Build target Build
ExternalBuildToolExecution Build
cd /Users/freddie/Desktop/Arduino_Sensors_Stuff/Wind_Speed-direction_Controller/Wind_Speed-direction_Controller
export ACTION=
export ALTERNATE_GROUP=staff
export ALTERNATE_MODE=u+w,go-w,a+rX
export ALTERNATE_OWNER=freddie
export ALWAYS_SEARCH_USER_PATHS=YES
export APPLE_INTERNAL_DEVELOPER_DIR=/AppleInternal/Developer
export APPLE_INTERNAL_DIR=/AppleInternal
export APPLE_INTERNAL_DOCUMENTATION_DIR=/AppleInternal/Documentation
export APPLE_INTERNAL_LIBRARY_DIR=/AppleInternal/Library
export APPLE_INTERNAL_TOOLS=/AppleInternal/Developer/Tools
export APPLICATION_EXTENSION_API_ONLY=NO
export APPLY_RULES_IN_COPY_FILES=NO
export ARCHS=x86_64
export AVAILABLE_PLATFORMS="iphonesimulator macosx iphoneos"
export BOARD_PORT="/dev/tty.usbmodem*"
export BOARD_TAG=teensy31
export BUILD_COMPONENTS="headers build"
export BUILD_DIR=/Users/freddie/Library/Developer/Xcode/DerivedData/Wind_Speed-direction_Controller-eldbnokxsbfqqrdxmaigjdpijvst/Build/Products
export BUILD_ROOT=/Users/freddie/Library/Developer/Xcode/DerivedData/Wind_Speed-direction_Controller-eldbnokxsbfqqrdxmaigjdpijvst/Build/Products
export BUILD_STYLE=
export BUILD_VARIANTS=normal
export BUILT_PRODUCTS_DIR=/Users/freddie/Library/Developer/Xcode/DerivedData/Wind_Speed-direction_Controller-eldbnokxsbfqqrdxmaigjdpijvst/Build/Products/Debug
export CACHE_ROOT=/var/folders/rb/y3bt7gq151x05xlwpzpzc0hm0000gt/C/com.apple.DeveloperTools/6.1-6A1052d/Xcode
export CLANG_CXX_LANGUAGE_STANDARD=gnu++0x
export CLANG_CXX_LIBRARY=libc++
export CLANG_ENABLE_MODULES=YES
export CLANG_ENABLE_OBJC_ARC=YES
export CLANG_WARN_BOOL_CONVERSION=YES
export CLANG_WARN_CONSTANT_CONVERSION=YES
export CLANG_WARN_DIRECT_OBJC_ISA_USAGE=YES_ERROR
export CLANG_WARN_EMPTY_BODY=YES
export CLANG_WARN_ENUM_CONVERSION=YES
export CLANG_WARN_INT_CONVERSION=YES
export CLANG_WARN_OBJC_ROOT_CLASS=YES_ERROR
export CLANG_WARN_UNREACHABLE_CODE=YES
export CLANG_WARN__DUPLICATE_METHOD_MATCH=YES
export CLASS_FILE_DIR=/Users/freddie/Library/Developer/Xcode/DerivedData/Wind_Speed-direction_Controller-eldbnokxsbfqqrdxmaigjdpijvst/Build/Intermediates/Wind_Speed-direction_Controller.build/Debug/Build.build/JavaClasses
export CLONE_HEADERS=NO
export CODE_SIGNING_ALLOWED=NO
export COLOR_DIAGNOSTICS=NO
export CONFIGURATION=Debug
export CONFIGURATION_BUILD_DIR=/Users/freddie/Library/Developer/Xcode/DerivedData/Wind_Speed-direction_Controller-eldbnokxsbfqqrdxmaigjdpijvst/Build/Products/Debug
export CONFIGURATION_TEMP_DIR=/Users/freddie/Library/Developer/Xcode/DerivedData/Wind_Speed-direction_Controller-eldbnokxsbfqqrdxmaigjdpijvst/Build/Intermediates/Wind_Speed-direction_Controller.build/Debug
export COPYING_PRESERVES_HFS_DATA=NO
export COPY_PHASE_STRIP=NO
export CREATE_INFOPLIST_SECTION_IN_BINARY=NO
export DEAD_CODE_STRIPPING=NO
export DEBUGGING_SYMBOLS=YES
export DEFAULT_COMPILER=com.apple.compilers.llvm.clang.1_0
export DEFAULT_KEXT_INSTALL_PATH=/Library/Extensions
