FPS.pde
>>> Before compiling: Please remove comment from the constructor of the
>>> connected graphics display (see below).
Universal 8bit Graphics Library, http://code.google.com/p/u8glib/
Copyright (c) 2012, olikraus@gmail.com
All rights reserved.
Redistribution and use in source and binary forms, with or without modification,
are permitted provided that the following conditions are met:
* Redistributions of source code must retain the above copyright notice, this list
of conditions and the following disclaimer.
* Redistributions in binary form must reproduce the above copyright notice, this
list of conditions and the following disclaimer in the documentation and/or other
materials provided with the distribution.
THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND
CONTRIBUTORS "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES,
INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF
MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR
CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT
NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER
CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT,
STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF
ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
ST7920_192X32, SPI: FPS: Box=7.6 @=9.8 iFPS: Box=11.4 @=14.7
ST7920_192X32, 8Bit: FPS: Box=6.2 @=7.5 iFPS: Box=9.3 @=11.2
DOGM128 SW SPI: FPS: Box=5.1 @=5.9 Pix=2.6 iFPS: Box=10.2 @=11.8 Pix=5.2
DOGM128 HW SPI: FPS: Box=5.5 @=6.3 iFPS: Box=11.0 @=12.6
DOGXL160 SW SPI: FPS: Box=1.7 @=1.9 iFPS: Box=6.9 @=7.7
DOGXL160 HW SPI: FPS: Box=1.8 @=2.1
NHD27OLED_BW, SW SPI: FPS: Box=3.0 @=3.7
NHD27OLED_BW, HW SPI: FPS: Box=3.5 @=4.5
NHD27OLED_2X_BW, SW SPI: FPS: Box=3.8 @=4.9
NHD27OLED_2X_BW, HW SPI: FPS: Box=4.6 @=6.4
30 Sep 2012
NHD27OLED_BW, SW SPI: FPS: Clip=9.2 Box=3.9 @=4.4 NEW_CODE
NHD27OLED_BW, SW SPI: FPS: Clip=9.2 Box=3.6 @=4.5
NHD27OLED_BW, HW SPI: FPS: Clip=16.3 Box=4.7 @=5.6
NHD27OLED_2X_BW, SW SPI: FPS: Clip=9.7 Box=4.5 @=5.8
NHD27OLED_2X_BW, SW SPI: FPS: Clip=18.0 Box=5.8 @=7.9
1 Oct 2012
ST7920_192X32, 8Bit: FPS: Box=7.2 @=10.0
DOGM128 SW SPI: FPS: Box=5.2 @=6.6 Pix=2.6
DOGM128 HW SPI: FPS: Clip=33.2 Box=5.5 @=7.1
DOGXL160 SW SPI: FPS: Box=1.7 @=2.0
DOGXL160 HW SPI: FPS: Box=1.8 @=2.2
DOGXL160 GR SW SPI: FPS: Box=1.1 @=1.3
1 Mar 2013
ST7920_192X32_1X, SPI: FPS: Clip=10.3 Box=5.5 @=7.2 Pix=3.9
