u8g_com_arduino_hw_spi.c
Universal 8bit Graphics Library
Copyright (c) 2011, olikraus@gmail.com
All rights reserved.
Redistribution and use in source and binary forms, with or without modification,
are permitted provided that the following conditions are met:
* Redistributions of source code must retain the above copyright notice, this list
of conditions and the following disclaimer.
* Redistributions in binary form must reproduce the above copyright notice, this
list of conditions and the following disclaimer in the documentation and/or other
materials provided with the distribution.
THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND
CONTRIBUTORS "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES,
INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF
MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR
CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT
NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER
CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT,
STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF
ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
SPI Clock Cycle Type
SSD1351 50ns 20 MHz
SSD1322 300ns 3.3 MHz
SSD1327 300ns
SSD1306 300ns
ST7565 400ns 2.5 MHz
ST7920 400ns
Arduino DUE
PA25 MISO
PA26 MOSI 75
PA27 SCLK 76
typedef struct {
WoReg SPI_CR; (Spi Offset: 0x00) Control Register
RwReg SPI_MR; (Spi Offset: 0x04) Mode Register
RoReg SPI_RDR; (Spi Offset: 0x08) Receive Data Register
WoReg SPI_TDR; (Spi Offset: 0x0C) Transmit Data Register
RoReg SPI_SR; (Spi Offset: 0x10) Status Register
WoReg SPI_IER; (Spi Offset: 0x14) Interrupt Enable Register
WoReg SPI_IDR; (Spi Offset: 0x18) Interrupt Disable Register
RoReg SPI_IMR; (Spi Offset: 0x1C) Interrupt Mask Register
RoReg Reserved1[4];
RwReg SPI_CSR[4]; (Spi Offset: 0x30) Chip Select Register
RoReg Reserved2[41];
RwReg SPI_WPMR; (Spi Offset: 0xE4) Write Protection Control Register
RoReg SPI_WPSR; (Spi Offset: 0xE8) Write Protection Status Register
} Spi;
Power Management Controller (PMC)
arduino-1.5.2/hardware/arduino/sam/system/CMSIS/Device/ATMEL/sam3xa/include/instance/instance_pmc.h
- enable PIO
REG_PMC_PCER0 = 1UL << ID_PIOA
- enable SPI
REG_PMC_PCER0 = 1UL << ID_SPI0
- enable PIOA and SPI0
REG_PMC_PCER0 = (1UL << ID_PIOA) | (1UL << ID_SPI0);
Parallel Input/Output Controller (PIO)
arduino-1.5.2/hardware/arduino/sam/system/CMSIS/Device/ATMEL/sam3xa/include/instance/instance_pioa.h
- enable special function of the pin: disable PIO on A26 and A27:
REG_PIOA_PDR = 0x0c000000
PIOA->PIO_PDR = 0x0c000000
SPI
SPI0->SPI_CR = SPI_CR_SPIDIS
SPI0->SPI_CR = SPI_CR_SWRST ;
SPI0->SPI_CR = SPI_CR_SPIEN
Bit 0: Master Mode = 1 (active)
Bit 1: Peripheral Select = 0 (fixed)
