -DCORE_TEENSY -DEMBEDXCODE=128 -D__MK20DX128__ -nostdlib -mthumb -MMD -DUSB_VID=null -DUSB_PID=null -DUSB_SERIAL -DLAYOUT_US_ENGLISH -DTIME_T=1391190454 /Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy3/serial1.c -o Builds/serial1.o
1.1-CORE: .o < .c teensy3 Builds/ serial2.c
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/arm-none-eabi/bin/arm-none-eabi-gcc -c -mcpu=cortex-m4 -DF_CPU=24000000 -I/Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy3 -g -Os -w -Wall -ffunction-sections -fdata-sections -DARDUINO=105 -DCORE_TEENSY -DEMBEDXCODE=128 -D__MK20DX128__ -nostdlib -mthumb -MMD -DUSB_VID=null -DUSB_PID=null -DUSB_SERIAL -DLAYOUT_US_ENGLISH -DTIME_T=1391190454 /Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy3/serial2.c -o Builds/serial2.o
1.1-CORE: .o < .c teensy3 Builds/ serial3.c
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/arm-none-eabi/bin/arm-none-eabi-gcc -c -mcpu=cortex-m4 -DF_CPU=24000000 -I/Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy3 -g -Os -w -Wall -ffunction-sections -fdata-sections -DARDUINO=105 -DCORE_TEENSY -DEMBEDXCODE=128 -D__MK20DX128__ -nostdlib -mthumb -MMD -DUSB_VID=null -DUSB_PID=null -DUSB_SERIAL -DLAYOUT_US_ENGLISH -DTIME_T=1391190454 /Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy3/serial3.c -o Builds/serial3.o
1.1-CORE: .o < .c teensy3 Builds/ touch.c
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/arm-none-eabi/bin/arm-none-eabi-gcc -c -mcpu=cortex-m4 -DF_CPU=24000000 -I/Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy3 -g -Os -w -Wall -ffunction-sections -fdata-sections -DARDUINO=105 -DCORE_TEENSY -DEMBEDXCODE=128 -D__MK20DX128__ -nostdlib -mthumb -MMD -DUSB_VID=null -DUSB_PID=null -DUSB_SERIAL -DLAYOUT_US_ENGLISH -DTIME_T=1391190455 /Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy3/touch.c -o Builds/touch.o
1.1-CORE: .o < .c teensy3 Builds/ usb_desc.c
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/arm-none-eabi/bin/arm-none-eabi-gcc -c -mcpu=cortex-m4 -DF_CPU=24000000 -I/Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy3 -g -Os -w -Wall -ffunction-sections -fdata-sections -DARDUINO=105 -DCORE_TEENSY -DEMBEDXCODE=128 -D__MK20DX128__ -nostdlib -mthumb -MMD -DUSB_VID=null -DUSB_PID=null -DUSB_SERIAL -DLAYOUT_US_ENGLISH -DTIME_T=1391190455 /Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy3/usb_desc.c -o Builds/usb_desc.o
1.1-CORE: .o < .c teensy3 Builds/ usb_dev.c
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/arm-none-eabi/bin/arm-none-eabi-gcc -c -mcpu=cortex-m4 -DF_CPU=24000000 -I/Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy3 -g -Os -w -Wall -ffunction-sections -fdata-sections -DARDUINO=105 -DCORE_TEENSY -DEMBEDXCODE=128 -D__MK20DX128__ -nostdlib -mthumb -MMD -DUSB_VID=null -DUSB_PID=null -DUSB_SERIAL -DLAYOUT_US_ENGLISH -DTIME_T=1391190455 /Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy3/usb_dev.c -o Builds/usb_dev.o
1.1-CORE: .o < .c teensy3 Builds/ usb_joystick.c
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/arm-none-eabi/bin/arm-none-eabi-gcc -c -mcpu=cortex-m4 -DF_CPU=24000000 -I/Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy3 -g -Os -w -Wall -ffunction-sections -fdata-sections -DARDUINO=105 -DCORE_TEENSY -DEMBEDXCODE=128 -D__MK20DX128__ -nostdlib -mthumb -MMD -DUSB_VID=null -DUSB_PID=null -DUSB_SERIAL -DLAYOUT_US_ENGLISH -DTIME_T=1391190455 /Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy3/usb_joystick.c -o Builds/usb_joystick.o
