I have integrated the teensy 3 with a wiznet ethernet module and I have already established that it works by running the example Webserver sketch.
The task I am attempting to accomplish at the moment is simply communicating to a server and writing to a text file. Essentially whats going on is the teensy sends a message to a php script running on the server and then the script populates a .txt with the providing information. Simple right?
The issue I am having is that I've gotten my sketch and teensy/wiznet project to work twice already. But I can't repeat the results ever since. I am lighting a debug LED which turns on, however nothing is being written to the console. I am just confused as to what may actually be going on.... any thoughts?
I'm sure these are all beginner issues I am having so any help would be appreciated. Thanks!
myWebClient3.INO
myWebClient3.INO
#include <Ethernet.h>
// Enter a MAC address for your controller below.
byte mac[] = { 0x**, 0x**, 0x**, 0x**, 0x**, 0x** };//Blue Teensy
IPAddress server(***,***,***,***);
// Initialize the Ethernet client library
// with the IP address and port of the server
// that you want to connect to (port 80 is default for HTTP):
EthernetClient client;
//debug LED
pinMode(23, OUTPUT);
digitalWrite(23, HIGH);
//Serial.println("Serial connection works");
// start the Ethernet connection:
if (Ethernet.begin(mac) == 0) {
Serial.println("Failed to configure Ethernet using DHCP");
// no point in carrying on, so do nothing forevermore:
for(;;)
// give the Ethernet shield a second to initialize:
Serial.println("connecting...");
// if you get a connection, report back via serial:
if (client.connect(server, 80)) {
Serial.println("connected");
// Make a HTTP request:
client.println("GET /sendData.php?name=cameFrom&status=theTeensy!/");
client.println();
client.println();
else {
// kf you didn't get a connection to the server:
Serial.println("connection failed");
//sendData();
//delay(3000);
void sendData(){
if(client.connected()){
client.println("GET /sendData.php?name=Client&status=ItWorkedAGAIN/");
client.println();
Serial.println("Looped Success cause still connected!");
else if (client.connect(server, 80)) {
client.println("GET /sendData.php?name=Client&status=ItWorkedInAgain/");
client.println();
Serial.println("Looped Success and had to reconnect!");
else {
Serial.println("Looped Fail and could not reconnect");
