Results 1 to 7 of 7
Thread: Communication between Teensy2.0++ and Arduino Uno
    Mar 2013
    3
    Talking Communication between Teensy2.0++ and Arduino Uno
    Hello everybody!
    I was wondering if it was possibile to connect a teensy 2.0++ to an arduino with a serial comunication by using the usb(on the teensy) and a FTDI breakout board.
    Thank you
    16,248
    The best way would be directly connecting Arduino Uno's RX & TX pins (pin 0 and 1) to Teensy++ 2.0's RX & TX (pin 2 & 3).
    In other words, connect Uno pin 0 to Teensy++ pin 3. Connect Uno pin 1 to Teensy++ pin 2. Of course, also connect their grounds together.
    On Uno, use Serial, and on Teensy++, use Serial1.
    For the sake of development, you might want to connect the 2 signal wires through a double-pole switch (or 2 single-pole switches), so you can disconnect the Teensy++ when you upload new code to the Uno board.
    On Teensy++, the USB is completely separate from pins 2 and 3, so you can upload new code to Teensy++ even when Uno is still connected.
    Mar 2013
    3
    Thank you very much for the fast and complete answear. I was hoping to use all
    the pins on the board and use teensy's usb for communication. Is it possible to connect teensy to a board like this http://www.play-zone.ch/de/arduino-u...t-adapter.html and get it to communicate with arduino?
    16,248
    No, that's will not work. At least not yet. USB host most is not supported yet.
    Mar 2013
    3
    You mean that it is not possible to convert the teensy's usb back to ftdi serial?
    16,248
    Here's the USB spec. It's a huge document, but chapter 4 is short and explains the key details of USB, like host vs device roles.
    http://www.pjrc.com/teensy/beta/usb20.pdf
    Please read chapter 4. Teensy currently only supports device mode. That FTDI chip is also only a device. Chapter 4 should make the reason why this can't work much clearer.
    1,408
    In order to make things really easy communicating between the two MCU's I highly recommend Easy Transfer from Bill Porter.
Tags for this Thread
