Page 11 of 25 FirstFirst ... 9 10 11 12 13 21 ... LastLast
Results 251 to 275 of 616
Thread: New I2C library for Teensy3
  1. #251
    Quote Originally Posted by nox771 View Post
    In order to spoof the libraries into using i2c_t3 instead of Wire, without editing anything, you would probably need to either modify the build process, or rely on directory ordering, or simply swap in the i2c_t3 in place of the default Wire library.
    Thank you very much for this explanation and verification!
    Based on your inspiration I tried the following but I failed FAILED:
    1) Create a Wire directory in <sketchbook>/libraries:
    2 ) Create a Wire.h file in it with the following contents:
    #ifndef _WIRE_SPOOF_I2C_T3_
    #define _WIRE_SPOOF_I2C_T3_
    #include <i2c_t3.h>
    typedef i2c_t3 TwoWire;
    The idea being that I don't need to modify your i2c_t3 library as well.
    But it failed:
    C:\Users\Markus\Documents\Arduino\libraries\Adafruit_INA219\Adafruit_INA219.cpp: In member function 'void Adafruit_INA219::wireWriteRegister(uint8_t, uint16_t)':
    C:\Users\Markus\Documents\Arduino\libraries\Adafruit_INA219\Adafruit_INA219.cpp:38:3: error: 'Wire' was not declared in this scope
       Wire.beginTransmission(ina219_i2caddr);
    C:\Users\Markus\Documents\Arduino\libraries\Adafruit_INA219\Adafruit_INA219.cpp: In member function 'void Adafruit_INA219::wireReadRegister(uint8_t, uint16_t*)':
    C:\Users\Markus\Documents\Arduino\libraries\Adafruit_INA219\Adafruit_INA219.cpp:59:3: error: 'Wire' was not declared in this scope
    C:\Users\Markus\Documents\Arduino\libraries\Adafruit_INA219\Adafruit_INA219.cpp: In member function 'void Adafruit_INA219::begin()':
    C:\Users\Markus\Documents\Arduino\libraries\Adafruit_INA219\Adafruit_INA219.cpp:364:3: error: 'Wire' was not declared in this scope
       Wire.begin();
    Multiple libraries were found for "Wire.h"
     Used: C:\Users\Markus\Documents\Arduino\libraries\Wire
     Not used: C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire
    Error compiling.
    Well I guess I'll stick to your solution.
    Thanks again!
    __Mark
  2. #252
    Mar 2013
    Austin TX
    406
    Ok, I did some testing, there is a simple (but rather odd looking) way to do this even easier than above:
    1) First create a Wire library in your sketchbook folder, with a Wire.h file in it:
    <sketchbook>/libraries/Wire/Wire.h
    2) Put the following contents in the Wire.h file:
    #include <i2c_t3.h>
    3) In your main sketch, setup the includes exactly like this:
    #include <i2c_t3.h>
    #include <Wire.h>             // fake include - points back to i2c_t3
    #include <Adafruit_INA219.h>
    This looks strange, like it is using both i2c_t3 and Wire, but Wire in this case will be the one from <sketchbook>/libraries due to Arduino build prioritization (which points to i2c_t3 and instantiates a Wire object). The #include <i2c_t3.h> is needed to force the linker to include it in the build even though it is not used directly (only indirectly via Wire.h).
    See if that can work for you. It does not require duplicating the library or base install, but it does require the headers to be included as shown.
  3. #253
    Mar 2013
    Austin TX
    406
    I've added a section to the top-post regarding resistor pullup configurations. It should cover the most common questions.
  4. #254
    6,066
    Nice - good detail - though I think you could safely add one of Paul's quotes for reference for 'if your I2C isn't working': "You do need two pullup resistors, one from SDA to 3.3V and one from SCL to 3.3V."
    * I'm not sure how long I've known what a pullup looked like or how it was properly wired (2% of my life?) so added detail could help in the learning curve
  5. #255
    That's exactly what I tried, but stupid me forgot to select the Teensy 3.1 board in the Arduino IDE. I usually work with Visual Micro for Arduino inside Visual Studio (where the spoofing worked anyway).
    Note the additional typedef I use in the spoofing Wire.h
    #include <i2c_t3.h>
    This allows for code that handles I2C buses as objects (i.e. multi bus capable libs such as the ones I am currently developping).
