// The program is used to interface a Teensy 2.0 ++ with a custom designed
// Hardware that has the same functions as the CRJ-200 Autopilot panel.
// It is meant to work with the gorgeous CRJ-200 developed by Javier Rollon
http://www.jrollon.com
// To use this script with x-plane, you shall install Teensyduino and the
// USB Flight Sim Plugin
http://www.pjrc.com/teensy/td_flightsim.html
// Adds the great SimLED library, developed by Jack Deeth
// Adds two libraries to control Push Buttons and Encoders
#include "SimLED.h"
#include <Bounce.h>
#include <Encoder.h>
//#include <DogLcd.h>
// LED DATAREF
// Two statements to define a LED:
// FlightSimInteger intName; defines an integer linked to a x-plane parameter
// SiMLED intNameCtr (PIN_NUM, &intName, minDetect,maxDetect);
// ~ intName : is the name of the integer connected to x-plane parameter;
// ~ intNameCtr : is a function that calls the SimLED library
// ~ PIN_NUM : is the PIN number on Teensy
// ~ minDetect : is the minimum change value which calls the SimLED function;
// ~ maxDetect : is the maximum change value which calls the SimLED function;
FlightSimInteger apLight;
SimLED apLightCtr (PIN_C6, &apLight, 1,1);
FlightSimInteger xfrLight;
SimLED xfrLightCtr (PIN_F0, &xfrLight, 1,1);
FlightSimInteger speedLight;
SimLED speedLightCtr (PIN_F2, &speedLight, 1,8);
FlightSimInteger apprLight;
SimLED apprLightCtr (PIN_F4, &apprLight, 1,1);
FlightSimInteger hdgLight;
SimLED hdgLightCtr (PIN_F6, &hdgLight, 1,1);
FlightSimInteger navLight;
SimLED navLightCtr (PIN_A0, &navLight, 1,1);
FlightSimInteger altLight;
SimLED altLightCtr (PIN_A2, &altLight, 1,1);
FlightSimInteger vsLight;
SimLED vsLightCtr (PIN_A7, &vsLight, 1,16);
FlightSimInteger fdLight;
SimLED fdLightCtr (PIN_B5, &fdLight, 1,1);
FlightSimInteger turbLight;
SimLED turbLightCtr (PIN_B2, &turbLight, 1,1);
FlightSimInteger bcLight;
SimLED bcLightCtr (PIN_B7, &bcLight, 1,1);
FlightSimInteger bankLight;
SimLED bankLightCtr (PIN_C0, &bankLight, 1,1);
//FlightSimInteger fd2Light;
SimLED fd2LightCtr (PIN_C4, &fdLight, 1,1);
// X-PLANE COMMAND AND ENCODERS DATAREF
// Hardware objects, for accessing the buttons, and rotary encoder
Bounce apEngBtn = Bounce(PIN_C7, 10); // Pushbutton on pin C6, 10ms debounce
Bounce xfrBtn = Bounce(PIN_F1, 10);
Bounce speedBtn = Bounce(PIN_F3, 10);
Bounce apprBtn = Bounce(PIN_F5, 10);
Bounce hdgBtn = Bounce(PIN_F7, 10);
Bounce navBtn = Bounce(PIN_A1, 10);
