WIZ820io Ethernet and 2nd power supply with teensy 3.0
Here's my code - I'm using TeensyDuino Loader 1.17 with Wiz8210 - it will occasionally get a DHCP address, but it never responds to a web page request. Most often, it just hangs waiting for an IP address.
The same code works well for the Wiz812.
#include <Ethernet.h>
#include <Dns.h>
#include <mac.h>
//consts
const int MAX_LEN = 85;
const int REQ_BUF_SZ = 140;
const int SCRATCH_BUFFER = 25;
const int MAX_RES = 10;
const int WEB_REQUEST_TIMEOUT = 2000;
//+++++++++ LCD Serial Commands++++++++++++++++++++++++++++
const int LCD_CLEAR = 12;
const int LCD_BACKLIGHT_ON = 17;
const int LCD_FF = 13;
const int LCD_BACKLIGHT_OFF = 18;
const int LCD_LF = 10;
const int LCD_NOTE_A = 220;
//------------PINS------------
const int reset_pin = 9; // Pin to monitor for manual Ethernet reset
//-----------PINS-------------
//--------DNS client---------
DNSClient dnsClient;
//--------address struct------
typedef struct
char szMacAddress[SCRATCH_BUFFER] = {0}; // MAC Address String
char szLcdMacAddress[SCRATCH_BUFFER]={0}; // MAC Address on LCD (no '-' chars...
char szIpAddress[SCRATCH_BUFFER]={0}; // Ip Address String
char szDnsAddress[SCRATCH_BUFFER]={0}; // DNS Address String
char szGatewayAddress[SCRATCH_BUFFER]={0}; // Default Gateway Address String
char szWebServiceAddress[SCRATCH_BUFFER]={0}; // Web Service Address
} _ADDRESSES;
_ADDRESSES address; // lenox laser string address structure
char strPageLine[MAX_LEN]={0};
char req_index = 0; // index into HTTP_req buffer
char szBuffer[SCRATCH_BUFFER] = {0};
char szResult[SCRATCH_BUFFER]={0}; // Numerical operation result
char szTemp[SCRATCH_BUFFER]={0}; // buffer for debug display
char szHostName[SCRATCH_BUFFER]={0}; // buffer for IP host name
//Values of illumination LEDs
int iRetVal = 0;
//timing
EthernetServer server(80); // create a server at port 80
char HTTP_req[REQ_BUF_SZ] = {0}; // stores the HTTP request
// +++++++++++++++Web Pages in Flash++++++++++++++++++++++
//page common - common html stuff
const char pc1 [] = "<!DOCTYPE html>\r\n<html>\r\n<head>\r\n<title>";
const char pc2 [] = "</title></head>\r\n";
const char pc_mainpage[] = "<p>Go back to <a href=\"index.htm\">main page</a></p>\r\n";
const char pce[] = "</body>\r\n</html>\r\n";
const char p1_body2[] = "<p><a href=\"net.htm\">net configuration</a></p>\r\n";
const char p1_close[] = "</html>\r\n";
const int P1_ELEMENTS = 4;
const char* p1[] = {pc1, pc2, p1_body2, p1_close}; //p1
const char* p2[] = {pc1, pc2, pc_mainpage, pce}; //p2
// +++++++++++++++End Web Pages in Flash++++++++++++++++++++++
Serial3.begin(9600);
//pin setup
pinMode(reset_pin, INPUT); // Ethernet reset
delay(5000);
//Use DHCP if possible
if(MakeDHCPRequest(true)==true)
// print the Ethernet board/shield's IP address:
DisplayAddressInfo();
LCD_Display("IP Address:", address.szIpAddress);
server.begin();
LCD_Display("DHCP Request", "-FAILED-");
Serial.print("--Error! - Failed DHCP Attempt---");
///////////////////////////// The main loop ////////////////////////////
CheckResetPin();
EthernetClient client = server.available(); // try to get client
if (client)
{ // got client?
boolean currentLineIsBlank = true;
while (client.connected())
if (client.available())
{ // client data available to read
char c = client.read(); // read 1 byte (character) from client
// buffer first part of HTTP request in HTTP_req array (string)
// leave last element in array as 0 to null terminate string (REQ_BUF_SZ - 1)
if (req_index < (REQ_BUF_SZ - 1))
HTTP_req[req_index] = c; // save HTTP request character
req_index++;
Serial.print(c); // print HTTP request character to serial monitor
// last line of client request is blank and ends with \n
// respond to client only after last line received
if (c == '\n' && currentLineIsBlank)
// send a standard http response header
client.println("HTTP/1.1 200 OK");
client.println("Content-Type: text/html");
client.println("Connnection: close");
client.println();
// open requested web page file
if ((strstr(HTTP_req, "GET /index.htm"))||(strstr(HTTP_req, "GET / ")))
Serial.println("------------ Request for web service recieved --------------------");
sendPage1(client);
else if (strstr(HTTP_req, "GET /net.htm"))
sendPage2(client);
// reset buffer index and all buffer elements to 0
req_index = 0;
memset(HTTP_req, 0, REQ_BUF_SZ);
// every line of text received from the client ends with \r\n
if (c == '\n')
// last character on line of received text
// starting new line with next character read
else if (c != '\r')
// a text character was received from client
currentLineIsBlank = false;
} // end if (client.available())
} // end while (client.connected())
delay(1); // give the web browser time to receive the data
client.stop(); // close the connection
} // end if (client)
dnsResolveToString
Resolve host string to string ip address
IN: pointer to a host string
IN/OUT: pointer to a string IP Address
void dnsResolveToString(char* pHost, char* szBuffer)
IPAddress ip;
dnsClient.getHostByName(pHost, ip);
ConvertAddress(szBuffer, ip);
Serial.print(pHost);
Serial.print(": ");
Serial.println(szBuffer);
LCD_Display
Display contents of a buffer on teh 16x2 LCD grid. The first line
is used to identify Lenox Laser's controller, while the 2nd line
can be used for custom display.