1.1-CORE: .o < .c teensy3 Builds/ usb_keyboard.c
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/arm-none-eabi/bin/arm-none-eabi-gcc -c -mcpu=cortex-m4 -DF_CPU=24000000 -I/Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy3 -g -Os -w -Wall -ffunction-sections -fdata-sections -DARDUINO=105 -DCORE_TEENSY -DEMBEDXCODE=128 -D__MK20DX128__ -nostdlib -mthumb -MMD -DUSB_VID=null -DUSB_PID=null -DUSB_SERIAL -DLAYOUT_US_ENGLISH -DTIME_T=1391190455 /Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy3/usb_keyboard.c -o Builds/usb_keyboard.o
1.1-CORE: .o < .c teensy3 Builds/ usb_mem.c
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/arm-none-eabi/bin/arm-none-eabi-gcc -c -mcpu=cortex-m4 -DF_CPU=24000000 -I/Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy3 -g -Os -w -Wall -ffunction-sections -fdata-sections -DARDUINO=105 -DCORE_TEENSY -DEMBEDXCODE=128 -D__MK20DX128__ -nostdlib -mthumb -MMD -DUSB_VID=null -DUSB_PID=null -DUSB_SERIAL -DLAYOUT_US_ENGLISH -DTIME_T=1391190455 /Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy3/usb_mem.c -o Builds/usb_mem.o
1.1-CORE: .o < .c teensy3 Builds/ usb_midi.c
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/arm-none-eabi/bin/arm-none-eabi-gcc -c -mcpu=cortex-m4 -DF_CPU=24000000 -I/Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy3 -g -Os -w -Wall -ffunction-sections -fdata-sections -DARDUINO=105 -DCORE_TEENSY -DEMBEDXCODE=128 -D__MK20DX128__ -nostdlib -mthumb -MMD -DUSB_VID=null -DUSB_PID=null -DUSB_SERIAL -DLAYOUT_US_ENGLISH -DTIME_T=1391190455 /Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy3/usb_midi.c -o Builds/usb_midi.o
1.1-CORE: .o < .c teensy3 Builds/ usb_mouse.c
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/arm-none-eabi/bin/arm-none-eabi-gcc -c -mcpu=cortex-m4 -DF_CPU=24000000 -I/Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy3 -g -Os -w -Wall -ffunction-sections -fdata-sections -DARDUINO=105 -DCORE_TEENSY -DEMBEDXCODE=128 -D__MK20DX128__ -nostdlib -mthumb -MMD -DUSB_VID=null -DUSB_PID=null -DUSB_SERIAL -DLAYOUT_US_ENGLISH -DTIME_T=1391190455 /Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy3/usb_mouse.c -o Builds/usb_mouse.o
1.1-CORE: .o < .c teensy3 Builds/ usb_rawhid.c
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/arm-none-eabi/bin/arm-none-eabi-gcc -c -mcpu=cortex-m4 -DF_CPU=24000000 -I/Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy3 -g -Os -w -Wall -ffunction-sections -fdata-sections -DARDUINO=105 -DCORE_TEENSY -DEMBEDXCODE=128 -D__MK20DX128__ -nostdlib -mthumb -MMD -DUSB_VID=null -DUSB_PID=null -DUSB_SERIAL -DLAYOUT_US_ENGLISH -DTIME_T=1391190455 /Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy3/usb_rawhid.c -o Builds/usb_rawhid.o
1.1-CORE: .o < .c teensy3 Builds/ usb_seremu.c