export DEFINES_MODULE=NO
export DEPLOYMENT_LOCATION=NO
export DEPLOYMENT_POSTPROCESSING=NO
export DERIVED_FILES_DIR=
export DERIVED_FILE_DIR=/Users/freddie/Library/Developer/Xcode/DerivedData/Wind_Speed-direction_Controller-eldbnokxsbfqqrdxmaigjdpijvst/Build/Intermediates/Wind_Speed-direction_Controller.build/Debug/Build.build/DerivedSources
export DERIVED_SOURCES_DIR=/Users/freddie/Library/Developer/Xcode/DerivedData/Wind_Speed-direction_Controller-eldbnokxsbfqqrdxmaigjdpijvst/Build/Intermediates/Wind_Speed-direction_Controller.build/Debug/Build.build/DerivedSources
export DEVELOPER_APPLICATIONS_DIR=/Applications/Xcode.app/Contents/Developer/Applications
export DEVELOPER_BIN_DIR=/Applications/Xcode.app/Contents/Developer/usr/bin
export DEVELOPER_DIR=/Applications/Xcode.app/Contents/Developer
export DEVELOPER_FRAMEWORKS_DIR=/Applications/Xcode.app/Contents/Developer/Library/Frameworks
export DEVELOPER_FRAMEWORKS_DIR_QUOTED=/Applications/Xcode.app/Contents/Developer/Library/Frameworks
export DEVELOPER_LIBRARY_DIR=/Applications/Xcode.app/Contents/Developer/Library
export DEVELOPER_SDK_DIR=/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs
export DEVELOPER_TOOLS_DIR=/Applications/Xcode.app/Contents/Developer/Tools
export DEVELOPER_USR_DIR=/Applications/Xcode.app/Contents/Developer/usr
export DEVELOPMENT_LANGUAGE=English
export DO_HEADER_SCANNING_IN_JAM=NO
export DSTROOT=/tmp/Wind_Speed-direction_Controller.dst
export DT_TOOLCHAIN_DIR=/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain
export DWARF_DSYM_FILE_NAME=.dSYM
export DWARF_DSYM_FILE_SHOULD_ACCOMPANY_PRODUCT=NO
export DWARF_DSYM_FOLDER_PATH=/Users/freddie/Library/Developer/Xcode/DerivedData/Wind_Speed-direction_Controller-eldbnokxsbfqqrdxmaigjdpijvst/Build/Products/Debug
export EMBEDDED_PROFILE_NAME=embedded.provisionprofile
export ENABLE_HEADER_DEPENDENCIES=YES
export ENABLE_STRICT_OBJC_MSGSEND=YES
export EXCLUDED_INSTALLSRC_SUBDIRECTORY_PATTERNS=".DS_Store .svn .git .hg CVS"
export EXCLUDED_RECURSIVE_SEARCH_PATH_SUBDIRECTORIES="*.nib *.lproj *.framework *.gch *.xcode* (*) .DS_Store CVS .svn .git .hg"
export FILE_LIST=/Users/freddie/Library/Developer/Xcode/DerivedData/Wind_Speed-direction_Controller-eldbnokxsbfqqrdxmaigjdpijvst/Build/Intermediates/Wind_Speed-direction_Controller.build/Debug/Build.build/Objects/LinkFileList
export FRAMEWORK_VERSION=A
export GCC3_VERSION=3.3
export GCC_C_LANGUAGE_STANDARD=gnu99
export GCC_DYNAMIC_NO_PIC=NO
export GCC_OPTIMIZATION_LEVEL=0
export GCC_PREPROCESSOR_DEFINITIONS="DEBUG=1 __MK20DX256__ TEENSYDUINO"
export GCC_SYMBOLS_PRIVATE_EXTERN=NO
export GCC_VERSION=com.apple.compilers.llvm.clang.1_0
export GCC_WARN_64_TO_32_BIT_CONVERSION=YES
export GCC_WARN_ABOUT_RETURN_TYPE=YES_ERROR
export GCC_WARN_UNDECLARED_SELECTOR=YES
export GCC_WARN_UNINITIALIZED_AUTOS=YES_AGGRESSIVE
export GCC_WARN_UNUSED_FUNCTION=YES
export GCC_WARN_UNUSED_VARIABLE=YES
export GENERATE_MASTER_OBJECT_FILE=NO
