Results 1 to 4 of 4
Thread: Teensy 3.0 and USB MIDI (problem and fix)
    Boston, MA, USA
    1,111
    After downloading the recently posted 1Dec snapshot, I noticed there was some Teensy 3.0 MIDI code although it was disabled by default.
    I enabled it in hardfware/teensy/boards.txt by uncommenting these three lines:
    teensy3.menu.usb.midi.name=MIDI
    teensy3.menu.usb.midi.build.define0=-DUSB_MIDI
    teensy3.menu.usb.midi.fake_serial=teensy_gateway
    and then tried the following sketch, which works in Teensy 2.0.
    // USB MIDI workout for Teensy family
    // set USB type to MIDI
    //#include <MIDI-notenames.h>
    #define Eflat_1 51
    #define C0 60
    #define tuningA 69
    const uint8_t channel = 1;             // MIDI channel
    const uint8_t moderate = 96;       // MIDI note velocity
    uint8_t Major[8] = {
      0, 2, 4, 5, 7, 9, 11, 12 };     // semitone intervals from root note of scale
    uint8_t Minor[8] = {
      0, 2, 3, 5, 7, 9, 11, 12 };
    void playScale(uint8_t note,  uint8_t scale[]);
      delay(5000); // time to get organized
      // Tune up
      usbMIDI.sendNoteOn(tuningA, moderate, channel);
      usbMIDI.sendNoteOff(tuningA, 0, channel);
      // Some scales
      playScale(C0, Major);
      playScale(Eflat_1, Minor);
      slide(C0, 3000, 4000);
      slide(C0, -5000, 7000);
    void playScale(uint8_t note,  uint8_t scale[])  {
      // play a scale with a given root note
      int duration = 1000;
      int between = 500;
      uint8_t i;
      uint8_t tone;
      for (i=0; i <8; i++) {
        tone = note+scale[i];
        usbMIDI.sendNoteOn(tone, moderate, channel);
        delay(duration);
        usbMIDI.sendNoteOff(tone, moderate, channel);
        delay(between);
    void slide(uint8_t note, int amount, int duration) {
      // play a note, then pitchbend it for the given duration (in ms)
      // amount is negative for bend down, positive for bend up, range +-8k
      int steps;            // number of pitchbend messages we will send
      int bendstep;     // change in pitchbend value per step
      int i;                    // loop counter
      int thisbend;      // signed pitchbend amount for this step
      uint16_t value;  // unsigned pitchbend amount (zero is 8k)
      // send pitchbend every 50ms so as not to overload the MIDI processor
      steps = duration / 50;
      bendstep = amount / steps;
      usbMIDI.sendNoteOn(note, moderate, channel);
      for (i=1; i<=steps; i++) {
        thisbend = bendstep * i;
        value = 0x2000 + thisbend;
        usbMIDI.sendPitchBend(value, channel);
        delay(50);
      usbMIDI.sendNoteOff(note, moderate, channel);
    The note on and off was correct but the pitchbend was not; looking at the output in MIDI-OX, note-on commands were being sent instead, with the high and low bytes of the pitchbend becomig the note and velocity respectively.
    Comparing the relevant portions of hardware/teensy/cores/usbmidi/usbapi.cpp:
    void usb_midi_class::sendNoteOff(uint8_t note, uint8_t velocity, uint8_t channel)
    	send_raw(0x08, 0x80 | ((channel - 1) & 0x0F), note & 0x7F, velocity & 0x7F);
    void usb_midi_class::sendNoteOn(uint8_t note, uint8_t velocity, uint8_t channel)
    	send_raw(0x09, 0x90 | ((channel - 1) & 0x0F), note & 0x7F, velocity & 0x7F);
    void usb_midi_class::sendPolyPressure(uint8_t note, uint8_t pressure, uint8_t channel)
    	send_raw(0x0A, 0xA0 | ((channel - 1) & 0x0F), note & 0x7F, pressure & 0x7F);
    void usb_midi_class::sendControlChange(uint8_t control, uint8_t value, uint8_t channel)
    	send_raw(0x0B, 0xB0 | ((channel - 1) & 0x0F), control & 0x7F, value & 0x7F);
    void usb_midi_class::sendProgramChange(uint8_t program, uint8_t channel)
    	send_raw(0x0C, 0xC0 | ((channel - 1) & 0x0F), program & 0x7F, 0);
    void usb_midi_class::sendAfterTouch(uint8_t pressure, uint8_t channel)
    	send_raw(0x0D, 0xD0 | ((channel - 1) & 0x0F), pressure & 0x7F, 0);
    void usb_midi_class::sendPitchBend(uint16_t value, uint8_t channel)
    	send_raw(0x0E, 0xE0 | ((channel - 1) & 0x0F), value & 0x7F, (value >> 7) & 0x7F);
    with hardware/teensy/cores/teensy3/usb_midi.h:
            void sendNoteOff(uint32_t note, uint32_t velocity, uint32_t channel) __attribute__((always_inline)) {
    		usb_midi_write_packed(0x8008 | (((channel - 1) & 0x0F) << 8)
    		  | ((note & 0x7F) << 16) | ((velocity & 0x7F) << 24));
            void sendNoteOn(uint32_t note, uint32_t velocity, uint32_t channel) __attribute__((always_inline)) {
    		usb_midi_write_packed(0x9009 | (((channel - 1) & 0x0F) << 8)
            void sendPolyPressure(uint32_t note, uint32_t pressure, uint32_t channel) __attribute__((always_inline)) {
    		  | ((note & 0x7F) << 16) | ((pressure & 0x7F) << 24));
            void sendControlChange(uint32_t control, uint32_t value, uint32_t channel) __attribute__((always_inline)) {
    		  | ((control & 0x7F) << 16) | ((value & 0x7F) << 24));
            void sendProgramChange(uint32_t program, uint32_t channel) __attribute__((always_inline)) {
    		  | ((channel & 0x7F) << 16));
            void sendAfterTouch(uint32_t pressure, uint32_t channel) __attribute__((always_inline)) {
    		  | ((pressure & 0x7F) << 16));
            void sendPitchBend(uint32_t value, uint32_t channel) __attribute__((always_inline)) {
    		  | ((value & 0x7F) << 16) | ((value & 0x3F80) << 17));
    shows what looks like a copy-and-paste error; the value 0x9009 (which corresponds to the two values 0x09, 0x90 for the Teensy 2 code) has been propogated from NoteOn to the other functions. The fix is therefore trivial:
    		usb_midi_write_packed(0xA00A | (((channel - 1) & 0x0F) << 8)
    		usb_midi_write_packed(0xB00B | (((channel - 1) & 0x0F) << 8)
    		usb_midi_write_packed(0xC00C | (((channel - 1) & 0x0F) << 8)
    		usb_midi_write_packed(0xD00D | (((channel - 1) & 0x0F) << 8)
    		usb_midi_write_packed(0xE00E | (((channel - 1) & 0x0F) << 8)
    I have made that change locally and verified that it works.
    22,072
    Oppps, yes, a copy-n-paste error indeed.
    The last couple days I've been testing the PC-to-Teensy3 MIDI stuff. I'm planning to publish beta9 later today, with MIDI enabled. It'll have this fixed.
    Boston, MA, USA
    1,111
    Confirming that Teensy beta9 gives the correct results with the above code, on Teensy 3.0.
    Feb 2013
    1
    there is another bug in usbMidi.sendProgramChange.
    where it says
    it must say:
    | ((program & 0x7F) << 16));
Tags for this Thread