Bit 2: Chip Select Decode Mode = 1 (4 to 16)
Bit 4: Mode Fault Detection = 1 (disabled)
Bit 5: Wait Data Read = 0 (disabled)
Bit 7: Loop Back Mode = 0 (disabled)
Bit 16-19: Peripheral Chip Select = 0 (chip select 0)
SPI0->SPI_MR = SPI_MR_MSTR | SPI_MR_PCSDEC | SPI_MR_MODFDIS
Bit 0: Clock Polarity = 0
Bit 1: Clock Phase = 0
Bit 4-7: Bits = 0 (8 Bit)
Bit 8-15: SCBR = 1
SPI0->SPI_CSR[0] = SPI_CSR_SCBR(x) Serial Baud Rate
SCBR / 84000000 > 50 / 1000000000
SCBR / 84 > 5 / 100
SCBR > 50 *84 / 1000 --> SCBR=5
SCBR > 300*84 / 1000 --> SCBR=26
SCBR > 400*84 / 1000 --> SCBR=34
Arduino Due test code:
REG_PIOA_PDR = 0x0c000000;
SPI0->SPI_CR = SPI_CR_SPIDIS;
SPI0->SPI_CR = SPI_CR_SWRST;
SPI0->SPI_CR = SPI_CR_SPIEN;
SPI0->SPI_MR = SPI_MR_MSTR | SPI_MR_PCSDEC | SPI_MR_MODFDIS;
SPI0->SPI_CSR[0] = SPI_CSR_SCBR(30);
for(;;)
while( (SPI0->SPI_SR & SPI_SR_TDRE) == 0 )
SPI0->SPI_TDR = 0x050;
#include "u8g.h"
#if defined(ARDUINO)
#if defined(__AVR__)
#define U8G_ARDUINO_ATMEGA_HW_SPI
/* remove the definition for attiny */
#if __AVR_ARCH__ == 2
#undef U8G_ARDUINO_ATMEGA_HW_SPI
#if __AVR_ARCH__ == 25
#if defined(U8G_ARDUINO_ATMEGA_HW_SPI)
#include <avr/interrupt.h>
#include <avr/io.h>
#if ARDUINO < 100
#include <WProgram.h>
/* fixed pins */
#if defined(__AVR_ATmega644P__) || defined(__AVR_ATmega1284P__) // Sanguino.cc board
#define PIN_SCK 7
#define PIN_MISO 6
#define PIN_MOSI 5
#define PIN_CS 4
#else // Arduino Board
#define PIN_SCK 13
#define PIN_MISO 12
#define PIN_MOSI 11
#define PIN_CS 10
#endif // (__AVR_ATmega644P__) || defined(__AVR_ATmega1284P__)
#else
#include <Arduino.h>
/* use Arduino pin definitions */
#define PIN_SCK SCK
#define PIN_MISO MISO
#define PIN_MOSI MOSI
#define PIN_CS SS
//static uint8_t u8g_spi_out(uint8_t data) U8G_NOINLINE;
/* unsigned char x = 100; */
/* send data */
SPDR = data;
/* wait for transmission */
while (!(SPSR & (1<<SPIF)))
/* clear the SPIF flag by reading SPDR */
return SPDR;
uint8_t u8g_com_arduino_hw_spi_fn(u8g_t *u8g, uint8_t msg, uint8_t arg_val, void *arg_ptr)
switch(msg)
case U8G_COM_MSG_STOP:
case U8G_COM_MSG_INIT:
u8g_com_arduino_assign_pin_output_high(u8g);
pinMode(PIN_SCK, OUTPUT);
digitalWrite(PIN_SCK, LOW);
pinMode(PIN_MOSI, OUTPUT);
digitalWrite(PIN_MOSI, LOW);
/* pinMode(PIN_MISO, INPUT); */
pinMode(PIN_CS, OUTPUT); /* system chip select for the atmega board */
digitalWrite(PIN_CS, HIGH);
SPR1 SPR0
0 0 fclk/4
0 1 fclk/16
1 0 fclk/64
1 1 fclk/128
SPCR = 0;
SPCR = (1<<SPE) | (1<<MSTR)|(0<<SPR1)|(0<<SPR0)|(0<<CPOL)|(0<<CPHA);
#ifdef U8G_HW_SPI_2X
SPSR = (1 << SPI2X); /* double speed, issue 89 */
#else
if ( arg_val <= U8G_SPI_CLK_CYCLE_50NS )
case U8G_COM_MSG_ADDRESS: /* define cmd (arg_val = 0) or data mode (arg_val = 1) */
