3.0 Board Joystick Example Not Working?
abenamou
New member
Using the 3.0 board and Examples->Teensy->USB_Joystick->Complete. Compile and upload to the 3.0 board, then plug into a Windows 7 box (tried several). Device is detected but none of the button presses register under the joy.cpl test tab. Using a 2.0 board in the same way works fine. Anyone using 3.0 with the Joystick example fine, maybe I have bad board?
Can you verify if your pushbuttons are working and connected correctly? When the button is not pressed, the pin should measure 3.3 volts. When you press the button, it should become 0 volts.