ST7920_192X32_4X, SPI: FPS: Clip=10.9 Box=6.7 @=8.8 Pix=7.4
ST7920_192X32_1X, 8Bit: FPS: Clip=14.2 Box=6.1 @=8.4 Pix=4.2
ST7920_192X32_4X, 8Bit: FPS: Clip=14.2 Box=7.8 @=10.7 Pix=8.7
ST7920_192X32_1X, HW SPI: FPS: Clip=14.2 Box=6.3 @=8.7 Pix=4.3
ST7920_192X32_4X, HW SPI: FPS: Clip=15.3 Box=8.0 @=11.2 Pix=9.0
2 Jun 2013
U8GLIB_DOGM128 SW SPI: FPS: Clip=23.9 Box=4.5 @=6.6 Pix=2.1
U8GLIB_DOGM128_2X SW SPI: FPS: Clip=28.5 Box=6.6 @=9.7 Pix=3.9
U8GLIB_DOGM128_2X HW SPI: FPS: Clip=40.8 Box=7.1 @=10.8 Pix=4.1
3 Jun 2013
U8GLIB_ST7920_192X32_1X -Os SW SPI FPS: Clip=11.0 Box=5.4 @=7.1 Pix=3.9 Size=11828
U8GLIB_ST7920_192X32_1X -O3 SW SPI FPS: Clip=10.9 Box=5.6 @=7.5 Pix=4.0 Size=13800
U8GLIB_ST7920_192X32_1X -Os SW SPI FPS: Clip=16.8 Box=6.7 @=9.6 Pix=4.5 Size=11858 (new seq data output)
U8GLIB_ST7920_192X32_1X -Os HW SPI FPS: Clip=25.7 Box=7.5 @=11.3 Pix=4.8 (new seq data output)
6 Jun 2013
U8GLIB_DOGS102 u8g(13, 11, 10, 9); STD SW SPI FPS: Clip=9.5 Box=7.6 @=8.2 Pix=6.2 Size=15652
U8GLIB_DOGS102 u8g(13, 11, 10, 9); SW SPI FPS: Clip=19.1 Box=12.8 @=14.0 Pix=9.2 Size=15532
12 Jun 2013
SSD1351_128X128_332 SW SPI FPS: Clip=1.3 Box=0.7 @=0.9 Pix=0.4
SSD1351_128X128_332 HW SPI FPS: Clip=3.6 Box=1.1 @=1.5 Pix=0.5
24 Jun 2013
Uno SSD1351_128X128_332 SW SPI FPS: Clip=1.4 Box=0.8 @=0.9 Pix=0.4
Uno SSD1351_128X128_332 HW SPI FPS: Clip=4.4 Box=1.2 @=1.6 Pix=0.5
Uno SSD1351_128X128_HICOLOR HW SPI FPS: Clip=3.7 Box=0.8 @=1.0 Pix=0.3
Mega2560 SSD1351_128X128_332 HW SPI FPS: Clip=4.4 Box=1.2 @=1.6 Pix=0.5
Mega2560 SSD1351_128X128_4X_332 HW SPI FPS: Clip=4.6 Box=2.3 @=2.8 Pix=1.5
Mega2560 SSD1351_128X128_HICOLOR HW SPI FPS: Clip=3.6 Box=0.8 @=1.0 Pix=0.3
Mega2560 SSD1351_128X128_4X_HICOLOR HW SPI FPS: Clip=4.2 Box=1.7 @=2.1 Pix=1.0
Due SSD1351_128X128_332 HW SPI FPS: Clip=24.6 Box=6.3 @=7.8 Pix=2.8
Due SSD1351_128X128_4X_332 HW SPI FPS: Clip=28.1 Box=13.0 @=15.1 Pix=8.5
Due SSD1351_128X128_HICOLOR HW SPI FPS: Clip=20.8 Box=3.4 @=4.5 Pix=1.4
Due SSD1351_128X128_4X_HICOLOR HW SPI FPS: Clip=26.3 Box=8.9 @=11.1 Pix=4.8
Due SSD1351_128X128_4X_HICOLOR SW SPI FPS: Clip=0.4 Box=0.4 @=0.4 Pix=0.4
Due DOGS102 u8g(13, 11, 10, 9); SW SPI FPS: Clip=19.1 Box=13.1 @=14.3 Pix=9.4
Due DOGS102 u8g(10, 9); HW SPI FPS: Clip=128.9 Box=30.7 @=40.6 Pix=15.4
Due NHD27OLED_BW u8g(10, 9) HW SPI FPS: Clip=53.0 Box=19.6 @=23.8 Pix=10.6
Due NHD27OLED_2X_BW u8g(10, 9) HW SPI FPS: Clip=57.0 Box=25.3 @=31.7 Pix=18.1