u8g_com_arduino_digital_write(u8g, U8G_PI_A0, arg_val);
case U8G_COM_MSG_CHIP_SELECT:
if ( arg_val == 0 )
/* disable */
u8g_com_arduino_digital_write(u8g, U8G_PI_CS, HIGH);
/* enable */
u8g_com_arduino_digital_write(u8g, U8G_PI_SCK, LOW);
u8g_com_arduino_digital_write(u8g, U8G_PI_CS, LOW);
case U8G_COM_MSG_RESET:
if ( u8g->pin_list[U8G_PI_RESET] != U8G_PIN_NONE )
u8g_com_arduino_digital_write(u8g, U8G_PI_RESET, arg_val);
case U8G_COM_MSG_WRITE_BYTE:
u8g_spi_out(arg_val);
case U8G_COM_MSG_WRITE_SEQ:
register uint8_t *ptr = arg_ptr;
while( arg_val > 0 )
u8g_spi_out(*ptr++);
arg_val--;
case U8G_COM_MSG_WRITE_SEQ_P:
u8g_spi_out(u8g_pgm_read(ptr));
ptr++;
arg_val--;
return 1;
/* #elif defined(__18CXX) || defined(__PIC32MX) */
#elif defined(__SAM3X8E__) // Arduino Due, maybe we should better check for __SAM3X8E__
#define PIN_SCK SCK
#define PIN_CS SS
/* wait until tx register is empty */
/* send data */
SPI0->SPI_TDR = (uint32_t)data;
return data;
switch(msg)
/* Arduino Due specific code */
/* enable PIOA and SPI0 */
/* disable PIO on A26 and A27 */
/* reset SPI0 (from sam lib) */
u8g_MicroDelay();
/* master mode, no fault detection, chip select 0 */
/* Polarity, Phase, 8 Bit data transfer, baud rate */
/* x * 1000 / 84 --> clock cycle in ns
5 * 1000 / 84 = 58 ns
SPI0->SPI_CSR[0] = SPI_CSR_SCBR(5) | 1;
else if ( arg_val <= U8G_SPI_CLK_CYCLE_300NS )
SPI0->SPI_CSR[0] = SPI_CSR_SCBR(26) | 1;
else if ( arg_val <= U8G_SPI_CLK_CYCLE_400NS )
SPI0->SPI_CSR[0] = SPI_CSR_SCBR(34) | 1;
SPI0->SPI_CSR[0] = SPI_CSR_SCBR(84) | 1;
u8g_MicroDelay();
u8g_MicroDelay();
if ( arg_val == 0 )
/* disable */
u8g_MicroDelay(); /* this delay is required to avoid that the display is switched off too early --> DOGS102 with DUE */
u8g_MicroDelay();
/* enable */
//u8g_com_arduino_digital_write(u8g, U8G_PI_SCK, LOW);
u8g_MicroDelay();
u8g_MicroDelay();
arg_val--;
ptr++;
arg_val--;
return 1;
#elif defined(__MK20DX128__) || defined(__MK20DX256__)
#include <limits.h>
#include "pins_arduino.h"
#include "wiring_private.h"
// new Chris O.
// Teensy 3.1 can only generate 30 MHz SPI when running at 120 MHz (overclock)
// At all other speeds, SPI.beginTransaction() will use the fastest available clock
#define SPICLOCK 30000000
#define _rst (u8g->pin_list[U8G_PI_RESET])
#define _cs (u8g->pin_list[U8G_PI_CS])
#define _rs (u8g->pin_list[U8G_PI_A0])
uint8_t _sid, _sclk;
uint8_t pcs_data, pcs_command;
uint32_t ctar;
volatile uint8_t *datapin, *clkpin, *cspin, *rspin;
bool hwSPI = false;
bool nextIsCommand = false;
//#endif
inline void writebegin()
inline void spiwrite(uint8_t c)
for (uint8_t bit = 0x80; bit; bit >>= 1) {
*datapin = ((c & bit) ? 1 : 0);
*clkpin = 1;
*clkpin = 0;
void writecommand(uint8_t c)
if (hwSPI) {
// new Chris O.