Bounce altBtn = Bounce(PIN_A3, 10);
Bounce vsBtn = Bounce(PIN_A6, 10);
Bounce fdBtn = Bounce(PIN_B6, 10);
Bounce apDiscBtn = Bounce(PIN_B4, 10);
Bounce turbBtn = Bounce(PIN_B3, 10);
Bounce bcBtn = Bounce(PIN_D7, 10);
Bounce bankBtn = Bounce(PIN_C1, 10);
Bounce fd2Btn = Bounce(PIN_C5, 10);
//ENCODERS BUTTONS
Bounce crs1syncBtn = Bounce(PIN_B0, 10);
Bounce crs2syncBtn = Bounce(PIN_A5, 10);
Bounce altsyncBtn = Bounce(PIN_C2, 10);
Bounce hdgsyncBtn = Bounce(PIN_E1, 10);
Bounce speedsyncBtn = Bounce(PIN_D5, 10);
//Bounce vssyncBtn = Bounce(PIN_C3, 10);
// ENCODERS
Encoder speedEncoder = Encoder(PIN_D0, PIN_D4);
Encoder hdgEncoder = Encoder(PIN_D1, PIN_E0);
Encoder altEncoder = Encoder(PIN_E5, PIN_D3);
Encoder vsEncoder = Encoder(PIN_D2, PIN_E4);
Encoder crs1Encoder = Encoder(PIN_E7, PIN_B1);
Encoder crs2Encoder = Encoder(PIN_E6, PIN_A4);
// X-Plane objects, Command refs and Data ref
// BUTTONS UPPER
FlightSimInteger apEng;
FlightSimInteger xfrEng;
FlightSimInteger speedEng;
FlightSimInteger apprEng;
FlightSimInteger hdgEng;
FlightSimInteger navEng;
FlightSimInteger altEng;
FlightSimInteger vsEng;
// BUTTONS LOWER
FlightSimInteger fdEng;
FlightSimInteger apDiscEng;
FlightSimInteger turbEng;
FlightSimInteger bcEng;
FlightSimInteger bankEng;
FlightSimInteger fd2Eng;
//FlightSimInteger batteryMaster;
FlightSimInteger testAllLights;
//FlightSimInteger crs2btn_A;
FlightSimInteger crs2btn_B;
FlightSimInteger crs2btn_C;
// ENCODERS
FlightSimInteger altVal;
FlightSimInteger speedVal;
FlightSimInteger hdgVal;
FlightSimInteger vsVal;
FlightSimInteger crs1Val;
FlightSimInteger crs2DHVal;
FlightSimInteger VTVal;
FlightSimInteger altsyncC;
FlightSimInteger speedsyncC;
FlightSimInteger hdgsyncC;
FlightSimInteger crs1syncC;
FlightSimInteger crs2syncC;
FlightSimInteger crs1BarosyncC;
FlightSimFloat crs1BaroVal;
// Variables used in the routine
//long encoder_prev=0; // used for detecting rotary position change
long altVal_prev=0;
//long altenc;
long hdgVal_prev=0;
//long hdgenc;
long speedVal_prev=100;
//int speedenc=0;
long vsVal_prev=0;
//int vsenc=0;
long crs1Val_prev=0;
long crs1BaroVal_prev=29.92;
// int crs1enc=0;
long crs2DHVal_prev=0;
/*int crs2enc=0;
int crs1EBtnClick=0;
int crs1EBtn_mode=0;
int crs2EBtnClick=0;
int crs2EBtn_mode=0;
long VTVal_prev=90;
int spd_val=0;
//elapsedMillis fd_click_timer; // double click timer fd
elapsedMillis inactivityTimeout;// an inactivity timeout
// SETUP runs once, when Teensy boots.
