manitou
Senior Member+
Does any one have a working snippet of using DMA with SPI on teensy 3.0. Here is my non-working attempt ...
// teensy SPI + DMA TODO
// CS,MOSI,MISO,CLK pins 10-13
// dma ch0 xmit (mem to SPI) ch1 recv (SPI to mem)
// try byte, 16-bit, and 32-bit dma transfers ? SPI 16-bit
// do exchange, read/write 0xff, write/sink read
// don't need ISR for now, spin wait
// ref https://github.com/hughpyle/teensy-i2s our mem2mem
#define CSpin 10
#define RSER_RFDF_DIRS (1<<16)
#define RSER_RFDF_RE (1<<17)
#define RSER_TFFF_DIRS (1<<24)
#define RSER_TFFF_RE (1<<25)
volatile int DMAdone=0;
#define DMA_CINT_CINT(n) ((uint8_t)(n & 3)<<0) // Clear Interrupt Request
void dma_ch0_isr(void)
DMAdone=1;
DMA_CINT = DMA_CINT_CINT(0); // use the Clear Intr. Request register
void dma_ch1_isr(void)
DMAdone=1;
DMA_CINT = DMA_CINT_CINT(1); // use the Clear Intr. Request register
void spidma_init() {
// set size, and SPI address for xmit and recv dma
// TODO enable DMA in SPI regs ...
SPI0_RSER = RSER_RFDF_DIRS | RSER_RFDF_RE | RSER_TFFF_DIRS | RSER_TFFF_RE;
DMA_TCD0_DADDR = &SPI0_PUSHR;
DMA_TCD1_SADDR = &SPI0_POPR;
DMA_TCD0_ATTR = DMA_TCD_ATTR_SSIZE(0) | DMA_TCD_ATTR_DSIZE(0); //8 bit
DMA_TCD1_ATTR = DMA_TCD_ATTR_SSIZE(0) | DMA_TCD_ATTR_DSIZE(0); //8 bit
DMA_TCD0_SLAST = 0;
DMA_TCD1_SLAST = 0;
DMA_TCD0_DOFF = 1; // increment
DMA_TCD1_DOFF = 1; // increment
DMA_TCD0_CITER_ELINKNO = 1;
DMA_TCD1_CITER_ELINKNO = 1;
DMA_TCD0_DLASTSGA = 0;
DMA_TCD1_DLASTSGA = 0;
DMA_TCD0_BITER_ELINKNO = 1;
DMA_TCD1_BITER_ELINKNO = 1;
DMAdone=0;
// DMA_TCD1_CSR = DMA_TCD_CSR_INTMAJOR; // interrupt on major loop completion
void myspi_init() {
// set up SPI speed and dma ? FIFO
SPI.begin();
SPI.setBitOrder(MSBFIRST);
SPI.setDataMode(SPI_MODE0);
pinMode(CSpin,OUTPUT);
spidma_init();
void spidma_transfer(char *inbuf, char *outbuf, int bytes) {
void spidma_write(char *outbuf, int bytes) {
static int sink;
digitalWrite(CSpin,LOW);
DMA_TCD0_SADDR = outbuf;
DMA_TCD1_DADDR = &sink; // ignore bytes from SPI
DMA_TCD0_NBYTES_MLNO = bytes;
DMA_TCD1_NBYTES_MLNO = bytes;
DMA_TCD1_CSR |= (1<<6) | (1<<3); // active and clear SERQ
DMA_TCD0_CSR |= (1<<6) | (1<<3); // start transmit
DMA_SERQ =0; // enable channel
DMA_SERQ =1; // enable channel
while (!(DMA_TCD0_CSR & DMA_TCD_CSR_DONE)) /* wait */ ;
digitalWrite(CSpin,HIGH);
void spidma_read(char *inbuf, int bytes) {
static int whatever = 0xffffffff;
DMA_TCD0_SADDR = &whatever;
DMA_TCD1_DADDR = inbuf;
DMA_TCD1_CSR |= (1<<6);
DMA_TCD0_CSR |= (1<<6); // start transmit
while (!(DMA_TCD1_CSR & DMA_TCD_CSR_DONE)) /* wait */ ;
while(!Serial.available()){
Serial.println("hit a key");
Serial.read();
Serial.println("ok");
myspi_init();
Serial.println(SPI0_CTAR0,HEX);
Serial.println(SPI0_RSER,HEX);
delay(2000);
char buff[1000];
unsigned int t1,t2;
Serial.println("looping");
t1 = micros();
spidma_write(buff,sizeof(buff));
t2 = micros() - t1;
Serial.println(t2);
delay(2000);