SPI.beginTransaction(SPISettings(SPICLOCK, MSBFIRST, SPI_MODE0));
KINETISK_SPI0.PUSHR = c | (pcs_command << 16) | SPI_PUSHR_CTAS(0);
while (((KINETISK_SPI0.SR) & (15 << 12)) > (3 << 12)) ; // wait if FIFO full
SPI.endTransaction();
*rspin = 0;
*cspin = 0;
spiwrite(c);
*cspin = 1;
void writedata(uint8_t c)
if (hwSPI) {
// new Chris O.
KINETISK_SPI0.PUSHR = c | (pcs_data << 16) | SPI_PUSHR_CTAS(0);
*rspin = 1;
*cspin = 0;
spiwrite(c);
*cspin = 1;
void writedata16(uint16_t d)
if (hwSPI) {
// new Chris O.
KINETISK_SPI0.PUSHR = d | (pcs_data << 16) | SPI_PUSHR_CTAS(1);
*rspin = 1;
*cspin = 0;
spiwrite(d >> 8);
spiwrite(d);
*cspin = 1;
inline void write(uint8_t c)
if(nextIsCommand)
writecommand(c);
writedata(c);
static bool spi_pin_is_cs(uint8_t pin)
if (pin == 2 || pin == 6 || pin == 9) return true;
if (pin == 10 || pin == 15) return true;
if (pin >= 20 && pin <= 23) return true;
return false;
static uint8_t spi_configure_cs_pin(uint8_t pin)
switch (pin) {
case 10: CORE_PIN10_CONFIG = PORT_PCR_MUX(2); return 0x01; // PTC4
case 2: CORE_PIN2_CONFIG = PORT_PCR_MUX(2); return 0x01; // PTD0
case 9: CORE_PIN9_CONFIG = PORT_PCR_MUX(2); return 0x02; // PTC3
case 6: CORE_PIN6_CONFIG = PORT_PCR_MUX(2); return 0x02; // PTD4
case 20: CORE_PIN20_CONFIG = PORT_PCR_MUX(2); return 0x04; // PTD5
case 23: CORE_PIN23_CONFIG = PORT_PCR_MUX(2); return 0x04; // PTC2
case 21: CORE_PIN21_CONFIG = PORT_PCR_MUX(2); return 0x08; // PTD6
case 22: CORE_PIN22_CONFIG = PORT_PCR_MUX(2); return 0x08; // PTC1
case 15: CORE_PIN15_CONFIG = PORT_PCR_MUX(2); return 0x10; // PTC0
return 0;
// new Chris O.
//#define SPICLOCK 30000000 // I DID THIS ON THE BEGINING
#define CTAR_24MHz (SPI_CTAR_PBR(0) | SPI_CTAR_BR(0) | SPI_CTAR_CSSCK(0) | SPI_CTAR_DBR)
#define CTAR_16MHz (SPI_CTAR_PBR(1) | SPI_CTAR_BR(0) | SPI_CTAR_CSSCK(0) | SPI_CTAR_DBR)
#define CTAR_12MHz (SPI_CTAR_PBR(0) | SPI_CTAR_BR(0) | SPI_CTAR_CSSCK(0))
#define CTAR_8MHz (SPI_CTAR_PBR(1) | SPI_CTAR_BR(0) | SPI_CTAR_CSSCK(0))
#define CTAR_6MHz (SPI_CTAR_PBR(0) | SPI_CTAR_BR(1) | SPI_CTAR_CSSCK(1))
#define CTAR_4MHz (SPI_CTAR_PBR(1) | SPI_CTAR_BR(1) | SPI_CTAR_CSSCK(1))
void setBitrate(uint32_t n)
// new Chris O.