Due NHD27OLED_GR u8g(10, 9) HW SPI FPS: Clip=34.1 Box=11.7 @=13.7 Pix=5.6
Due NHD27OLED_2X_GR u8g(10, 9) HW SPI FPS: Clip=38.1 Box=15.5 @=20.0 Pix=8.8
01 Jun 2014
16 Bit mode: NHD-3.12-25664UMB3 OLED 256 x 64 pixel resolution
Teensy 3.0 (CPU SPEED 96Mhz) NHD31OLED_BW u8g(13, 11, 10, 9) SW SPI FPS: Clip=2.5 Box=2.1 @=2.2 Pix=1.8
Teensy 3.0 (CPU SPEED 48Mhz) NHD31OLED_BW u8g(10, 9) HW SPI FPS: Clip=37.2 Box=7.7 @=10.0 Pix=4.1
Teensy 3.0 (CPU SPEED 96Mhz) NHD31OLED_BW u8g(10, 9) HW SPI FPS: Clip=46.3 Box=9.5 @=11.3 Pix=5.2
Teensy 3.0 (CPU SPEED 96Mhz) NHD31OLED_2X_BW u8g(10, 9) HW SPI FPS: Clip=49.6 Box=13.3 @=16.3 Pix=9.2
Teensy 3.0 (CPU SPEED 96Mhz) NHD31OLED_2X_GR u8g(10, 9) HW SPI FPS: Clip=37.6 Box=8.4 @=10.4 Pix=4.5
Improved performance:
For Teensy 3.x, there is a digitalWriteFast(pin, value) function that will compile to the fastest possible ARM code
using only a single bus cycle. http://forum.pjrc.com/threads/23431-Teensy-3-using-IO-pins
For improved performance replace digitalWrite with digitalWriteFast in ...\arduino-1.0.5\libraries\U8glib\utility\u8g_com_arduino_common.c
Teensy 3.0 (CPU SPEED 96Mhz) NHD31OLED_2X_BW u8g(10, 9) HW SPI FPS: Clip=50.7 Box=13.4 @=16.4 Pix=9.2
// SPI Library
#include <SPI.h> //IMPORTANT NOTE: Needed for hw spi on teensy 3.x with Hoss U8G modify Library.
// http://forum.pjrc.com/threads/23445-Teensy-3-0-and-u8glib/page3
#include "U8glib.h"
// setup u8g object, please remove comment from one of the following constructor calls
// IMPORTANT NOTE: The following list is incomplete. The complete list of supported
// devices with all constructor calls is here: http://code.google.com/p/u8glib/wiki/device
//U8GLIB_NHD27OLED_BW u8g(13, 11, 10, 9); // SPI Com: SCK = 13, MOSI = 11, CS = 10, A0 = 9
//U8GLIB_NHD27OLED_2X_BW u8g(13, 11, 10, 9); // SPI Com: SCK = 13, MOSI = 11, CS = 10, A0 = 9
//U8GLIB_NHD27OLED_GR u8g(13, 11, 10, 9); // SPI Com: SCK = 13, MOSI = 11, CS = 10, A0 = 9
//U8GLIB_NHD27OLED_2X_GR u8g(13, 11, 10, 9); // SPI Com: SCK = 13, MOSI = 11, CS = 10, A0 = 9
//U8GLIB_NHD27OLED_BW u8g(10,9); // HW SPI Com: CS = 10, A0 = 9 (Hardware Pins are SCK = 13 and MOSI = 11)
//U8GLIB_NHD27OLED_2X_BW u8g(10,9); // HW SPI Com: CS = 10, A0 = 9 (Hardware Pins are SCK = 13 and MOSI = 11)
//U8GLIB_NHD27OLED_GR u8g(10,9); // HW SPI Com: CS = 10, A0 = 9 (Hardware Pins are SCK = 13 and MOSI = 11)