// initialize all hardware
// ENCODERS PINMODE
pinMode(PIN_D0, INPUT_PULLUP); // SPEED ENC
pinMode(PIN_D4, INPUT_PULLUP); // SPEED ENC
pinMode(PIN_D5, INPUT_PULLUP); // SPEED BTN
pinMode(PIN_D1, INPUT_PULLUP); // HDG ENC
pinMode(PIN_E0, INPUT_PULLUP); // HDG ENC
pinMode(PIN_E1, INPUT_PULLUP); // HDG BTN
pinMode(PIN_D3, INPUT_PULLUP); // ALT ENC
pinMode(PIN_E5, INPUT_PULLUP); // ALT ENC
pinMode(PIN_C2, INPUT_PULLUP); // ALT BTN
pinMode(PIN_D2, INPUT_PULLUP); // VS ENC
pinMode(PIN_E4, INPUT_PULLUP); // VS ENC
//pinMode(PIN_C3, INPUT_PULLUP); // VS BTN
pinMode(PIN_E7, INPUT_PULLUP); // CRS1 ENC
pinMode(PIN_B1, INPUT_PULLUP); // CRS1 ENC
pinMode(PIN_B0, INPUT_PULLUP); // CRS1 BTN
pinMode(PIN_E6, INPUT_PULLUP); // CRS2 ENC
pinMode(PIN_A4, INPUT_PULLUP); // CRS2 ENC
pinMode(PIN_A5, INPUT_PULLUP); // CRS2 BTN
// BUTTONS UPPER PART
pinMode(PIN_C7, INPUT_PULLUP); // AP ENG
pinMode(PIN_F1, INPUT_PULLUP); // XFR
pinMode(PIN_F3, INPUT_PULLUP); // SPEED
pinMode(PIN_F5, INPUT_PULLUP); // APPR
pinMode(PIN_F7, INPUT_PULLUP); // HDG
pinMode(PIN_A1, INPUT_PULLUP); // NAV
pinMode(PIN_A3, INPUT_PULLUP); // ALT
pinMode(PIN_A6, INPUT_PULLUP); //VS
// BUTTONS LOWER PART
pinMode(PIN_B6, INPUT_PULLUP); // FD1
pinMode(PIN_B4, INPUT_PULLUP); // APD
pinMode(PIN_B3, INPUT_PULLUP); // TRB
pinMode(PIN_D7, INPUT_PULLUP); // BC
pinMode(PIN_C1, INPUT_PULLUP); // BANK
pinMode(PIN_C5, INPUT_PULLUP); // FD2
//pinMode(6, OUTPUT);
// LEDS X-PLANE DATAREF
// Links the variables to the proper DATAREF
apLight = XPlaneRef("CRJ/autopilot/ap_eng_light");
xfrLight = XPlaneRef("CRJ/autopilot/xpr_light");
speedLight = XPlaneRef("CRJ/autopilot/spd_light");
apprLight = XPlaneRef("CRJ/autopilot/appr_light");
hdgLight = XPlaneRef("CRJ/autopilot/hdg_light");
navLight = XPlaneRef("CRJ/autopilot/nav_light");
altLight = XPlaneRef("CRJ/autopilot/alt_light");
vsLight = XPlaneRef("CRJ/autopilot/vs_light");
fdLight = XPlaneRef("CRJ/autopilot/fd_light");
turbLight = XPlaneRef("CRJ/autopilot/turb_light");
bcLight = XPlaneRef("CRJ/autopilot/bcrs_light");
bankLight = XPlaneRef("CRJ/autopilot/bank_light");
//fd2Light = XPlaneRef("CRJ/mfd/nav_source"); // Forse da mettere cmq fd
// BUTTONS X-PLANE DATAREF
apEng = XPlaneRef("CRJ/autopilot/ap_eng_button");
xfrEng = XPlaneRef("CRJ/autopilot/xpr_button");
speedEng = XPlaneRef("CRJ/autopilot/speed_button");
apprEng = XPlaneRef("CRJ/autopilot/appr_button");
hdgEng = XPlaneRef("CRJ/autopilot/hdg_button");
navEng = XPlaneRef("CRJ/autopilot/nav_button");
altEng = XPlaneRef("CRJ/autopilot/alt_button");
vsEng = XPlaneRef("CRJ/autopilot/v_button");
fdEng = XPlaneRef("CRJ/autopilot/fd_button");
apDiscEng = XPlaneRef("CRJ/autopilot/ap_disc_button");
