Results 1 to 3 of 3
Thread: Teensy 2.0 - I2C not connecting with BMPO85
    Feb 2013
    4
    I recently got a BMP085 from Drotek, trying to connect it now with my new Teensy 2 (ordered via Ada 2 weeks ago).
    Sadly, I don't get aaaaany output, not even with basic code & simple examples like
    http://https://docs.google.com/viewe...MDMzZTZj&hl=fr
    Just wondering whether the chip got fried or what I might be doing wrong... Coding with Arduino 1.0.3 & latest teensyduino.
    Issues with libraries? With I2C-pins? (aaaaaaaaarghhh)
    Connect SCL with D0 (pin5), SDA with D1 (pin6) ... 5V running of VCC near the USB-plug.
    ** Code going FUBAR at dps.init...
Name:	2013-03-01 21.07.49.jpg
    #include <BMP085.h>
    const int Speed = 19200;
    const int buzzPin = 4;
    char STRING[40]="";
    int32_t Pressure = 999999;
    int32_t Altitude = 99999;
    int pitch=400;
    int count=12;
    BMP085 dps = BMP085();
    void bleep(int toon=0) {
      tone(buzzPin,pitch,100);
      if (toon > 0) { delay(200); tone(buzzPin,pitch+150,150); }
    // the setup() method runs once, when the sketch starts
      delay(5000);
      bleep();
      Wire.begin();
      Serial.begin(28800);
      Serial.println("Starting DPS\n");
      dps.init();
      delay(1500);
      bleep(1);
      Serial.println("DPS Started.");
      dps.getPressure(&Pressure);       delay(200);
      dps.getAltitude(&Altitude);
      sprintf(STRING,"%lu,%lu,%lu,%u,%u,",Pressure,Altitude);
      Serial.println(STRING);
      tone(buzzPin,pitch*count++/4-200,100);
      delay(200);
    Is this board 5V tolerant? I think there a several BMP85 boards that are limited to 3.3V
    And: There are several broken examples for the BMP085 floating around, I had lots and lots of trouble until I found a working sketch.
    Feb 2013
    4
    Quote Originally Posted by ausserirdischegesund View Post
    Both boards are supposed to as announced. Bmp-board contains connections for 5V & 3.3V and something that looks like a voltage regulator... So I might expect it to be.
    No idea how resistant it could/might/will/shall be to voltage fluctuations though... Is the VoltReg not supposed to take this into account?
    Beside that, for both Sda and scl, pullups have been installed too...
