Page 2 of 2 FirstFirst 1 2
Results 26 to 29 of 29
Thread: analogWriteFrequency and analogWrite rounding
  1. #26
    Thanks again for your help! Here is the improved code:
    #include <math.h>
    #define pwm_pin 2
    #define ftm 3
    #define alt 4
    #define FTM_CHANCFG(chan) FTM_CHANCFG2(chan)
    #define FTM_CHANCFG2(chan) FTM ## chan ## _C0V
    #define FTM_PINCFG(pin) FTM_PINCFG2(pin)
    #define FTM_PINCFG2(pin) CORE_PIN ## pin ## _CONFIG
    // input values:
    double delta_t_ms = 0.2;                        // ramp stage duration in ms
    double f_min = 3000.0;                          // start frequency in steps/s: if too slow for delta_t f_min will be increased in init()
    double a_f_max_ms = 500.0;                      // max possible frequency increment per ms in steps/ms
    double steps_R = 200.0;                         // steps per motor revolution
    double microsteps = 16.0;                       // microstepping in microsteps per step
    // timing belt or rack & pinion:
    const double diameter_mm = 40.0;                // diameter of pinion in mm
    const double ratio = 1.0;                       // gear ratio (> 1 = slower speed)
    // or lead screw:
    const double threadpitch_mm = 8.0;              // thread pitch in mm: set to zero if pinion driven
    // desired:
    double s_wanted_cm = 16.0;                      // desired travel in cm
    double v_wanted_cms = 25.0;                     // desired speed in cm/s
    double s_c_min = 0.001;                         // minimum travel with constant speed in m
    double delta_t;                                 // ramp stage duration (derived from delta_t_ms) in s
    double delta_t_us;                              // ramp stage duration (derived from delta_t_ms) in Ás
    double delta_f;                                 // frequency increment per ramp stage
    double a_f_max;                                 // max possible frequency increment per ms (derived from a_f_max_ms) in steps/ms
    double s_wanted;                                // desired travel (derived from s_wanted_cm) in m
    double v_wanted;                                // desired speed (derived from v_wanted_cms) in m/s
    double a_f;                                     // actual acceleration in steps/s^2
    double t_a;                                     // duration of acceleration in s
    double t_c;                                     // duration of travel with constant speed v_wanted in s
    double t_c_ms;                                  // duration of travel with constant speed v_wanted in ms
    double t_c_us;                                  // duration of travel with constant speed v_wanted in Ás
    double N;                                       // total number of ramp stages
    double n;                                       // actual ramp stage
    double u;                                       // conversion factor frequency to speed v/f in m/steps
    double f;                                       // actual frequency in steps/s
    double f_wanted;                                // desired frequency in steps/s
    double t_n_us;                                  // time stamp of ramp stage in Ás
    double t_total;                                 // total time = 2 * t_a + t_c
    double s_c;                                     // travel with constant speed in m
    double a;                                       // acceleration in m/s^2
    double v;                                       // achievable max speed in m/s
    double s_a;                                     // travel of ramp in m
    uint32_t mck = F_BUS;                           // PWM source frequency
    const uint8_t duty_percent = 50;                // 50% duty cycle
    const uint8_t resolution_pwm = 12;              // PWM resolution
    uint8_t prescaler;                              // smallest possible divider will be calced
    uint16_t duty;                                  // duty cicle value
      pinMode(pwm_pin, OUTPUT);
      analogWriteResolution(resolution_pwm);
      init();
      start();
    double calc_freq(double freq) {
      uint16_t period = calc_period(freq);
      return (double)(mck >> prescaler) / (double)(period + 1);
    uint32_t calc_period(double freq) {
      for (prescaler = 0; prescaler < 7; prescaler++) {
        double freq_min = (double)(mck >> prescaler) / 65536.0;
        if (freq >= freq_min) break;
      return (double)(mck >> prescaler) / ((double)freq) - 0.5;
    double simul_ramp(double f_min, double a_f, double delta_t, uint32_t N) {
      // simulation of ramp in order to obtain accurate travel
      double delta_f = a_f * delta_t;
      double f = f_min;
      double s_f = 0.0;                                                         // travel / u, where u = v / f
      uint32_t n = 0;
      while (n < N) {
        s_f += floor(delta_t * calc_freq(f));
        f += delta_f;
        n += 1;