turbEng = XPlaneRef("CRJ/autopilot/turbo_button");
bcEng = XPlaneRef("CRJ/autopilot/backcrs_button");
bankEng = XPlaneRef("CRJ/autopilot/12_bank_button");
fd2Eng = XPlaneRef("CRJ/mfd/nav_source");
testAllLights = XPlaneRef("sim/weapons/z[13]");
//batteryMaster = XPlaneRef("CRJ/syselec/main_batt");
//crs2btn_A = XPlaneRef("CRJ/autopilot/alt_sync");
crs2btn_B =XPlaneRef("CRJ/spd/sel_button");
crs2btn_C=XPlaneRef("CRJ/spd/tgt_vspds");
// ENCODER DATAREF
hdgVal = XPlaneRef("CRJ/autopilot/hdg");
altVal = XPlaneRef("CRJ/autopilot/alt");
speedVal = XPlaneRef("CRJ/autopilot/speed");
vsVal = XPlaneRef("CRJ/autopilot/verticalspeed");
crs1Val = XPlaneRef("CRJ/autopilot/crs1"); // CRS1 MODE0
crs1BaroVal = XPlaneRef("CRJ/baro/pressure"); // CRS1 MODE1 Pressure
crs2DHVal = XPlaneRef("CRJ/dh_mda_tune"); // CRS2 MODE1 DH
VTVal = XPlaneRef("CRJ/spd/tune"); // CRS2 MODE0 VT Speeds
altsyncC = XPlaneRef("CRJ/autopilot/alt_sync");
hdgsyncC = XPlaneRef("CRJ/autopilot/hdg_sync");
speedsyncC = XPlaneRef("CRJ/autopilot/knots_mach");
crs1syncC = XPlaneRef("CRJ/autopilot/crs1_sync"); // CRS1 SYNC
crs1BarosyncC = XPlaneRef("CRJ/baro/pressure_std"); // CRS1 MODE1 BARO SYNC
crs2syncC = XPlaneRef("CRJ/dh_mda_hide"); // CRS2 SYNC DH
// hdgenc = hdgVal;
//altenc = altVal;
// Invokes the SimLED setup routine
SimLED::setup();
// LOOP runs repetitively, as long as Teensy is powered up
// normally the first step in loop() should update from X-Plane
FlightSim.update();
// Update the LED STATE or enable the test all lights command,
// only when the battery Master switch is on (airplane Feed ON).
SimLED::update();
//if (batteryMaster==1)
// TEST LIGHT MODE
SimLED::lightTest(testAllLights==1);
// HDG ENCODER
// read the rotary encoder, if it's changed, write to hdgValue
// HDG ENCODER SYNC BUTTON
if ( hdgsyncBtn.update() ) {
if ( hdgsyncBtn.read() == HIGH) {
if ( hdgsyncC == 0 ) {
hdgsyncC = 1;
Serial.println("HDGSYNC!!!");
else {
hdgsyncC = 0;
// ENCODER ROUTINE
long hdgenc = hdgEncoder.read();
if (hdgenc != hdgVal_prev) {
if (hdgVal>359)
hdgVal=0;
hdgEncoder.write(0);
hdgVal_prev=0;
Serial.print("HDGVAL: ");
Serial.print(hdgVal);
Serial.print(" HDGVAL_prev: ");
Serial.println(hdgVal_prev);
if (abs(hdgenc-hdgVal_prev)>1)
if (inactivityTimeout<25)
hdgVal = hdgVal + (hdgenc - hdgVal_prev)/abs(hdgenc - hdgVal_prev)*4;
hdgVal = hdgVal + (hdgenc - hdgVal_prev)/abs(hdgenc - hdgVal_prev);
// Serial.println(altVal);
hdgVal_prev = hdgenc;
inactivityTimeout=0;
Serial.print("torno?");
Serial.println(" No");
// ALT ENCODER
// read the rotary encoder, if it's changed, write to altValue
long altenc = altEncoder.read();
if (altenc != altVal_prev) {