//U8GLIB_NHD27OLED_2X_GR u8g(10,9); // HW SPI Com: CS = 10, A0 = 9 (Hardware Pins are SCK = 13 and MOSI = 11)
//U8GLIB_NHD31OLED_BW u8g(13, 11, 10, 9); // SPI Com: SCK = 13, MOSI = 11, CS = 10, A0 = 9
//U8GLIB_NHD31OLED_2X_BW u8g(13, 11, 10, 9); // SPI Com: SCK = 13, MOSI = 11, CS = 10, A0 = 9
//U8GLIB_NHD31OLED_GR u8g(13, 11, 10, 9); // SPI Com: SCK = 13, MOSI = 11, CS = 10, A0 = 9
//U8GLIB_NHD31OLED_2X_GR u8g(13, 11, 10, 9); // SPI Com: SCK = 13, MOSI = 11, CS = 10, A0 = 9
//U8GLIB_NHD31OLED_BW u8g(10,9); // HW SPI Com: CS = 10, A0 = 9 (Hardware Pins are SCK = 13 and MOSI = 11)
//U8GLIB_NHD31OLED_2X_BW u8g(10, 9); // HW SPI Com: CS = 10, A0 = 9 (Hardware Pins are SCK = 13 and MOSI = 11)
//U8GLIB_NHD31OLED_GR u8g(10, 9); // HW SPI Com: CS = 10, A0 = 9 (Hardware Pins are SCK = 13 and MOSI = 11)
//U8GLIB_NHD31OLED_2X_GR u8g(10, 9); // HW SPI Com: CS = 10, A0 = 9 (Hardware Pins are SCK = 13 and MOSI = 11)
IMPORTANT NOTE: Needed 16 Bit mode for NHD-3.12-25664UMB3 OLED 256 x 64 pixel resolution
16 Bit mode: U8glib can be put into 16 Bit mode. Remove comment from {{{#define U8G_16BIT 1}}} in ...\arduino-1.0.5\libraries\U8glib\utility\u8g.h
-------------------> My Pinout connections for NHD-3.12-25664UMB3 OLED <------------------------------------
Teensy 3.x <--wire-connection--to-> NHD-3.12-25664UMB3 OLED
4-wire Serial Interface:
PIN-13 -> SCK -------------------> PIN-7 SCLK Serial Clock signal. (Hardware Pins are SCK = 13)
PIN-11 -> DOUT, MOSI ------------> PIN-8 SDIN Serial Data Input signal. (Hardware Pins are MOSI = 11)
PIN-10 -> CS, Select Device -----> PIN-16 CS Active LOW Chip Enable signal.
PIN-9 -> D/C, A0 ---------------> PIN-4 D/C Register select signal. D/C=0: Command, D/C=1: Data
PIN-3.3v+(100 mA max)-> /Reset --> PIN-15 /RES Active LOW Reset signal. (Connect to Teensy 3.x 3.3v+)
PIN-GND --to Uno GND to ---------> PIN-1 VSS Power Supply Ground (-)
IMPORTANT NOTE: needs 3.3v Power Supply other then teensy (100 mA max).
I had been using Arduino Uno 3.3v out (Connect Uno GND to Teensy GND)
Arduino Uno 3.3v out (+) --------> PIN-2 VDD Power Supply Supply Voltage for OLED and logic 3.3V (+)
PIN-3 NC No Connect
PIN-5 VSS Power Supply Ground (-)
PIN-6 VSS Power Supply Ground (-)
PIN-9 NC No Connect
PIN-10>14 VSS Power Supply Ground (-)
PIN-17 BS1 GND / 4-wire Serial Interface / MPU Interface Select signal.
PIN-18 BS0 GND / 4-wire Serial Interface / MPU Interface Select signal.