    I think this is a feasible pattern after all that works without touching any third party libs.
    Thanks again,
    Mark
  6. #256
    Start and stop
    Is there a way to control start and stop bit through the library ?
    I want to use it to read values from smart batteries on SMBus.
    I need to repeat the start bit and avoid the stop one.
  7. #257
    Mar 2013
    Austin TX
    406
    Quote Originally Posted by esapode688 View Post
    Yes repeated STARTs are possible (use I2C_NOSTOP on the command which should not end with a STOP). IIRC, the hardware has more low-level support for SMBus, but I haven't had a chance to study it.
  8. #258
    Sep 2015
    1
    The version of i2c_t3 included in Teensyduino 1.25 appears to be broken with the Teensy 3.0.
    C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\i2c_t3\i2c_t3.cpp: In static member function 'static uint8_t i2c_t3::setOpMode_(i2cStruct*, uint8_t, i2c_op_mode)':
    C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\i2c_t3\i2c_t3.cpp:289:84: error: 'DMAMUX_SOURCE_I2C1' was not declared in this scope
    i2c->DMA->triggerAtHardwareEvent((bus == 0) ? DMAMUX_SOURCE_I2C0 : DMAMUX_SOURCE_I2C1);
    Error compiling.
    This line should probably be wrapped with a preprocessor if.
  9. #259
    Mar 2013
    Austin TX
    406
    Quote Originally Posted by lunchbox View Post
    Error compiling.
    Ah thanks, I'll look into it.
  10. #260
    Sep 2015
    1
    Hello.
    Would it be possible to connect Teensy 3.1 to I2C bus which contains only 5V devices without level-shifters?
    Since Teensy 3.1 is 5V tolerant, the plan is to connect pullup resistors for SDL and SCL to 5V (instead of 3.3V). Are there any significant downsides of this method?
    Teensy will have slightly lower threshold values for high and low levels. For 5V device VH=3.5, VL=1.75 and for Teensy VH=2.31, VL=1.15 (assuming VH=0.7*Vdd, VL=0.35*Vdd). But I could not figure out what effect it will have on I2C performance.
  11. #261
    You can use Mosfet level shifters ... snazzy solution, see: http://www.nxp.com/documents/applica...te/AN10441.pdf
    David
  12. #262
    Sep 2015
    1
    thanks a lot for this library. Is the best one I found in the last month.
    At the address 0x00 i2c_t3.h Library returns an ACK even when the unit is powered off.
    Im using a device with a broadcast address 0x00 which addresses a group of up to 8 units each with their own I2C addresses (two per unit: Controller and EEPROM). All units respones to Braodcast adress 0x00.
    How can one check, if i2c on 0x00 is active and how can I use this address?
    On arduino with wire.h or with Peter Fleurys i2cmaster.h this works fine.
  13. #263
    Mar 2013
    Austin TX
    406
    Quote Originally Posted by max.b View Post
    Hello.
    Sorry for the huge delay in response, completely didn't see the notice on this. In theory this should work ok because it is on a 5V tolerant I/O. Moreover because the pullup is resistive it is inherently a current-limited connection. The lower switch threshold of the Teensy shouldn't be a problem as long as your pullup resistance is not excessively low. It should not affect the performance.
    Problems come up when you have a non-current-limited connection (eg. hard-tie to say 5V if a 3.3V device is on the bus with a supply-connected ESD diode, then the diode will hard clamp the voltage to ~4V at whatever current it can take - until it blows).
    I have in the past connected differing voltage devices using just series resistors (specifically different voltage shift-registers), and they ran fine (but they had dual-diode ESD). The ESD was probably mildly forward-biased, but the series R keeps it away from damaging current levels. Although I should mention some devices now use entirely ground-referenced ESD (referred to as ggNMOS - grounded-gate-NMOS), so that's not always a workable idea (ggNMOS will trip at a high-voltage, above supply, and then snapback).
    So all that said, this is a try at your own risk type of thing, but for your specific case I think it can work.
