Dear friends,
I have configured Teensy's USB type to be Disk (SD card) + Keyboard. I hope to receive the serial data from Teensy. Although there is no USB type of Disk+Serial, I think this is possible because in Serial Monitor, I am able to see the messages.
Under linux, my dmesg shows that Teensy is being recognized as Teensy Disk/Keyboard. No serial is mentioned. I have tried minicom on ttyS0 with no success.
I have the following questions and wonder if you can help me:
1, Is this actually possible? If possible in Teensyduino or C, could you give me some rough guidelines? If not, what would you recommend me to do to allow Teensy communicate back to the PC in the way SerialMonitor works?
2, What port is Teensy recognized as under Linux? I looked at the preferences.txt, it says serial.port=COM1, which only makes sense in the context of Windows.
Thanks for your help!
Huan
Huan