if (altVal<-10)
//Serial.println("OUTBOUND!!");
altVal=-10;
altEncoder.write(-10);
altVal_prev=-10;
Serial.print("ALTVAL: ");
Serial.print(altVal);
Serial.print(" ALTVAL_prev: ");
Serial.println(altVal_prev);
//Serial.print("ENCODER: ");
//Serial.println(altenc);
//Serial.print("timer: ");
//Serial.println(inactivityTimeout);
if (abs(altenc-altVal_prev)>1)
altVal = altVal + (altenc - altVal_prev)/abs(altenc - altVal_prev)*4;
altVal = altVal + (altenc - altVal_prev)/abs(altenc - altVal_prev);
altVal_prev = altenc;
//delay(50);
if ( altsyncBtn.update() ) {
if ( altsyncBtn.read() == HIGH) {
if ( altsyncC == 0 ) {
altsyncC = 1;
else {
altsyncC = 0;
// SPEED ENCODER
long speedenc = speedEncoder.read();
if (speedenc != speedVal_prev) {
if (speedVal<100)
speedVal=100;
speedEncoder.write(100);
speedVal_prev=100;
Serial.print("SPEEDVAL: ");
Serial.print(speedVal);
Serial.print("SPEEDVAL_prev: ");
Serial.println(speedVal_prev);
if (abs(speedenc-speedVal_prev)>1)
speedVal = speedVal + (speedenc - speedVal_prev)/abs(speedenc - speedVal_prev)*4;
speedVal = speedVal + (speedenc - speedVal_prev)/abs(speedenc - speedVal_prev);
speedVal_prev = speedenc;
//return;
if ( speedsyncBtn.update() ) {
if ( speedsyncBtn.read() == HIGH) {
if ( speedsyncC == 0 ) {
speedsyncC = 1;
else {
speedsyncC = 0;
// VS ENCODER
long vsenc = vsEncoder.read();
if (vsenc != vsVal_prev) {
if (vsVal>50)
vsVal=50;
vsEncoder.write(50);
vsVal_prev=50;
else if (vsVal<-40){
vsVal=-40;
vsEncoder.write(-40);
vsVal_prev=-40;
Serial.print("VSVAL: ");
Serial.print(vsVal);
Serial.print("VSVAL_prev: ");
Serial.println(vsVal_prev);
if (abs(vsenc-vsVal_prev)>1)
vsVal = vsVal + (vsenc - vsVal_prev)/abs(vsenc - vsVal_prev)*4;
vsVal = vsVal + (vsenc - vsVal_prev)/abs(vsenc - vsVal_prev);
vsVal_prev = vsenc;
//return;
delay(50);
// CRS1 ENCODER BTN ROUTINE
// First part of the script catches a click, stores the
// information in the variable crs2EBtnClick and starts a timer
// inactivityTimeout.
// Catches single click
if (crs1EBtnClick ==0)
if ( crs1syncBtn.update() )
// ROUTINE BOTTONE 2
if ( crs1syncBtn.read() == HIGH)
Serial.println("SYNC");
inactivityTimeout = 0;
crs1EBtnClick =1;
// Timer for Double Single click
if ((inactivityTimeout<200) && (crs1EBtnClick==1))
//ROUTINE DOUBLE CLICK
if (crs1syncBtn.update() )
//Serial.println("DOUBLE CLICK");
//Serial.println("SYNC");
// inactivityTimeout = 0;
if (crs1EBtn_mode==1)
// SWITCH BETWEEN TWO MODES OF SINGLE CLICK
crs1EBtn_mode=0;
crs1EBtn_mode=1;
// SINGLE BLINK OF THE LED
//digitalWrite(6, HIGH);
//delay(40);
//digitalWrite(6, LOW);
crs1EBtnClick =0;
// SINGLE CLICK ROUTINE