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/arm-none-eabi/bin/arm-none-eabi-gcc -c -mcpu=cortex-m4 -DF_CPU=24000000 -I/Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy3 -g -Os -w -Wall -ffunction-sections -fdata-sections -DARDUINO=105 -DCORE_TEENSY -DEMBEDXCODE=128 -D__MK20DX128__ -nostdlib -mthumb -MMD -DUSB_VID=null -DUSB_PID=null -DUSB_SERIAL -DLAYOUT_US_ENGLISH -DTIME_T=1391190455 /Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy3/usb_seremu.c -o Builds/usb_seremu.o
1.1-CORE: .o < .c teensy3 Builds/ usb_serial.c
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/arm-none-eabi/bin/arm-none-eabi-gcc -c -mcpu=cortex-m4 -DF_CPU=24000000 -I/Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy3 -g -Os -w -Wall -ffunction-sections -fdata-sections -DARDUINO=105 -DCORE_TEENSY -DEMBEDXCODE=128 -D__MK20DX128__ -nostdlib -mthumb -MMD -DUSB_VID=null -DUSB_PID=null -DUSB_SERIAL -DLAYOUT_US_ENGLISH -DTIME_T=1391190455 /Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy3/usb_serial.c -o Builds/usb_serial.o
1.1-CORE: .o < .c teensy3 Builds/ yield.c
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/arm-none-eabi/bin/arm-none-eabi-gcc -c -mcpu=cortex-m4 -DF_CPU=24000000 -I/Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy3 -g -Os -w -Wall -ffunction-sections -fdata-sections -DARDUINO=105 -DCORE_TEENSY -DEMBEDXCODE=128 -D__MK20DX128__ -nostdlib -mthumb -MMD -DUSB_VID=null -DUSB_PID=null -DUSB_SERIAL -DLAYOUT_US_ENGLISH -DTIME_T=1391190455 /Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy3/yield.c -o Builds/yield.o
1.3-CORE: .o < .cpp teensy3 Builds/ AudioStream.cpp
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/arm-none-eabi/bin/arm-none-eabi-g++ -c -mcpu=cortex-m4 -DF_CPU=24000000 -I/Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy3 -g -Os -w -Wall -ffunction-sections -fdata-sections -DARDUINO=105 -DCORE_TEENSY -DEMBEDXCODE=128 -D__MK20DX128__ -nostdlib -mthumb -MMD -DUSB_VID=null -DUSB_PID=null -DUSB_SERIAL -DLAYOUT_US_ENGLISH -DTIME_T=1391190455 /Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy3/AudioStream.cpp -o Builds/AudioStream.o
1.3-CORE: .o < .cpp teensy3 Builds/ HardwareSerial1.cpp
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/arm-none-eabi/bin/arm-none-eabi-g++ -c -mcpu=cortex-m4 -DF_CPU=24000000 -I/Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy3 -g -Os -w -Wall -ffunction-sections -fdata-sections -DARDUINO=105 -DCORE_TEENSY -DEMBEDXCODE=128 -D__MK20DX128__ -nostdlib -mthumb -MMD -DUSB_VID=null -DUSB_PID=null -DUSB_SERIAL -DLAYOUT_US_ENGLISH -DTIME_T=1391190455 /Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy3/HardwareSerial1.cpp -o Builds/HardwareSerial1.o
1.3-CORE: .o < .cpp teensy3 Builds/ HardwareSerial2.cpp
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/arm-none-eabi/bin/arm-none-eabi-g++ -c -mcpu=cortex-m4 -DF_CPU=24000000 -I/Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy3 -g -Os -w -Wall -ffunction-sections -fdata-sections -DARDUINO=105 -DCORE_TEENSY -DEMBEDXCODE=128 -D__MK20DX128__ -nostdlib -mthumb -MMD -DUSB_VID=null -DUSB_PID=null -DUSB_SERIAL -DLAYOUT_US_ENGLISH -DTIME_T=1391190455 /Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy3/HardwareSerial2.cpp -o Builds/HardwareSerial2.o
1.3-CORE: .o < .cpp teensy3 Builds/ HardwareSerial3.cpp