export GENERATE_PKGINFO_FILE=NO
export GID=20
export GROUP=staff
export HEADERMAP_INCLUDES_FLAT_ENTRIES_FOR_TARGET_BEING_BUILT=YES
export HEADERMAP_INCLUDES_FRAMEWORK_ENTRIES_FOR_ALL_PRODUCT_TYPES=YES
export HEADERMAP_INCLUDES_NONPUBLIC_NONPRIVATE_HEADERS=YES
export HEADERMAP_INCLUDES_PROJECT_HEADERS=YES
export HEADERMAP_USES_FRAMEWORK_PREFIX_ENTRIES=YES
export HEADERMAP_USES_VFS=NO
export HEADER_SEARCH_PATHS="/Applications/Teensyduino.app/Contents/Resources/Java/** /Applications/Arduino.app/Contents/Resources/Java/** /Applications/Arduino.app/Contents/Java/**"
export INFOPLIST_EXPAND_BUILD_SETTINGS=YES
export INFOPLIST_OUTPUT_FORMAT=same-as-input
export INFOPLIST_PREPROCESS=NO
export INSTALL_DIR=/tmp/Wind_Speed-direction_Controller.dst
export INSTALL_GROUP=staff
export INSTALL_MODE_FLAG=u+w,go-w,a+rX
export INSTALL_OWNER=freddie
export INSTALL_ROOT=/tmp/Wind_Speed-direction_Controller.dst
export JAVA_APP_STUB=/System/Library/Frameworks/JavaVM.framework/Resources/MacOS/JavaApplicationStub
export JAVA_ARCHIVE_CLASSES=YES
export JAVA_ARCHIVE_TYPE=JAR
export JAVA_COMPILER=/usr/bin/javac
export JAVA_FRAMEWORK_RESOURCES_DIRS=Resources
export JAVA_JAR_FLAGS=cv
export JAVA_SOURCE_SUBDIR=.
export JAVA_USE_DEPENDENCIES=YES
export JAVA_ZIP_FLAGS=-urg
export KEEP_PRIVATE_EXTERNS=NO
export LD_DEPENDENCY_INFO_FILE=//Build_dependency_info.dat
export LD_GENERATE_MAP_FILE=NO
export LD_MAP_FILE_PATH=/Users/freddie/Library/Developer/Xcode/DerivedData/Wind_Speed-direction_Controller-eldbnokxsbfqqrdxmaigjdpijvst/Build/Intermediates/Wind_Speed-direction_Controller.build/Debug/Build.build/Build-LinkMap--.txt
export LD_NO_PIE=NO
export LD_QUOTE_LINKER_ARGUMENTS_FOR_COMPILER_DRIVER=YES
export LEGACY_DEVELOPER_DIR=/Applications/Xcode.app/Contents/PlugIns/Xcode3Core.ideplugin/Contents/SharedSupport/Developer
export LIBRARY_FLAG_NOSPACE=YES
export LIBRARY_KEXT_INSTALL_PATH=/Library/Extensions
export LINKER_DISPLAYS_MANGLED_NAMES=NO
export LINK_WITH_STANDARD_LIBRARIES=YES
export LOCAL_ADMIN_APPS_DIR=/Applications/Utilities
export LOCAL_APPS_DIR=/Applications
export LOCAL_DEVELOPER_DIR=/Library/Developer
export LOCAL_LIBRARY_DIR=/Library
export MACOSX_DEPLOYMENT_TARGET=10.10
export MAC_OS_X_PRODUCT_BUILD_VERSION=13F34
export MAC_OS_X_VERSION_ACTUAL=1095
export MAC_OS_X_VERSION_MAJOR=1090
export MAC_OS_X_VERSION_MINOR=0905
export MODULE_CACHE_DIR=/Users/freddie/Library/Developer/Xcode/DerivedData/ModuleCache
export MTL_ENABLE_DEBUG_INFO=YES
export OBJECT_FILE_DIR=/Users/freddie/Library/Developer/Xcode/DerivedData/Wind_Speed-direction_Controller-eldbnokxsbfqqrdxmaigjdpijvst/Build/Intermediates/Wind_Speed-direction_Controller.build/Debug/Build.build/Objects
export OBJROOT=/Users/freddie/Library/Developer/Xcode/DerivedData/Wind_Speed-direction_Controller-eldbnokxsbfqqrdxmaigjdpijvst/Build/Intermediates
export ONLY_ACTIVE_ARCH=YES
export OPTIMIZATION_LEVEL=0
export OS=MACOS
