Results 1 to 6 of 6
Thread: concatenate 3 HEX values to RGB?
    7
    Question concatenate 3 HEX values to RGB?
    Im trying to concatenate three hex values(redval,greenval,blueval) into a RGB Value(0xFFFFFF) is this possible? I've been trying for a while and it just wont work...(i already googled for help and still couldn't find anyone who has successfully done it.
    27,995
    int color = (redval << 16) | (greenval << 8) | (blueval);
    7
    ummm seems to out put just a number from 0-255.
    perhaps how im converting to hex isnt right?
    redval = (redval, HEX);
    ah its not right its just giving the value of "16"
    27,995
    I do not understand exactly what you need.
    7
    okay so here is what i have.
    I have three potentiometer each with a integer variable(redval,greenval,blueval) with a value between 0-255.
    What i want to do is turn these three variables into a color code( ie. 0x00FF00 or 0xFFFFFF) that is represented by the potentiometers.
    Does that explain it better?
    4,417
    Cool
    I would imagine:
    unsigned long color_code;
    color_code = ((((unsigned long)(redval & 0xff)) << 16)
    	      | (((unsigned long)(greenval & 0xff)) << 8)
    	      | ((unsigned long)(blueval & 0xff)));
Tags for this Thread
