el_supremo
Although the T++2 hardware has pin change interrupts on all pins on Port B, none of them are accessible in Teensyduino. The code only handles the INTn interrupts.
I need a couple of pin change interrupts (FALLING) which can wake up the processor from a power down sleep but INT4-7 can only do that with a level interupt (LOW). INT0 and INT1 are used by the I2C interface and INT2 and INT3 are used by the serial port, both of which are in use.
Is there some way that I can set up pin change interrupts on, say, pins 26 and 27?
Pete
Pete