IN: pointer to a char buffer for line 1 (16 chars max)
IN: pointer to a char buffer for line 2 (16 chars max)
Returns: void
void LCD_Display(char* szLine1, char* szLine2)
Serial3.write(LCD_CLEAR);
if(szLine1)
Serial3.println(szLine1);
if(szLine2)
Serial3.write(LCD_LF);
Serial3.println(szLine2);
Serial3.write(LCD_NOTE_A);
MakeDHCPRequest()
Attempts a DHCP request for network connectivity.
Returns: Boolean result
bool MakeDHCPRequest(bool bLCD)
if(bLCD == true)
LCD_Display("Initializing", "Network...");
Serial.println("Getting address information, please wait...");
if (Ethernet.begin(GetFirmwareMAC()))
dnsClient.begin(Ethernet.dnsServerIP());
return true;
Serial.println("Failed to get address from DHCP server");
Serial3.println("Address FAIL!");
return false;
DisplayAddressInfo
void DisplayAddressInfo()
Serial.print("IP address: ");
Serial.println(Ethernet.localIP());
Serial.print("Subnet Mask: ");
Serial.println(Ethernet.subnetMask());
Serial.print("Default Gateway: ");
Serial.println(Ethernet.gatewayIP());
Serial.print("DNS: ");
Serial.println(Ethernet.dnsServerIP());
Serial.print("MAC: " );
Serial.println(address.szMacAddress);
ConvertAddress(address.szDnsAddress, Ethernet.dnsServerIP()); // convert the 32 bit dns address
ConvertAddress(address.szIpAddress, Ethernet.localIP()); // convert the 32 bit IP address
GetFirmwareMAC
Reads the firmware MAC burned into teensy 3.0+. Needs the mac.h
header...
IN: void
Returns: a pointer to a SRAM byte buffer that can be used by the
Ethernet object's begin() method.
byte* GetFirmwareMAC()
read_mac();
sprintf(address.szMacAddress, "%02x-%02x-%02x-%02x-%02x-%02x", mac[0], mac[1], mac[2], mac[3], mac[4], mac[5]);
sprintf(address.szLcdMacAddress, "%02x%02x%02x%02x%02x%02x", mac[0], mac[1], mac[2], mac[3], mac[4], mac[5]);
sprintf(szHostName, "WIZnet0%01x%02x%02x", mac[3], mac[4], mac[5]);
return mac;
sendPage1
This function is called to display the initial choices given
to the browser. These choices include network settings, LED
value modifications and settings, flow tests, etc.
IN: Reference to an EthernetClient object
Returns: void
void sendPage1(EthernetClient & client)
// send HTML header
client.println("");
for(int i= 0; i<P1_ELEMENTS; i++)
strcpy_P(strPageLine, (char*)p1);
client.print(strPageLine);
memset(strPageLine, 0, MAX_LEN);
sendPage2
This function is called to display in the browser the current
IP network settings for the Microprocessor.
Returns: void
void sendPage2(EthernetClient & client)
// send HTML header
client.println("");
strcpy_P(strPageLine, (char*)p2[0]);
client.print("Network Configuration");
strcpy_P(strPageLine, (char*)p2[1]);
sendConfigurationInfo(client);
strcpy_P(strPageLine, (char*)p2[2]);
strcpy_P(strPageLine, (char*)p2[3]);
Send the current IP address information to the client
IN: Reference to EthernetClient object
Returns: void
void sendConfigurationInfo(EthernetClient & client)
client.print("<h1>Network Configuration</h1>\r\n");
//method
client.print(szBuffer);
client.print("<table border=\"1\">\r\n<tr>\r\n<th>Network Item</th>\r\n<th>Value</th>\r\n</tr>\r\n");
//ip address
client.print("<tr>\r\n<td>IP Address</td>\r\n");
client.print("<td>");
client.print(Ethernet.localIP());
client.print("</td>\r\n</tr>\r\n");
//Ethernet.subnetMask()
client.print("<tr>\r\n<td>Subnet Mask</td>\r\n");
client.print(Ethernet.subnetMask());
//mac
client.print("<tr>\r\n<td>MAC Address</td>\r\n");
client.print(address.szMacAddress);
//default gateway
client.print("<tr>\r\n<td>Default Gateway</td>\r\n");
client.print(Ethernet.gatewayIP());
//dns
client.print("<tr>\r\n<td>DNS Server</td>\r\n");
client.print(Ethernet.dnsServerIP());
client.print("</td>\r\n</tr>\r\n</table>\r\n");
ConvertAddress
This method converts an unsigned integer (32 bit) address format
into a format that can be used as a character string.