  14. #264
    Mar 2013
    Austin TX
    406
    Quote Originally Posted by Wonderer View Post
    Sorry for the delay, 0x00 is not a valid Slave address, it is the General Call address. Refer to the I2C spec here, page 17 specifically:
    http://www.nxp.com/documents/user_manual/UM10204.pdf
    The Teensy I2C hardware can be configured to recognize it. The library is not configured to use it at the moment. If you look at the Freescale documentation here:
    http://pjrc.com/teensy/K20P64M72SF1RM.pdf
    Refer to Chapter 46, pg 1178, the GCAEN bit controls the feature. It should be disabled by default. There is additional info in Chapter 46 regarding that bit. If a GC is received the library would probably need to be modified to parse the 2nd byte after the GC to determine what to do. I haven't worked with this feature yet as I don't have any Slaves which support it.
  15. #265
    16
    I2C LCD to working correctly
    I can't seem to get I2C to work correctly
    I tried the standard "wire.h" but I can not get the i2C LCD to work.
    I have used the Serial LCD Module 20x4 Blue with White Backlight 5v version for years with 324/1284 based avr boards with no issue. I bought the 3.3V version to work the Teensy.
    Product Datasheet: http://media.nkcelectronics.com/datashe ... -BBW-33V33
    Arduino Sample program: http://media.nkcelectronics.com/downloa ... Serial.ino
    Arduino 1.0 library: http]s://github.com/downloads/nkcelectronics/SerialLCD/SerialLCD.zip
    I used the standard Arduino library but used:
    "#include <i2c_t3.h>"
    instead of the standard wire library.
    The board has 10K resistors. I another 10K pull up in parallel.
    The display starts working out find but eventual decays as if missing messages.
    Any ideas why?
    Bruce
  16. #266
    Mar 2013
    Austin TX
    406
    Quote Originally Posted by bvernham View Post
    Any ideas why?
    I wasn't able to access any of those links, I just get server error. Perhaps try uploading your code example to the forum.
    It is difficult to speculate on a cause, it would be just random guessing. If initial messages work, but later ones don't then perhaps there is some other overriding cause in the code (eg. messages too fast, other devices on the bus, insufficient timing on slow bus, etc). There could also be hardware issues, power supply fluctuating (particularly if a backlight is involved), pullup resistance, etc.
    You may need to incorporate a more rigorous error-checking methodology in your code. For instance, send an I2C message, then check the return value from the calls. For i2c_t3 this would be Wire.status() and Wire.getError() calls. Print the return codes after each transmission to the Serial window.
    EDIT: your links are entered wrong - use the "Link" button on the text entry form to set them up.
  17. #267
    16
      NKC Electronics serial display - Demo
     Demonstrates different functions of the Serial LCD module
      The circuit:
     * LCD SCL pin to Arduino SCL pin or Analog 5
     * LCD SDA pin to Arduino SDA pin or Analog 4
     * LCD VSS pin to GND
     * LCD VDD pin to +5V
    #include <SerialLCD.h>
    //#include <Wire.h>
    #include <i2c_t3.h>
    // make some custom characters:
    byte heart[8] = {
      0b00000,
      0b01010,
      0b11111,
      0b11111,
      0b11111,
      0b01110,
      0b00100,
      0b00000
    byte smiley[8] = {
      0b00000,
      0b00000,
      0b01010,
      0b00000,
      0b00000,
      0b10001,
      0b01110,
      0b00000
    byte frownie[8] = {
      0b00000,
      0b00000,
      0b01010,
      0b00000,
      0b00000,
      0b00000,
      0b01110,
      0b10001
    byte armsDown[8] = {
      0b00100,
      0b01010,
      0b00100,
      0b00100,
      0b01110,
      0b10101,
      0b00100,
      0b01010
    byte armsUp[8] = {
      0b00100,
      0b01010,
      0b00100,
      0b10101,
      0b01110,
      0b00100,
      0b00100,
      0b01010
    // Constructor.  Parameters: rows, columns, baud/i2c_address, interface (RS232, I2C, SPI)
    SerialLCD lcd(2,16,0x28,I2C);
      // Initialize LCD module
      lcd.init();
      // create a new character
      lcd.createChar(0, heart);
      lcd.createChar(1, smiley);
      lcd.createChar(2, frownie);
      lcd.createChar(3, armsDown);
      lcd.createChar(4, armsUp);
      // Set Contrast