else if (inactivityTimeout>=200 && crs1EBtnClick==1)
// DO SINGLE CLICK MODE 1
if (crs1EBtn_mode==1) // BARO SYNC
if ( crs1BarosyncC == 0 ) {
crs1BarosyncC = 1;
//DECISION HEIGHT KNOB ON OFF
else {
crs1BarosyncC = 0;
crs1EBtnClick=0;
// DO SINGLE CLICK MODE 0
else // crs1EBtn_mode=0
if ( crs1syncC == 0 ) {
crs1syncC = 1;
else {
crs1syncC = 0;
crs1EBtnClick=0;
// ENCODER CRS1 TWO MODES
if(crs1EBtn_mode==1) // BARO
long crs1enc = crs1Encoder.read();
if (crs1enc != crs1BaroVal_prev) {
if (crs1BaroVal>31.00) {
crs1BaroVal=31.00;
crs1Encoder.write(31.00);
crs1BaroVal_prev=31.00;
else if (crs1BaroVal<27.90)
crs1BaroVal=27.90;
crs1Encoder.write(27.90);
crs1BaroVal_prev=27.90;
if (abs(crs1enc-crs1BaroVal_prev)>1)
crs1BaroVal = crs1BaroVal - (crs1enc - crs1BaroVal_prev)/abs(crs1enc - crs1BaroVal_prev)*4*0.01;
crs1BaroVal = crs1BaroVal - (crs1enc - crs1BaroVal_prev)/abs(crs1enc - crs1BaroVal_prev)*0.01;
crs1BaroVal_prev = crs1enc;
else // CRS1
if (crs1enc != crs1Val_prev) {
if (crs1Val>360)
crs1Val=0;
crs1Encoder.write(0);
crs1Val_prev=0;
if (abs(crs1enc-crs1Val_prev)>1)
crs1Val = crs1Val - (crs1enc - crs1Val_prev)/abs(crs1enc - crs1Val_prev)*4;
crs1Val = crs1Val - (crs1enc - crs1Val_prev)/abs(crs1enc - crs1Val_prev);
crs1Val_prev = crs1enc;
if (crs1Val>360)
crs1Val=0;
crs1Val_prev=0;
crs1Val = crs1Val + (crs1enc - crs1Val_prev)/abs(crs1enc - crs1Val_prev)*4;
crs1Val = crs1Val + (crs1enc - crs1Val_prev)/abs(crs1enc - crs1Val_prev);
if ( crs1syncBtn.update() ) {
if ( crs1syncBtn.read() == HIGH) {
crs1syncC = 1;
else {
crs1syncC = 0;
// CRS2 ENCODER BTN ROUTINE
if (crs2EBtnClick ==0)
if ( crs2syncBtn.update() )
if ( crs2syncBtn.read() == HIGH)
crs2EBtnClick =1;
// Second part of the script verifies the click/timer condition:
// - if elapsed time is less than 200 ms, a click was previously
// made, and another click is received, the double click routine
// cycles through the 2 modes.
// - if elapsed time is more than 200 ms, and a click was previously
// made, the single button click routine is performed.
if ((inactivityTimeout<200) && (crs2EBtnClick==1))
if (crs2syncBtn.update() )
if (crs2EBtn_mode==1)
crs2EBtn_mode=0;
crs2EBtn_mode=1;
//delay(40);
crs2EBtnClick =0;
else if (inactivityTimeout>=200 && crs2EBtnClick==1)
if (crs2EBtn_mode==1) // DECISION HEIGHT SYNC
if ( crs2syncC == 0 ) {
crs2syncC = 1;
else {
crs2syncC = 0;
crs2EBtnClick=0;
else // crs2EBtn_mode=0
//Serial.println("SINGLE CLICK");
//Serial.print("SPD_VAL=");
//Serial.println(spd_val);
// CUSTOM ROUTINE DUE TO V1 V2 VR VT
// crs2btn_B = V1 V2 VR
// crs2btn_C = TGT SPEED KNOB
// spd_val goes from 0 to 3, and is used for the encoder
// to adjust the values of V1 V2 VR and VT.