IN: szAddress - pointer to a char string buffer
IN: _uiaddress - 32 bit ip address format
Returns: void
void ConvertAddress(char* szAddress, uint32_t _uiaddress)
union
uint32_t unsigned_int;
uint8_t bytes[4];
} Address;
Address.unsigned_int = _uiaddress;
sprintf(szAddress, "%d.%d.%d.%d", Address.bytes[0], Address.bytes[1], Address.bytes[2], Address.bytes[3]);
CheckResetPin
Check the value of the Ethernet reset pin. If this value is low
for > 2mSecs, then we reset the Ethernet adapter. This allows us
a manual reset...
void CheckResetPin()
if(digitalRead(reset_pin) == LOW)
Serial.println("******* Ethernet Reset detected! ******");
LCD_Display("Resetting", "Please wait");
LCD_Display("*IP Address:", address.szIpAddress); // create a web service request with our address information
Your code would be easier to read if posted in code tags:
 your code
Its the hash (#) in the advanced edit menu
Ok, finally ound the hash tag - thanks for the info. The code below works for the WIZ812MJ fine. I get
a DHCP address and can connect a client intot he web server. However, I cannot get the WIZ820 to work - although sometimes I will get a DHCP assigned address,
most of the times it just habgs waiting. Even when I do get an address, I can never connect to the web server. I am using Teensy 3.1 with loader 1.17.
#include <Dns.h>
#include <mac.h>
//consts
typedef struct
 } _ADDRESSES;
_ADDRESSES address;
int iRetVal = 0;
//timing
  //pin setup
  delay(5000);
    server.begin();
  CheckResetPin();
  if (client)
  {  // got client?
          req_index++;
          client.println();
            sendPage1(client);
            sendPage2(client);
          req_index = 0;
        if (c == '\n')
        else if (c != '\r')
dnsResolveToString
  IPAddress ip;
  Serial.print(": ");
LCD_Display
Returns: void
  if(szLine1)
  if(szLine2)
MakeDHCPRequest()
  if(bLCD == true)
    return true;
    return false;
DisplayAddressInfo
GetFirmwareMAC
header...
IN: void
Returns: a pointer to a byte buffer that can be used by the
  read_mac();
  return mac;
sendPage1
Returns: void
  // send HTML header
  client.println("");
    strcpy_P(strPageLine, (char*)p1[i]);
sendPage2
Returns: void
  // send HTML header
  client.println("");
Returns: void
  //method
  //ip address
  //mac
  //default gateway
  //dns
 ConvertAddress
 Returns: void
  union
    uint8_t bytes[4];
  } Address;
CheckResetPin
a manual reset...
Nice. Can you reduce the code to something small that can reproduce the problem ?
E.G. reduce it to something that I can run here on my Teensy3 <-> WIZ820io board ?
I am not sure the CheckReset Code will work as is with the WIZ820io.
I tried to take any extraneous "stuff" out to make a bare sketch.
#include <Dns.h>
#include <mac.h>
//consts
typedef struct
 } _ADDRESSES;
_ADDRESSES address;
int iRetVal = 0;
//timing
/////////////////////////////// Setup /////////////////////
  delay(5000);
    server.begin();
  if (client)
  {  // got client?
          req_index++;
          client.println();
            sendPage(client);
          req_index = 0;
        if (c == '\n')
        else if (c != '\r')
dnsResolveToString
  IPAddress ip;
  Serial.print(": ");
LCD_Display
Returns: void
  if(szLine1)
  if(szLine2)
MakeDHCPRequest()
  if(bLCD == true)
    return true;
    return false;
DisplayAddressInfo
GetFirmwareMAC
header...
IN: void
  read_mac();
  return mac;
sendPage
This function is called to display a Hello
Returns: void
void sendPage(EthernetClient & client)
  // send Hello msg
  client.println("");
  client.println("<!DOCTYPE html>\r\n<html>\r\n<head>\r\n<title>");
  client.println("Hello</title>\r\n<body>\r\n");
  client.println("<p>Hello from Teensy 3.1 and WIZ820io</p>\r\n");
  client.println("</body>\r\n</html>\r\n");
 ConvertAddress
 Returns: void
  union
    uint8_t bytes[4];
  } Address;
Headroom, thanks for your help - I got it going. I changed the sendpage function to this and now I get a page served.
  // send Hello msg
  client.println("<html>\r\n<head>\r\n<title>");
  client.println("Hello</title>\r\n</head>\r\n");
  client.println("<body><h1>Hello from Teensy 3.1 and WIZ820io</h1>\r\n");
I'll find out what code the 812MJ could tolerate but the 820io would not and post it. Thanks again!