PIN-19>22 NC No Connect / Multi-font IC
#define SECONDS 10
uint8_t flip_color = 0;
uint8_t draw_color = 1;
void draw_set_screen(void) {
// graphic commands to redraw the complete screen should be placed here
if ( u8g.getMode() == U8G_MODE_HICOLOR ) {
if ( flip_color == 0 )
u8g.setHiColorByRGB(0,0,0);
u8g.setHiColorByRGB(255,255,255);
else {
u8g.setColorIndex(flip_color);
u8g.drawBox( 0, 0, u8g.getWidth(), u8g.getHeight() );
void draw_clip_test(void) {
u8g_uint_t i, j, k;
char buf[3] = "AB";
k = 0;
else {
u8g.setColorIndex(draw_color);
u8g.setFont(u8g_font_6x10);
for( i = 0; i < 6; i++ ) {
for( j = 1; j < 8; j++ ) {
u8g.drawHLine(i-3, k, j);
u8g.drawHLine(i-3+10, k, j);
u8g.drawVLine(k+20, i-3, j);
u8g.drawVLine(k+20, i-3+10, j);
k++;
u8g.drawStr(0-3, 50, buf);
u8g.drawStr180(0+3, 50, buf);
u8g.drawStr(u8g.getWidth()-3, 40, buf);
u8g.drawStr180(u8g.getWidth()+3, 40, buf);
u8g.drawStr90(u8g.getWidth()-10, 0-3, buf);
u8g.drawStr270(u8g.getWidth()-10, 3, buf);
u8g.drawStr90(u8g.getWidth()-20, u8g.getHeight()-3, buf);
u8g.drawStr270(u8g.getWidth()-20, u8g.getHeight()+3, buf);
void draw_char(void) {
char buf[2] = "@";
u8g_uint_t i, j;
else {
j = 8;
for(;;) {
i = 0;
for(;;) {
u8g.drawStr( i, j, buf);
i += 8;
if ( i > u8g.getWidth() )
j += 8;
if ( j > u8g.getHeight() )
void draw_pixel(void) {
u8g_uint_t x, y, w2, h2;
else {
w2 = u8g.getWidth();
h2 = u8g.getHeight();
w2 /= 2;
h2 /= 2;
for( y = 0; y < h2; y++ ) {
for( x = 0; x < w2; x++ ) {
if ( (x + y) & 1 ) {
u8g.drawPixel(x,y);
u8g.drawPixel(x,y+h2);
u8g.drawPixel(x+w2,y);
u8g.drawPixel(x+w2,y+h2);
// returns unadjusted FPS
uint16_t picture_loop_with_fps(void (*draw_fn)(void)) {
uint16_t FPS10 = 0;
uint32_t time;
time = millis() + SECONDS*1000;
// picture loop
do {
u8g.firstPage();
do {
draw_fn();
} while( u8g.nextPage() );
FPS10++;
flip_color = flip_color ^ 1;
} while( millis() < time );
return FPS10;
const char *convert_FPS(uint16_t fps) {
static char buf[6];
strcpy(buf, u8g_u8toa( (uint8_t)(fps/10), 3));
buf[3] = '.';
buf[4] = (fps % 10) + '0';
buf[5] = '\0';
return buf;
void show_result(const char *s, uint16_t fps) {
// assign default color value
else {
u8g.setFont(u8g_font_8x13B);
u8g.firstPage();
do {
u8g.drawStr(0,12, s);
u8g.drawStr(0,24, convert_FPS(fps));
void setup(void) {
// flip screen, if required
// u8g.setRot180();
if ( u8g.getMode() == U8G_MODE_R3G3B2 )
draw_color = 255; // white
else if ( u8g.getMode() == U8G_MODE_GRAY2BIT )
draw_color = 3; // max intensity
else if ( u8g.getMode() == U8G_MODE_BW )
draw_color = 1; // pixel on
else if ( u8g.getMode() == U8G_MODE_HICOLOR ) {
void loop(void) {
uint16_t fps;
fps = picture_loop_with_fps(draw_clip_test);
show_result("draw clip test", fps);
delay(5000);
fps = picture_loop_with_fps(draw_set_screen);
show_result("clear screen", fps);
delay(5000);
fps = picture_loop_with_fps(draw_char);
show_result("draw @", fps);
delay(5000);
fps = picture_loop_with_fps(draw_pixel);
show_result("draw pixel", fps);
delay(5000);