export PATH="/Applications/Xcode.app/Contents/Developer/usr/bin:/usr/local/bin:/usr/bin:/bin:/usr/sbin:sbin:/Users/freddie/Desktop/Arduino_Sensors_Stuff/Wind_Speed-direction_Controller"
export PATH_PREFIXES_EXCLUDED_FROM_HEADER_DEPENDENCIES="/usr/include /usr/local/include /System/Library/Frameworks /System/Library/PrivateFrameworks /Applications/Xcode.app/Contents/Developer/Headers /Applications/Xcode.app/Contents/Developer/SDKs /Applications/Xcode.app/Contents/Developer/Platforms"
export PLATFORM_NAME=macosx
export PLIST_FILE_OUTPUT_FORMAT=same-as-input
export PRECOMPS_INCLUDE_HEADERS_FROM_BUILT_PRODUCTS_DIR=YES
export PRECOMP_DESTINATION_DIR=/Users/freddie/Library/Developer/Xcode/DerivedData/Wind_Speed-direction_Controller-eldbnokxsbfqqrdxmaigjdpijvst/Build/Intermediates/Wind_Speed-direction_Controller.build/Debug/Build.build/PrefixHeaders
export PRESERVE_DEAD_CODE_INITS_AND_TERMS=NO
export PRODUCT_MODULE_NAME=Build
export PRODUCT_NAME=Build
export PROFILING_CODE=NO
export PROJECT=Wind_Speed-direction_Controller
export PROJECT_DERIVED_FILE_DIR=/Users/freddie/Library/Developer/Xcode/DerivedData/Wind_Speed-direction_Controller-eldbnokxsbfqqrdxmaigjdpijvst/Build/Intermediates/Wind_Speed-direction_Controller.build/DerivedSources
export PROJECT_DIR=/Users/freddie/Desktop/Arduino_Sensors_Stuff/Wind_Speed-direction_Controller
export PROJECT_FILE_PATH=/Users/freddie/Desktop/Arduino_Sensors_Stuff/Wind_Speed-direction_Controller/Wind_Speed-direction_Controller.xcodeproj
export PROJECT_NAME=Wind_Speed-direction_Controller
export PROJECT_TEMP_DIR=/Users/freddie/Library/Developer/Xcode/DerivedData/Wind_Speed-direction_Controller-eldbnokxsbfqqrdxmaigjdpijvst/Build/Intermediates/Wind_Speed-direction_Controller.build
export PROJECT_TEMP_ROOT=/Users/freddie/Library/Developer/Xcode/DerivedData/Wind_Speed-direction_Controller-eldbnokxsbfqqrdxmaigjdpijvst/Build/Intermediates
export REMOVE_CVS_FROM_RESOURCES=YES
export REMOVE_GIT_FROM_RESOURCES=YES
export REMOVE_HEADERS_FROM_EMBEDDED_BUNDLES=YES
export REMOVE_HG_FROM_RESOURCES=YES
export REMOVE_SVN_FROM_RESOURCES=YES
export SCAN_ALL_SOURCE_FILES_FOR_INCLUDES=NO
export SDKROOT=
export SEPARATE_STRIP=NO
export SEPARATE_SYMBOL_EDIT=NO
export SHARED_DERIVED_FILE_DIR=/Users/freddie/Library/Developer/Xcode/DerivedData/Wind_Speed-direction_Controller-eldbnokxsbfqqrdxmaigjdpijvst/Build/Products/Debug/DerivedSources
export SHARED_PRECOMPS_DIR=/Users/freddie/Library/Developer/Xcode/DerivedData/Wind_Speed-direction_Controller-eldbnokxsbfqqrdxmaigjdpijvst/Build/Intermediates/PrecompiledHeaders
export SKETCH_EXTENSION=ino
export SKIP_INSTALL=YES
export SOURCE_ROOT=/Users/freddie/Desktop/Arduino_Sensors_Stuff/Wind_Speed-direction_Controller
export SRCROOT=/Users/freddie/Desktop/Arduino_Sensors_Stuff/Wind_Speed-direction_Controller
export STRINGS_FILE_OUTPUT_ENCODING=UTF-16
export STRIP_INSTALLED_PRODUCT=YES
export STRIP_STYLE=all
export SUPPORTED_PLATFORMS=macosx
export SYMROOT=/Users/freddie/Library/Developer/Xcode/DerivedData/Wind_Speed-direction_Controller-eldbnokxsbfqqrdxmaigjdpijvst/Build/Products