// ? SPI.beginTransaction(SPISettings(SPICLOCK, MSBFIRST, SPI_MODE0));
if (n >= 24000000) {
ctar = CTAR_24MHz;
} else if (n >= 16000000) {
ctar = CTAR_16MHz;
} else if (n >= 12000000) {
ctar = CTAR_12MHz;
} else if (n >= 8000000) {
ctar = CTAR_8MHz;
} else if (n >= 6000000) {
ctar = CTAR_6MHz;
ctar = CTAR_4MHz;
SIM_SCGC6 |= SIM_SCGC6_SPI0;
KINETISK_SPI0.MCR = SPI_MCR_MDIS | SPI_MCR_HALT;
KINETISK_SPI0.CTAR0 = ctar | SPI_CTAR_FMSZ(7);
KINETISK_SPI0.CTAR1 = ctar | SPI_CTAR_FMSZ(15);
KINETISK_SPI0.MCR = SPI_MCR_MSTR | SPI_MCR_PCSIS(0x1F) | SPI_MCR_CLR_TXF | SPI_MCR_CLR_RXF;
// SPI.endTransaction();
write(data);
return 0;
switch(msg)
//from https://github.com/PaulStoffregen/Adafruit_ST7735/blob/master/Adafruit_ST7735.cpp
if (_sid == 0) _sid = 11;
if (_sclk == 0) _sclk = 13;
if ( spi_pin_is_cs(_cs) && spi_pin_is_cs(_rs)
&& (_sid == 7 || _sid == 11)
&& (_sclk == 13 || _sclk == 14)
&& !(_cs == 2 && _rs == 10) && !(_rs == 2 && _cs == 10)
&& !(_cs == 6 && _rs == 9) && !(_rs == 6 && _cs == 9)
&& !(_cs == 20 && _rs == 23) && !(_rs == 20 && _cs == 23)
&& !(_cs == 21 && _rs == 22) && !(_rs == 21 && _cs == 22) ) {
hwSPI = true;
//uncomment this line to test for hardware SPI
//the program will take an extra 10 seconds to start up
//delay(10000);
// new Chris O.
// SPI.beginTransaction(SPISettings(SPICLOCK, MSBFIRST, SPI_MODE0));
if (_sclk == 13) {
CORE_PIN13_CONFIG = PORT_PCR_MUX(2) | PORT_PCR_DSE;
SPCR.setSCK(13);
CORE_PIN14_CONFIG = PORT_PCR_MUX(2);
SPCR.setSCK(14);
if (_sid == 11) {
CORE_PIN11_CONFIG = PORT_PCR_MUX(2);
SPCR.setMOSI(11);
CORE_PIN7_CONFIG = PORT_PCR_MUX(2);
SPCR.setMOSI(7);
ctar = CTAR_24MHz;
pcs_data = spi_configure_cs_pin(_cs);
pcs_command = pcs_data | spi_configure_cs_pin(_rs);
//SPI.endTransaction();
hwSPI = false;
cspin = portOutputRegister(digitalPinToPort(_cs));
rspin = portOutputRegister(digitalPinToPort(_rs));
clkpin = portOutputRegister(digitalPinToPort(_sclk));
datapin = portOutputRegister(digitalPinToPort(_sid));
*cspin = 1;
*rspin = 0;
*clkpin = 0;
*datapin = 0;
pinMode(_cs, OUTPUT);
pinMode(_rs, OUTPUT);
pinMode(_sclk, OUTPUT);
pinMode(_sid, OUTPUT);
if (_rst) {
pinMode(_rst, OUTPUT);
digitalWriteFast(_rst, HIGH); //digitalWriteFast
digitalWriteFast(_rst, LOW);
if(hwSPI)
nextIsCommand = (arg_val == 0);
if(!hwSPI)
if ( arg_val == 0 )
/* disable */
/* enable */
register uint8_t *ptr = (uint8_t*)arg_ptr;
arg_val--;
ptr++;
arg_val--;
return 1;
#else
#endif /* U8G_ARDUINO_ATMEGA_HW_SPI */
#else /* ARDUINO */
return 1;
#endif /* ARDUINO */