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/arm-none-eabi/bin/arm-none-eabi-g++ -c -mcpu=cortex-m4 -DF_CPU=24000000 -I/Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy3 -g -Os -w -Wall -ffunction-sections -fdata-sections -DARDUINO=105 -DCORE_TEENSY -DEMBEDXCODE=128 -D__MK20DX128__ -nostdlib -mthumb -MMD -DUSB_VID=null -DUSB_PID=null -DUSB_SERIAL -DLAYOUT_US_ENGLISH -DTIME_T=1391190456 /Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy3/HardwareSerial3.cpp -o Builds/HardwareSerial3.o
1.3-CORE: .o < .cpp teensy3 Builds/ IPAddress.cpp
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/arm-none-eabi/bin/arm-none-eabi-g++ -c -mcpu=cortex-m4 -DF_CPU=24000000 -I/Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy3 -g -Os -w -Wall -ffunction-sections -fdata-sections -DARDUINO=105 -DCORE_TEENSY -DEMBEDXCODE=128 -D__MK20DX128__ -nostdlib -mthumb -MMD -DUSB_VID=null -DUSB_PID=null -DUSB_SERIAL -DLAYOUT_US_ENGLISH -DTIME_T=1391190456 /Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy3/IPAddress.cpp -o Builds/IPAddress.o
1.3-CORE: .o < .cpp teensy3 Builds/ IntervalTimer.cpp
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/arm-none-eabi/bin/arm-none-eabi-g++ -c -mcpu=cortex-m4 -DF_CPU=24000000 -I/Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy3 -g -Os -w -Wall -ffunction-sections -fdata-sections -DARDUINO=105 -DCORE_TEENSY -DEMBEDXCODE=128 -D__MK20DX128__ -nostdlib -mthumb -MMD -DUSB_VID=null -DUSB_PID=null -DUSB_SERIAL -DLAYOUT_US_ENGLISH -DTIME_T=1391190456 /Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy3/IntervalTimer.cpp -o Builds/IntervalTimer.o
1.3-CORE: .o < .cpp teensy3 Builds/ Print.cpp
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/arm-none-eabi/bin/arm-none-eabi-g++ -c -mcpu=cortex-m4 -DF_CPU=24000000 -I/Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy3 -g -Os -w -Wall -ffunction-sections -fdata-sections -DARDUINO=105 -DCORE_TEENSY -DEMBEDXCODE=128 -D__MK20DX128__ -nostdlib -mthumb -MMD -DUSB_VID=null -DUSB_PID=null -DUSB_SERIAL -DLAYOUT_US_ENGLISH -DTIME_T=1391190456 /Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy3/Print.cpp -o Builds/Print.o
1.3-CORE: .o < .cpp teensy3 Builds/ Stream.cpp
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/arm-none-eabi/bin/arm-none-eabi-g++ -c -mcpu=cortex-m4 -DF_CPU=24000000 -I/Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy3 -g -Os -w -Wall -ffunction-sections -fdata-sections -DARDUINO=105 -DCORE_TEENSY -DEMBEDXCODE=128 -D__MK20DX128__ -nostdlib -mthumb -MMD -DUSB_VID=null -DUSB_PID=null -DUSB_SERIAL -DLAYOUT_US_ENGLISH -DTIME_T=1391190456 /Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy3/Stream.cpp -o Builds/Stream.o
1.3-CORE: .o < .cpp teensy3 Builds/ Tone.cpp
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/arm-none-eabi/bin/arm-none-eabi-g++ -c -mcpu=cortex-m4 -DF_CPU=24000000 -I/Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy3 -g -Os -w -Wall -ffunction-sections -fdata-sections -DARDUINO=105 -DCORE_TEENSY -DEMBEDXCODE=128 -D__MK20DX128__ -nostdlib -mthumb -MMD -DUSB_VID=null -DUSB_PID=null -DUSB_SERIAL -DLAYOUT_US_ENGLISH -DTIME_T=1391190456 /Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy3/Tone.cpp -o Builds/Tone.o
1.3-CORE: .o < .cpp teensy3 Builds/ WMath.cpp