export SYSTEM_ADMIN_APPS_DIR=/Applications/Utilities
export SYSTEM_APPS_DIR=/Applications
export SYSTEM_CORE_SERVICES_DIR=/System/Library/CoreServices
export SYSTEM_DEMOS_DIR=/Applications/Extras
export SYSTEM_DEVELOPER_APPS_DIR=/Applications/Xcode.app/Contents/Developer/Applications
export SYSTEM_DEVELOPER_BIN_DIR=/Applications/Xcode.app/Contents/Developer/usr/bin
export SYSTEM_DEVELOPER_DEMOS_DIR="/Applications/Xcode.app/Contents/Developer/Applications/Utilities/Built Examples"
export SYSTEM_DEVELOPER_DIR=/Applications/Xcode.app/Contents/Developer
export SYSTEM_DEVELOPER_DOC_DIR="/Applications/Xcode.app/Contents/Developer/ADC Reference Library"
export SYSTEM_DEVELOPER_GRAPHICS_TOOLS_DIR="/Applications/Xcode.app/Contents/Developer/Applications/Graphics Tools"
export SYSTEM_DEVELOPER_JAVA_TOOLS_DIR="/Applications/Xcode.app/Contents/Developer/Applications/Java Tools"
export SYSTEM_DEVELOPER_PERFORMANCE_TOOLS_DIR="/Applications/Xcode.app/Contents/Developer/Applications/Performance Tools"
export SYSTEM_DEVELOPER_RELEASENOTES_DIR="/Applications/Xcode.app/Contents/Developer/ADC Reference Library/releasenotes"
export SYSTEM_DEVELOPER_TOOLS=/Applications/Xcode.app/Contents/Developer/Tools
export SYSTEM_DEVELOPER_TOOLS_DOC_DIR="/Applications/Xcode.app/Contents/Developer/ADC Reference Library/documentation/DeveloperTools"
export SYSTEM_DEVELOPER_TOOLS_RELEASENOTES_DIR="/Applications/Xcode.app/Contents/Developer/ADC Reference Library/releasenotes/DeveloperTools"
export SYSTEM_DEVELOPER_USR_DIR=/Applications/Xcode.app/Contents/Developer/usr
export SYSTEM_DEVELOPER_UTILITIES_DIR=/Applications/Xcode.app/Contents/Developer/Applications/Utilities
export SYSTEM_DOCUMENTATION_DIR=/Library/Documentation
export SYSTEM_KEXT_INSTALL_PATH=/System/Library/Extensions
export SYSTEM_LIBRARY_DIR=/System/Library
export TARGETNAME=Build
export TARGET_BUILD_DIR=/Users/freddie/Library/Developer/Xcode/DerivedData/Wind_Speed-direction_Controller-eldbnokxsbfqqrdxmaigjdpijvst/Build/Products/Debug
export TARGET_NAME=Build
export TARGET_TEMP_DIR=/Users/freddie/Library/Developer/Xcode/DerivedData/Wind_Speed-direction_Controller-eldbnokxsbfqqrdxmaigjdpijvst/Build/Intermediates/Wind_Speed-direction_Controller.build/Debug/Build.build
export TEMP_DIR=/Users/freddie/Library/Developer/Xcode/DerivedData/Wind_Speed-direction_Controller-eldbnokxsbfqqrdxmaigjdpijvst/Build/Intermediates/Wind_Speed-direction_Controller.build/Debug/Build.build
export TEMP_FILES_DIR=
export TEMP_FILE_DIR=/Users/freddie/Library/Developer/Xcode/DerivedData/Wind_Speed-direction_Controller-eldbnokxsbfqqrdxmaigjdpijvst/Build/Intermediates/Wind_Speed-direction_Controller.build/Debug/Build.build
export TEMP_ROOT=/Users/freddie/Library/Developer/Xcode/DerivedData/Wind_Speed-direction_Controller-eldbnokxsbfqqrdxmaigjdpijvst/Build/Intermediates
export TREAT_MISSING_BASELINES_AS_TEST_FAILURES=NO
export UID=506
export USER=freddie
