Results 1 to 2 of 2
Thread: Teensy2++ with stonyman vision breakout board part 1
    10
    The following code changes are for the ardueye stonyman breakout board to run on Teensy 2++ as ammended by me
    Don't forget to add the 1286 def type to any examples
    // pin_defs_1286.h
    // ArduEye Library for the ATMega 1286
    // Defines pin interface between ATMega 1286 and
    // Stonyman/Hawksbill vision chips
    // Working revision started July 9, 2012
    Copyright (c) 2012 Centeye, Inc.
    All rights reserved.
    Redistribution and use in source and binary forms, with or without
    modification, are permitted provided that the following conditions are met:
    Redistributions of source code must retain the above copyright notice,
    this list of conditions and the following disclaimer.
    Redistributions in binary form must reproduce the above copyright notice,
    this list of conditions and the following disclaimer in the documentation
    and/or other materials provided with the distribution.
    THIS SOFTWARE IS PROVIDED BY CENTEYE, INC. ``AS IS'' AND ANY EXPRESS OR
    IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF
    MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO
    EVENT SHALL CENTEYE, INC. OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT,
    INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING,
    BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
    DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY
    OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING
    NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
    EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
    The views and conclusions contained in the software and documentation are
    those of the authors and should not be interpreted as representing official
    policies, either expressed or implied, of Centeye, Inc.
    #ifndef _PIN_DEFS_1286_H_INCLUDED
    #define _PIN_DEFS_1286_H_INCLUDED
    //RESP pin TEENSY2++ E0
    #define SMH_RESP_PORT PORTE
    #define SMH_RESP_DDR DDRE
    #define SMH_RESP_PIN 0x01
    //INCP pin TEENSY2++D7
    #define SMH_INCP_PORT PORTD
    #define SMH_INCP_DDR DDRD
    #define SMH_INCP_PIN 0x80
    //RESV pin TEENSY2++ D6
    #define SMH_RESV_PORT PORTD
    #define SMH_RESV_DDR DDRD
    #define SMH_RESV_PIN 0x40
    //INCV pin TEENSY2++ D5
    #define SMH_INCV_PORT PORTD
    #define SMH_INCV_DDR DDRD
    #define SMH_INCV_PIN 0x20
    //INPHI pin TEENSY2++ D4
    #define SMH_INPHI_PORT PORTD
    #define SMH_INPHI_DDR DDRD
    #define SMH_INPHI_PIN 0x10
    //ANALOG OUT pins (4 supported)
    #define SMH_ANALOG_PORT PORTF
    #define SMH_ANALOG_DDR DDRF
    #define SMH_ANALOG0 0x01
    #define SMH_ANALOG1 0x02
    #define SMH_ANALOG2 0x04
    #define SMH_ANALOG3 0x08
    //EXTERNAL ADC SS pin TEENSY2++ E1
    #define SMH_ADC_SS_PORT PORTE
    #define SMH_ADC_SS_DDR DDRE
    #define SMH_ADC_SS_PIN 0x02
ID:	273   Click image for larger version.
    10
    // ArduEye_SMH_v1.h
    // ArduEye Library for the Stonyman/Hawksbill Centeye Vision Chips
    // Basic functions to operate Stonyman/Hawksbill with ArduEye boards
    // Supports all Arduino boards that use the ATMega 8/168/328/2560/AVR_AT90USB1286
    // NOTE: ATMega 2560 SPI for external ADC is not supported.