      return (double) u * s_f;
    void init() {
      delta_t = delta_t_ms / 1000.0;                                            // time increment in s
      a_f_max = a_f_max_ms * 1000.0;                                            // frequency increment in steps/s^2
      s_wanted = s_wanted_cm / 100.0;                                           // desired travel in m
      v_wanted = v_wanted_cms / 100.0;                                          // desired speed in m/s
      if (threadpitch_mm == 0) {
        u = (PI * (diameter_mm / 1000.0) / ratio) / (steps_R * microsteps);     // in m/steps
      else {
        u = threadpitch_mm / 1000.0 / (steps_R * microsteps);                   // in m/steps
      // calculations with the presumption that speed is the limiting factor
      f_wanted = v_wanted / u;                                                  // in steps/s
      // corrections for frequencys
      f_wanted = calc_freq(f_wanted);
      if (f_min < ceil(1000.0 / delta_t_ms)) f_min = ceil(1000.0 / delta_t_ms); // update f_min if too slow for delta_t
      f_min = calc_freq(f_min);
      a_f = a_f_max;                                                            // in steps/s^2
      t_a = (f_wanted - f_min) / a_f;                                           // in s
      N = floor(t_a / delta_t) + 1;
      // correction of a_f in order to obtain equal ramp stages of f for N ramp stages of delta_t
      a_f = (f_wanted - f_min) / (N * delta_t);
      // re-calculation with new a_f
      t_a = N * delta_t;
      // predict minimum needed travel to reach v_wanted
      s_a = simul_ramp(f_min, a_f, delta_t, N);
      // in case s_wanted is the limiting factor
      if (2 * s_a + s_c_min > s_wanted) {
        // calculations with the presumption that travel is the limiting factor
        // s_wanted/2 is limiting the duration of the ramp
        a_f = a_f_max;
        s_a = s_wanted / 2 - s_c_min;
        t_a = sqrt((2 * s_a / (u * a_f)) + ((f_min / a_f) * (f_min / a_f))) - (f_min / a_f);
        // recalculate max possible speed
        f_wanted = calc_freq(a_f * t_a);
        // re-calculate number of ramp stages
        t_a = N * delta_t;
        // re-predict travel
      s_c = s_wanted - 2 * s_a;                                                              // travel with constant speed in m
      v = u * f_wanted;        // reached speed (v <= v_wanted) in m/s
      a = u * a_f;        // acceleration in m/s^2
      t_c = s_c / v;        // duration of travel with constant speed in s
      t_total = 2 * t_a + t_c;                                                               // total duration in s
      // preparations:
      delta_t_us = delta_t_ms * 1000.0;
      t_c_us = t_c * 1000000.0;
      duty = ((uint32_t)((duty_percent << resolution_pwm) * 0.01) * (uint32_t)(calc_period(f_wanted + 1))) >> resolution_pwm;
    void start() {
      // ramp-up
      double t_pulse_us;
      f = f_min;
      n = 0;
      t_n_us = 0.0;
      if (FTM_CHANCFG(ftm) == 0) (t_n_us += round(1000000 / f_min));
      t_n_us += micros();
      while (n < N) {
        analogWriteFrequency(pwm_pin, f);
        if (n == 0) {
          FTM_CHANCFG(ftm) = duty;
          FTM_PINCFG(pwm_pin) = PORT_PCR_MUX(alt) | PORT_PCR_DSE | PORT_PCR_SRE;
        n += 1;
        // calculate next time stamp:
        t_pulse_us = 1000000.0 / calc_freq(f);
        t_n_us += round(floor(delta_t_us / t_pulse_us) * t_pulse_us);
        f += delta_f;
        // needed waiting time = next time stamp minus last time stamp:
        while (micros() <= t_n_us);
      analogWriteFrequency(pwm_pin, f_wanted);
      n = 0;
      t_n_us += round(floor(t_c_us / t_pulse_us) * t_pulse_us);
      f -= delta_f;
      // ramp-down
      while (n < N) {
        n += 1;
        if (n == N) t_n_us -= 500000 / f;
        f -= delta_f;
    EDIT: minor fixes
  2. #27
    Just to report: I read Pauls recommendations on this forum about oscilloscopes and bought a Rigol DS1054Z (4channel 50Mhz). There are glitches when changing frequency, I tried to remove them by updating PWM earlier, but this doesn't work with high frequencys as the LOW-time gets too short [EDIT: I also tried shifting the PWM phase as described here]. Here is a scope shot of a single PWM pulse with a (negative) spike at the beginning:
    I will try to smooth out these spikes with some kind of circuit, do you have any hints for me where I can look for a good starting point?
  3. #28
    Resistor-Capacitor into a Schmitt trigger.
    Start with a 500pF capacitor and 100 ohm resistor. My guess is you'll get it reliably rejected between 100 ohm to 500 ohm.
    Adjust the resistor value so a typical glitch dips to about 50%. The Schmitt trigger should be about to safely reject 50% with some reasonable margin.
  4. #29
    Many thanks, I tried the suggestions and got nice glitch free ramps. I tidied up the code a bit and updated #26 with it. I think I am ready to use teensies in my projects from now
