11-07-2017, 10:03 AM
#151
Thank you for reporting the issue. I was able to replicate it and fix it.
01-23-2018, 08:45 AM
#152
Please find a new release of embedXcode.
- embedXcode • Jan 22, 2018 release 9.0.7 • Updated support for Teensy boards
Download
01-23-2018, 09:58 AM
#153
Senior Member+
On the embedXcode website, I see "PJRC Teensy boards with Freescale ARM Cortex-M4 MK20". Does that mean that there is no support for the newer Teensys, 3.5, 3.6 and LC? I'd like to give embedXcode a try, but if it's limited to the T3.2, it's rather useless for me.
01-23-2018, 10:15 AM
#154
All Teensy 3.x boards are supported.
The front page needs to be refreshed; thank you for noticing me.
The full list of tested boards is available at What Has Been Tested.
Enjoy embedXcode!
06-05-2018, 08:49 AM
#155
The embedXcode User Manual is now available as a dedicated website.
09-28-2018, 04:08 PM
#156
Please find a new major release of embedXcode.
- embedXcode • 25 Sep 2018 release 10.0.6 • Added IDE path to board configuration files
- embedXcode+ • 25 Sep 2018 release 10.0.6 • Added IDE path to board configuration files
embedXcode now supports Xcode 10 on macOS 10.14 Mojave.
Download
11-07-2018, 06:44 PM
#157
Release 10.2.3 updates support for Xcode 10.1 and macOS 10.14.1.
Download
03-28-2019, 02:05 AM
#158
Confused about this...
Installed both IDE's, EmbedX shows as a template inside Xcode. Upon creating a new project, the 'resources' folder is RED. I build using ALL > My Mac, it builds successfully however all the text is gray and there is no code sense.
I test with a simple blink code, upload and it works, however no sign of code sense and the text is still gray.
I create a new header file, and all the colors and code sense works there.... just not in the .ino file (which is not the typical Arduino green ino file, its just a plain C++ file)
What am I missing?
Please help
05-24-2019, 10:18 AM
#159
The project needs to be built one time in order to feature code-sense.
Please refer to the user manual at Prepare the project
08-18-2019, 09:58 PM
#160
I conducted some building and linking tests against the Teensy 4.0 with embedXcode and all went successful.
I hope to get one board soon to finalise the uploading and running tests.
09-01-2019, 01:30 PM
#161
I managed to get a Teensy 4.0 board and proceeded with more tests. Uploading and running work fine, and very fast!
So soon-to-be-released version 11 of embedXcode supports Teensy 4.0.
10-11-2019, 01:55 PM
#162
Release 11.2.1 of embedXcode adds support for Xcode 11.1 on macOS 10.15 Catalina.
It also supports the Teensy 4.0 board.
Download
Tags for this Thread
- You may not post replies
- You may not edit your posts
Forum Rules