if (spd_val==0)
// CHANGES BETWEEN the other Velocities to VT
spd_val=spd_val+1;
crs2btn_C=0;
else if(spd_val==1)
// CHANGES BETWEEN VT and the other Velocities
spd_val=spd_val+1;
crs2btn_C=1;
crs2btn_B=1;
else if (spd_val<=3)
// CYCLES through V1 V2 VR
crs2btn_B=1;
spd_val=spd_val+1;
if( spd_val==4)
spd_val=0;
crs2EBtnClick=0;
//Serial.println("FineSingle2ON");
// ENCODER CRS2 TWO MODES
if(crs2EBtn_mode==1) // DH
long crs2enc = crs2Encoder.read();
if (crs2enc != crs2DHVal_prev) {
if (crs2DHVal<0)
crs2DHVal=0;
crs2Encoder.write(0);
crs2DHVal_prev=0;
if (abs(crs2enc-crs2DHVal_prev)>1)
crs2DHVal = crs2DHVal + (crs2enc - crs2DHVal_prev)/abs(crs2enc - crs2DHVal_prev)*4*10;
crs2DHVal = crs2DHVal + (crs2enc - crs2DHVal_prev)/abs(crs2enc - crs2DHVal_prev)*10;
crs2DHVal_prev = crs2enc;
//Serial.print("torno?");
//return;
//Serial.println(" No");
//delay(50);
if (crs2enc != VTVal_prev) {
if (VTVal<90)
VTVal=90;
crs2Encoder.write(90);
VTVal_prev=90;
if (abs(crs2enc-VTVal_prev)>1)
VTVal = VTVal + (crs2enc - VTVal_prev)/abs(crs2enc - VTVal_prev)*4;
VTVal = VTVal + (crs2enc - VTVal_prev)/abs(crs2enc - VTVal_prev);
VTVal_prev = crs2enc;
//return;
//delay(50);
// || BUTTONS NORMAL ROUTINES ||
// Autopilot Engage Button
if ( apEngBtn.update() ) {
if ( apEngBtn.read() == HIGH) {
if ( apEng == 0 ) {
apEng = 1;
else {
apEng = 0;
// XFR Engage Button
if ( xfrBtn.update() ) {
if ( xfrBtn.read() == HIGH) {
if ( xfrEng == 0 ) {
xfrEng = 1;
else {
xfrEng = 0;
// SPEED Engage Button
if ( speedBtn.update() ) {
if ( speedBtn.read() == HIGH) {
if ( speedEng == 0 ) {
speedEng = 1;
else {
speedEng = 0;
// APPR Engage Button
if ( apprBtn.update() ) {
if ( apprBtn.read() == HIGH) {
if ( apprEng == 0 ) {
apprEng = 1;
else {
apprEng = 0;
// HDG Engage Button
if ( hdgBtn.update() ) {
if ( hdgBtn.read() == HIGH) {
if ( hdgEng == 0 ) {
hdgEng = 1;
else {
hdgEng = 0;
// NAV Engage Button
if ( navBtn.update() ) {
if ( navBtn.read() == HIGH) {
if ( navEng == 0 ) {
navEng = 1;
else {
navEng = 0;
// ALT Engage Button
if ( altBtn.update() ) {
if ( altBtn.read() == HIGH) {
if ( altEng == 0 ) {
altEng = 1;
else {
altEng = 0;
// VS Engage Button
if ( vsBtn.update() ) {
if ( vsBtn.read() == HIGH) {
if ( vsEng == 0 ) {
vsEng = 8;
else {
vsEng = 0;
// FD Engage Button
if ( fdBtn.update() ) {
if ( fdBtn.read() == HIGH) {
if ( fdEng == 0 ) {
fdEng = 1;
Serial.println("FDENGAGE");
else {
fdEng = 0;
// APDISC Engage Button
if ( apDiscBtn.update() ) {
if ( apDiscBtn.read() == HIGH) {
if ( apDiscEng == 0 ) {
apDiscEng = 1;
else {
apDiscEng = 0;
// TURB Engage Button
if ( turbBtn.update() ) {
if ( turbBtn.read() == HIGH) {
if ( turbEng == 0 ) {
turbEng = 1;
else {
turbEng = 0;
// BC Engage Button
if ( bcBtn.update() ) {
if ( bcBtn.read() == HIGH) {
if ( bcEng == 0 ) {
bcEng = 1;
else {
bcEng = 0;
// 1/2 BANK Engage Button
if ( bankBtn.update() ) {
if ( bankBtn.read() == HIGH) {
if ( bankEng == 0 ) {
bankEng = 1;
else {
bankEng = 0;
// FD2 Engage Button
if ( fd2Btn.update() ) {
if ( fd2Btn.read() == HIGH) {
if ( fd2Eng == 0 ) {
fd2Eng = 1; // NAV1 VOR MODE
else if (fd2Eng ==1) {
fd2Eng = 2; // NAV2 VOR MODE
else if (fd2Eng ==2) {
fd2Eng = 3; // FMS MODE
else if (fd2Eng ==3) {
fd2Eng = 0; // OFF
Serial.println("NAV1 NAV2 FMS OFF");