    #ifndef _ARDUEYE_SMH_H_INCLUDED
    #define _ARDUEYE_SMH_H_INCLUDED
    //supports older version of ARDUINO IDE
    #if defined(ARDUINO) && ARDUINO >= 100
    #include "Arduino.h"
    #else
    #include "WProgram.h"
    //loads pin definitions based on the board type
    //set in the Arduino IDE
    //currently supports ATmega2560/8/168/328/AVR_AT90USB1286
    #if defined(__AVR_ATmega2560__)
    # include "pin_defs_2560.h" //2560 defs
    #elif defined (__AVR_ATmega8__)||(__AVR_ATmega168__)|(__AVR_ATme ga168P__)||(__AVR_ATmega328P__)
    # include "pin_defs_168_328.h" //8/168/328 defs
    #elif defined (__AVR_AT90USB1286__)
    # include "pin_defs_1286.h" //AVR_AT90USB1286
    #else
    # error "Code only supports ATmega 2560 and ATmega 8/168/328"
    //copy pin defs from loaded pin_def headers
    #define RESP_PORT SMH_RESP_PORT
    #define RESP_DDR SMH_RESP_DDR
    #define RESP SMH_RESP_PIN
    #define INCP_PORT SMH_INCP_PORT
    #define INCP_DDR SMH_INCP_DDR
    #define INCP SMH_INCP_PIN
    #define RESV_PORT SMH_RESV_PORT
    #define RESV_DDR SMH_RESV_DDR
    #define RESV SMH_RESV_PIN
    #define INCV_PORT SMH_INCV_PORT
    #define INCV_DDR SMH_INCV_DDR
    #define INCV SMH_INCV_PIN
    #define INPHI_PORT SMH_INPHI_PORT
    #define INPHI_DDR SMH_INPHI_DDR
    #define INPHI SMH_INPHI_PIN
    #define ADC_SS_PORT SMH_ADC_SS_PORT
    #define ADC_SS_DDR SMH_ADC_SS_DDR
    #define ADC_SS SMH_ADC_SS_PIN
    #define ANALOG_PORT SMH_ANALOG_PORT
    #define ANALOG_DDR SMH_ANALOG_DDR
    #define ANALOG0 SMH_ANALOG0
    #define ANALOG1 SMH_ANALOG1
    #define ANALOG2 SMH_ANALOG2
    #define ANALOG3 SMH_ANALOG3
    //MACROS to pulse chip lines
    #define SMH1_ResP_Pulse {RESP_PORT|=RESP;RESP_PORT&=~RESP;}
    #define SMH1_IncP_Pulse {INCP_PORT|=INCP;INCP_PORT&=~INCP;}
    #define SMH1_ResV_Pulse {RESV_PORT|=RESV;RESV_PORT&=~RESV;}
    #define SMH1_IncV_Pulse {INCV_PORT|=INCV;INCV_PORT&=~INCV;}
    //MACROS for inphi (delay is inserted between high and low)
    #define SMH1_InPhi_SetHigh {INPHI_PORT|=INPHI;}
    #define SMH1_InPhi_SetLow {INPHI_PORT&=~INPHI;}
    //MACRO to set all pins low
    #define SMH1_SetAllLow {RESP_PORT&=~RESP;INCP_PORT&=~INCP;RESV_PORT&=~RES V;INCV_PORT&=~INCV;INPHI_PORT&=~INPHI;}
    //SMH System Registers
    #define SMH_SYS_COLSEL 0 //select column
    #define SMH_SYS_ROWSEL 1 //select row
    #define SMH_SYS_VSW 2 //vertical switching
    #define SMH_SYS_HSW 3 //horizontal switching
    #define SMH_SYS_CONFIG 5 //configuration register
    #define SMH_SYS_VREF 4 //voltage reference
    #define SMH_SYS_NBIAS 6 //nbias
    #define SMH_SYS_AOBIAS 7 //analog out bias
    //default values
    // Supply voltage types
    // Notation: AVB is A.B volts. e.g. 5V0 is 5V, 3V3 is 3.3V, etc.