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/arm-none-eabi/bin/arm-none-eabi-g++ -c -mcpu=cortex-m4 -DF_CPU=24000000 -I/Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy3 -g -Os -w -Wall -ffunction-sections -fdata-sections -DARDUINO=105 -DCORE_TEENSY -DEMBEDXCODE=128 -D__MK20DX128__ -nostdlib -mthumb -MMD -DUSB_VID=null -DUSB_PID=null -DUSB_SERIAL -DLAYOUT_US_ENGLISH -DTIME_T=1391190456 /Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy3/WMath.cpp -o Builds/WMath.o
1.3-CORE: .o < .cpp teensy3 Builds/ WString.cpp
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/arm-none-eabi/bin/arm-none-eabi-g++ -c -mcpu=cortex-m4 -DF_CPU=24000000 -I/Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy3 -g -Os -w -Wall -ffunction-sections -fdata-sections -DARDUINO=105 -DCORE_TEENSY -DEMBEDXCODE=128 -D__MK20DX128__ -nostdlib -mthumb -MMD -DUSB_VID=null -DUSB_PID=null -DUSB_SERIAL -DLAYOUT_US_ENGLISH -DTIME_T=1391190456 /Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy3/WString.cpp -o Builds/WString.o
1.3-CORE: .o < .cpp teensy3 Builds/ avr_emulation.cpp
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/arm-none-eabi/bin/arm-none-eabi-g++ -c -mcpu=cortex-m4 -DF_CPU=24000000 -I/Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy3 -g -Os -w -Wall -ffunction-sections -fdata-sections -DARDUINO=105 -DCORE_TEENSY -DEMBEDXCODE=128 -D__MK20DX128__ -nostdlib -mthumb -MMD -DUSB_VID=null -DUSB_PID=null -DUSB_SERIAL -DLAYOUT_US_ENGLISH -DTIME_T=1391190457 /Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy3/avr_emulation.cpp -o Builds/avr_emulation.o
1.3-CORE: .o < .cpp teensy3 Builds/ new.cpp
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/arm-none-eabi/bin/arm-none-eabi-g++ -c -mcpu=cortex-m4 -DF_CPU=24000000 -I/Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy3 -g -Os -w -Wall -ffunction-sections -fdata-sections -DARDUINO=105 -DCORE_TEENSY -DEMBEDXCODE=128 -D__MK20DX128__ -nostdlib -mthumb -MMD -DUSB_VID=null -DUSB_PID=null -DUSB_SERIAL -DLAYOUT_US_ENGLISH -DTIME_T=1391190457 /Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy3/new.cpp -o Builds/new.o
1.3-CORE: .o < .cpp teensy3 Builds/ usb_flightsim.cpp
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/arm-none-eabi/bin/arm-none-eabi-g++ -c -mcpu=cortex-m4 -DF_CPU=24000000 -I/Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy3 -g -Os -w -Wall -ffunction-sections -fdata-sections -DARDUINO=105 -DCORE_TEENSY -DEMBEDXCODE=128 -D__MK20DX128__ -nostdlib -mthumb -MMD -DUSB_VID=null -DUSB_PID=null -DUSB_SERIAL -DLAYOUT_US_ENGLISH -DTIME_T=1391190457 /Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy3/usb_flightsim.cpp -o Builds/usb_flightsim.o
1.3-CORE: .o < .cpp teensy3 Builds/ usb_inst.cpp
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/arm-none-eabi/bin/arm-none-eabi-g++ -c -mcpu=cortex-m4 -DF_CPU=24000000 -I/Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy3 -g -Os -w -Wall -ffunction-sections -fdata-sections -DARDUINO=105 -DCORE_TEENSY -DEMBEDXCODE=128 -D__MK20DX128__ -nostdlib -mthumb -MMD -DUSB_VID=null -DUSB_PID=null -DUSB_SERIAL -DLAYOUT_US_ENGLISH -DTIME_T=1391190457 /Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy3/usb_inst.cpp -o Builds/usb_inst.o
4.3-LOCAL: .o < .cpp teensy3 Builds/ LocalLibrary.cpp