      lcd.setContrast(40);
      // Set Backlight
      lcd.setBacklightBrightness(8);
      int i;
      lcd.home();
      lcd.displayVersion();
      delay(2000);
      lcd.clear();
      lcd.displayBaudRate();
      delay(2000);
      lcd.clear();
      lcd.displayI2CAddress();
      delay(2000);
      lcd.clear();
      // Write some text to the display.  Show custom characters
      lcd.home();
      lcd.setCursor(1, 1);
      lcd.print("CustomChars");
      lcd.write((byte)0);
      lcd.write(1);
      lcd.write(2);
      lcd.write(3);
      lcd.write(4);
      // blinking cursor, move cursor and change text
      lcd.setCursor(2, 1);
      lcd.print("This is original");
      delay(2000);
      lcd.blinkOn();
      for (i=0; i<8; i++) {
        lcd.right();
      lcd.print("modified");
      lcd.blinkOff();
      delay(2000);
      lcd.print("scrolling text..");
      lcd.setCursor(1,6);
      for (i=0; i<15; i++) {
        lcd.shiftRight();
        lcd.shiftLeft();
      delay(2000);
      for (i=0; i<MAX_CONTRAST; i++) {
        lcd.setContrast(i);
      delay(2000);
      for (i=0; i<MAX_BRIGHTNESS; i++) {
        lcd.setBacklightBrightness(i);
      delay(2000);
        // Set Contrast
      // Set Backlight
      delay(2000);
    http://media.nkcelectronics.com/data...-BBW-33V33.pdf
    I am presently using the USB power supply.
    The display is by itself.
    Pull ups are 10K on the board. I tried adding another 10K (so actually 5K) in parallel and it did not help.
    The display work fine at 400K with the UNO and the 1284P I am using (5V version).
    I will follow up on the more rigorous error checking.
    Bruce
  18. #268
    2,628
    Note, the normal pull-up resistors for i2c is 4.7K. It might be 10K is too high.
  19. #269
    Can this library handle multimaster --- by that I mean handle multiple masters on a single bus, and allow the masters to address one another? I have done this previously with Wire by initializing them to be addressed slaves, but then using the master-send routines.
    Thanks.
    David
    PS This library is a tour de force!
  20. #270
    16
  21. #271
    2,628
    I believe 10K pull-ups are TOO HIGH for 3.3v systems. For example a google search brings up from Phil Pilgrim: http://forums.parallax.com/discussio...on-scl-and-sda
    Quote Originally Posted by Phil Pilgrim
    My recommendation is 4.7K on both lines. 10K -- especially in 3.3V systems -- is too high a value, particularly for high-speed operation.
    And this from an Adafruit forum: http://forums.adafruit.com/viewtopic.php?f=8&t=45373:
    Quote Originally Posted by frank26080115
    I usually find that 400KHz I2C busses will malfunction using 10K resistors at 3.3V, it's safer to start with 4.7K, and move down to 2.7K if you experience any errors.
    This datasheet mentions how to calculate the appropriate resistors based on the capacitive load on the i2c lines: http://www.ti.com/lit/an/slva689/slva689.pdf
  22. #272
    16
    Once again... both 10K and 5K (10K in parallel) were tried with the same result.
  23. #273
    4k7 , or 5k in your case should be ok at 3v3,
    with a following wind etc.
    some I2C chips need 5v on the power, even if they are 3v3 'compatible' and if your using usb power, that can be well below the 5v level.
    for 3v3 I'd normally go for 2K2 to get any speed out of I2C
    Its out with the scope to check the actual signal levels / shape.
    I2C is real easy, thats to get write and wrong, there are so many variants of it now.
    sorry on small screen device here, did you say what the I2C device you have a slave is
  24. #274
    16
    I2C Slave LCD Not working
  25. #275
    One of the better Chinese data sheets I have seen,
    You seem to be in happy position of having a scope and a demo working with a 5v uno to compare with.
    so at least you know the LCD works.
    so out with scope.
    What I2C levels are you getting on the I2C on the teensy and the UNO.
    You might want to look at pulse timing also , assuming any are on the I2C lines.
    A few things concerned me with the data sheet, the fact the I2C address can be set to 'anything', and the same pins supporting RS232, SPI and I2C.
    also the ambiguity about the 5v and 3v3 status of the LCD.
    When you ran the LCD with the UNO, what did you do for the 3v3 logic and power levels the LCD wants.