export USER_APPS_DIR=/Users/freddie/Applications
export USER_LIBRARY_DIR=/Users/freddie/Library
export XCODE_APP_SUPPORT_DIR=/Applications/Xcode.app/Contents/Developer/Library/Xcode
export XCODE_PRODUCT_BUILD_VERSION=6A1052d
export XCODE_VERSION_ACTUAL=0610
export XCODE_VERSION_MAJOR=0600
export XCODE_VERSION_MINOR=0610
export arch=x86_64
export variant=normal
/Applications/Xcode.app/Contents/Developer/usr/bin/make build
embedXcode
embedXcode+
Embedded Computing on Xcode
© Rei VILO, 2010-2014
All rights reserved
http://embedXcode.weebly.com/
embedXcode • Oct 26, 2014 release 221 • Stability enhancements
embedXcode+ • Oct 26, 2014 release 222 • Stability enhancements
==== Info ====
---- Project ----
Target build
Name Wind_Speed-direction_Controller
Tag teensy31
Extension ino
User /Users/freddie
---- Platform ----
IDE Teensy
Version 1.0.6
Platform arm
---- Board ----
Name Teensy 3.1
Frequency 96000000
MCU cortex-m4
Flash memory 262144 bytes
SRAM memory 65536 bytes
---- Port ----
Uploader teensy_flash
Serial
---- Libraries ----
. Core libraries from /Applications/Arduino
Arduino AudioStream Client DMAChannel HardwareSerial IPAddress IntervalTimer Print Printable SPIFIFO Server Stream Udp WCharacter WConstants WProgram WString arm_common_tables arm_math avr_emulation avr_functions binary core_cm4 core_cm4_simd core_cmInstr core_id core_pins elapsedMillis keylayouts kinetis math_helper mk20dx128 new pins_arduino usb_desc usb_dev usb_flightsim usb_joystick usb_keyboard usb_mem usb_midi usb_mouse usb_names usb_rawhid usb_seremu usb_serial wiring wiring_private avr/eeprom avr/interrupt avr/io avr/pgmspace avr/sleep avr/wdt util/atomic util/crc16 util/delay util/parity
. Application libraries from /Applications/Arduino
0
. User libraries from /Users/freddie/Documents/Arduino sketchbook
0
. Local libraries from /Users/freddie/Desktop/Arduino_Sensors_Stuff/Wind_Speed-direction_Controller/Wind_Speed-direction_Controller
AverageList PString Wind Wind_Speed_direction_Controller Wind_Speed_direction_ControllerConstants Wind_Speed_direction_ControllerModel
==== Info done ====
==== Build ====
---- Clean ----
---- Compile ----
1.2-CORE: .cpp.o < .cpp teensy31 Builds/ AudioStream.cpp
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/arm-none-eabi/bin/arm-none-eabi-g++ -c -mcpu=cortex-m4 -DF_CPU=96000000 -g -Os -w -ffunction-sections -fdata-sections -DARDUINO=105 -DTEENSYDUINO=118 -DEMBEDXCODE=222 -D__MK20DX256__ -nostdlib -mthumb -MMD -I/Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy3 -DUSB_VID=null -DUSB_PID=null -DUSB_SERIAL __arm__ TEENSY_CORE -DLAYOUT_US_ENGLISH -DTIME_T=1415047335 -fno-exceptions -fno-rtti -felide-constructors -std=gnu++0x /Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy3/AudioStream.cpp -o Builds/AudioStream.cpp.o
arm-none-eabi-g++: error: __arm__: No such file or directory
arm-none-eabi-g++: error: TEENSY_CORE: No such file or directory
make: *** [Builds/AudioStream.cpp.o]