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/arm-none-eabi/bin/arm-none-eabi-g++ -c -mcpu=cortex-m4 -DF_CPU=24000000 -I/Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy3 -g -Os -w -Wall -ffunction-sections -fdata-sections -DARDUINO=105 -DCORE_TEENSY -DEMBEDXCODE=128 -D__MK20DX128__ -nostdlib -mthumb -MMD -DUSB_VID=null -DUSB_PID=null -DUSB_SERIAL -DLAYOUT_US_ENGLISH -DTIME_T=1391190457 LocalLibrary.cpp -o Builds/LocalLibrary.o
4.3-LOCAL: .o < .cpp teensy3 Builds/ main.cpp
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/arm-none-eabi/bin/arm-none-eabi-g++ -c -mcpu=cortex-m4 -DF_CPU=24000000 -I/Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy3 -g -Os -w -Wall -ffunction-sections -fdata-sections -DARDUINO=105 -DCORE_TEENSY -DEMBEDXCODE=128 -D__MK20DX128__ -nostdlib -mthumb -MMD -DUSB_VID=null -DUSB_PID=null -DUSB_SERIAL -DLAYOUT_US_ENGLISH -DTIME_T=1391190457 main.cpp -o Builds/main.o
---- Link ----
7.1-ARCHIVE: .elf < . teensy3 Builds/ .
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/arm-none-eabi/bin/arm-none-eabi-ar rcs Builds/embeddedcomputing.a Builds/analog.o Builds/eeprom.o Builds/keylayouts.o Builds/math_helper.o Builds/mk20dx128.o Builds/nonstd.o Builds/pins_teensy.o Builds/serial1.o Builds/serial2.o Builds/serial3.o Builds/touch.o Builds/usb_desc.o Builds/usb_dev.o Builds/usb_joystick.o Builds/usb_keyboard.o Builds/usb_mem.o Builds/usb_midi.o Builds/usb_mouse.o Builds/usb_rawhid.o Builds/usb_seremu.o Builds/usb_serial.o Builds/yield.o Builds/AudioStream.o Builds/HardwareSerial1.o Builds/HardwareSerial2.o Builds/HardwareSerial3.o Builds/IPAddress.o Builds/IntervalTimer.o Builds/Print.o Builds/Stream.o Builds/Tone.o Builds/WMath.o Builds/WString.o Builds/avr_emulation.o Builds/new.o Builds/usb_flightsim.o Builds/usb_inst.o
7.2-LINK: .elf < . teensy3 Builds/ .
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/arm-none-eabi/bin/arm-none-eabi-g++ -mcpu=cortex-m4 -Wl,--gc-sections -Os -mthumb -T/Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy3/mk20dx128.ld -o Builds/embeddedcomputing.elf Builds/embeddedcomputing.a Builds/LocalLibrary.o Builds/main.o -lc -LBuilds -lm
8.1-COPY: .hex < .elf teensy3 Builds/ embeddedcomputing.elf
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/arm-none-eabi/bin/arm-none-eabi-objcopy -Oihex -R .eeprom Builds/embeddedcomputing.elf Builds/embeddedcomputing.hex
8.3-COPY: .eep < .elf teensy3 Builds/ embeddedcomputing.elf
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/arm-none-eabi/bin/arm-none-eabi-objcopy -Oihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 Builds/embeddedcomputing.elf Builds/embeddedcomputing.eep
---- Size ----
Binary sketch size: 1240 bytes (of a 131072 byte maximum)
Estimated SRAM used: 28 bytes (of a 16384 byte maximum)
Elapsed time: 4.9 s
---- Reset ----
screen -X kill
No screen session found.
make: [reset] Error 1 (ignored)
sleep 1
---- Upload ----
9.8-UPLOAD: < teensy3 ./
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/teensy_post_compile -file=embeddedcomputing -path=/Users/duff/Documents/Arduino/embedXcode/test2/test2/Builds/ -tools=/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/teensy_reboot
---- Serial ----
osascript -e 'tell application "Terminal" to do script " "'
tab 1 of window id 416
==== All