    #define SMH1_VDD_5V0 1
    #define SMH_VREF_5V0 30 //vref for 5 volts
    #define SMH_NBIAS_5V0 55 //nbias for 5 volts
    #define SMH_AOBIAS_5V0 55 //aobias for 5 volts
    #define SMH_GAIN_DEFAULT 0 //no amp gain
    #define SMH_SELAMP_DEFAULT 0 //amp bypassed
    // ADC types
    // ARDUINO ONBOARD ADC
    #define SMH1_ADCTYPE_ONBOARD 0
    // MCP3201, Microchip, 12bits, 100ksps
    #define SMH1_ADCTYPE_MCP3201 1
    // MCP3201, Microchip, 12bits, 100ksps, for ArduEye Bug v1.0
    #define SMH1_ADCTYPE_MCP3201_2 2
    // MCP3001, Microchip, 10bits, 200ksps
    #define SMH1_ADCTYPE_MCP3001 3
    // ArduEyeSMHClass
    class ArduEyeSMHClass
    private:
    //indicates whether amplifier is in use
    char useAmp;
    public:
    // Initialize the vision chip for image readout
    void begin(short vref=SMH_VREF_5V0,short nbias=SMH_NBIAS_5V0,short aobias=SMH_AOBIAS_5V0,char gain=SMH_GAIN_DEFAULT,char selamp=SMH_SELAMP_DEFAULT);
    // Chip Register and Value Manipulation
    //set pointer on chip
    void setPointer(char ptr);
    //set value of current pointer
    void setValue(short val);
    //increment value of current pointer
    void incValue(short val);
    //pulse INPHI to operate amplifier
    void pulseInphi(char delay);
    //clear all register values
    void clearValues(void);
    //set pointer to register and set value for that register
    void setPointerValue(char ptr,short val);
    //set configuration register on chip
    void setConfig(char gain, char selamp,char cvdda=1);
    //select amp and set amp gain
    void setAmpGain(char gain);
    //set analog input to Arduino for onboard ADC
    void setAnalogInput(char analogInput);
    //set external ADC input
    void setADCInput(char ADCInput,char state);
    //set hsw and vsw registers to bin on-chip
    void setBinning(short hbin,short vbin);
    // Bias functions
    //set individual bias values
    void setVREF(short vref);
    void setNBIAS(short nbias);
    void setAOBIAS(short aobias);
    //set biases based on Vdd
    void setBiasesVdd(char vddType);
    //set all bias values
    void setBiases(short vref,short nbias,short aobias);
    // Image Functions
    //given an image, returns a fixed-pattern noise mask and mask_base
    void calcMask(short *img, short size, unsigned char *mask, short *mask_base);
    //applies pre-calculated FPN mask to an image
    void applyMask(short *img, short size, unsigned char *mask, short mask_base);
    //gets an image from the vision chip
    void getImage(short *img, unsigned char rowstart, unsigned char numrows, unsigned char rowskip, unsigned char colstart, unsigned char numcols, unsigned char colskip, char ADCType,char anain);
    //gets a image from the vision chip, sums each row and returns one pixel for the row
    void getImageRowSum(short *img, unsigned char rowstart, unsigned char numrows, unsigned char rowskip, unsigned char colstart, unsigned char numcols, unsigned char colskip, char ADCType,char anain);
    //gets a image from the vision chip, sums each col and returns one pixel for the col
    void getImageColSum(short *img, unsigned char rowstart, unsigned char numrows, unsigned char rowskip, unsigned char colstart, unsigned char numcols, unsigned char colskip, char ADCType,char anain);
    //takes an image and returns the maximum value row and col
    void findMax(unsigned char rowstart, unsigned char numrows, unsigned char rowskip, unsigned char colstart, unsigned char numcols, unsigned char colskip, char ADCType,char anain,unsigned char *max_row, unsigned char *max_col);
    //prints the entire vision chip over serial as a Matlab array
    void chipToMatlab(char whichchip,char ADCType,char anain);
    //prints a section of the vision chip over serial as a Matlab array
    void sectionToMatlab(unsigned char rowstart, unsigned char numrows, unsigned char rowskip, unsigned char colstart, unsigned char numcols, unsigned char colskip, char ADCType, unsigned char anain);
    //external definition of ArduEyeSMH class instance
    extern ArduEyeSMHClass ArduEyeSMH;
