Results 1 to 2 of 2
Thread: Using Eclipse to upload to a Teensy++2.0?
    Question Using Eclipse to upload to a Teensy++2.0?
    I suspect the kind of Teensy 2 doesn't matter but what I am using today is a teensy++2.0
    I have my Eclipse environment all set up to build the hex file (which looks successful) and at the end my make file does this: teensy_reboot -v -v -v -v -pat90usb1286 -chalfkay -P/dev/ttyACM0 -b12000000 -D -Uflash:w:./Release/BlinkTeensy++2.0.hex:i
    It looks like it works and it shows me this:
    teensy_reboot, verbose mode
    pid:1, vid1, name:1
    found: /dev/ttyACM0
    add_serial_name, /dev/ttyACM0
    trying port 3149
    get_line: "Teensy Loader 1.06"
    found Teensy Loader, version 1.06
    send: status - at Tue Mar  5 18:00:52 2013
    sent: status - at Tue Mar  5 18:00:52 2013
    get_line: "dir:/tmp/build3641049840847516656.tmp/"
    get_line: "file:Blink.cpp.hex"
    get_line: "readable:1"
    readable = 1
    get_line: "auto:0"
    auto = 0
    get_line: "online:0"
    online = 0
    get_line: "online_count:0"
    online_count = 0
    get_line: "offline_count:0"
    offline_count = 0
    get_line: "state:0"
    state = 0
    get_line: "code_size:130048"
    get_line: "EOT"
    send: auto:on
    get_line: "Ok"
    do_reset (serial) /dev/ttyACM0
    -----------------------------removed a lot of repetition here
    send: status - at Tue Mar  5 18:00:53 2013
    sent: status - at Tue Mar  5 18:00:53 2013
    readable = 1
    get_line: "auto:1"
    auto = 1
    get_line: "online:1"
    online = 1
    get_line: "online_count:1"
    online_count = 1
    offline_count = 1
    get_line: "state:1"
    state = 1
    get_line: "EOT"
    status read, retry 8
    Success
    It is loading a file called Blink.cpp.hex from a tmp directory and, sure enough, this is what is running at the end. But this isn't the file I asked for.
    Does anyone know what is going on here? I actually thought this was working some time ago but think it fooled me. The file it loads is a test one I loaded from the Arduino IDE.
    How can I get the hex file I just built ie ./Release/BlinkTeensy++2.0.hex to load?
    I have tried obvious things like comparing the log from the Arduino IDE and making sure they are the same. The Arduino IDE does this:
    teensy_reboot -v -v -v -v -pat90usb1286 -chalfkay -P/dev/ttyACM0 -b12000000 -D -Uflash:w:/tmp/build3641049840847516656.tmp/Blink.cpp.hex:i
    I've tried simpler variations in the make file and I also tried using the cli which looked like it worked but nothing seemed to be running.
    Thanks for any help
    Roger
    I think I have this solved.
    I stopped using teensy_reboot and changed to the cli so my command is now:
    ${AVRDUDEPATH}/teensy_loader_cli -mmcu=${AVRTARGETMCU} -v -w ${PWD}/${BuildArtifactFileBaseName}.hex
    which translates out to
    /home/roger/kits/arduino-1.0/hardware/tools//teensy_loader_cli -mmcu=at90usb1286 -v -w /home/roger/workspaceCPP/BlinkTeensy++2.0/Release/BlinkTeensy++2.0.hex
    and produces the log:
    Teensy Loader, Command Line, Version 2.0
    Read "/home/roger/workspaceCPP/BlinkTeensy++2.0/Release/BlinkTeensy++2.0.hex": 2660 bytes, 2.0% usage
    Waiting for Teensy device...
     (hint: press the reset button)
    Found HalfKay Bootloader
    Programming...........
    Booting
    The program doesn't actually run yet but that's a different topic. I tested the cli using those switches with a known-working hex file and it definitely loads okay.
Tags for this Thread
